Home » Archived » Visual Editor (VE) » How to extend the palette ?
How to extend the palette ? [message #40434] Mon, 07 June 2004 13:17 Go to next message
Hi all,
Any examples on how to extend the palette in the Eclipse Visual
Editor ? There;s one article from IBM but it is quite old...
I'm looking for 1.0M1 example...
Re: How to extend the palette ? [message #40496 is a reply to message #40434] Tue, 08 June 2004 05:25 Go to previous messageGo to next message
Hi Ivan
We don't have an updated article, but the basic principles still apply.
The best way to try to extend the palette is to look at an example
of where the VE already does it, so the ideas in the article still
largely apply and the syntax is just different. To see the correct
syntax/method look at the org.eclipse.ve.jfc plugin (that adds AWT/Swing
to the palette) and also org.eclipse.ve.swt (that adds SWT support).
There is a detailed document about the VE extension points for
contributors that covers the palette at:
http://dev.eclipse.org/viewcvs/indextools.cgi/~checkout~/vep -home/WebContent/docs/contributors/contributors.html
Joe Winchester
Re: How to extend the palette ? [message #40527 is a reply to message #40496] Tue, 08 June 2004 08:55 Go to previous messageGo to next message
ohh.... thanks~ :-)
Joe Winchester wrote:
> Hi Ivan
> apply. The best way to try to extend the palette is to look at an
> example of where the VE already does it, so the ideas in the article
> still largely apply and the syntax is just different. To see the
> correct syntax/method look at the org.eclipse.ve.jfc plugin (that adds
> AWT/Swing to the palette) and also org.eclipse.ve.swt (that adds SWT
> support).
> Best regards,
> Joe Winchester
Re: How to extend the palette ? [message #40581 is a reply to message #40527] Tue, 08 June 2004 12:08 Go to previous messageGo to next message
The example plug-ins included in the VE-examples file from the download
page also can be used as good reference for the palette, beaninfo and
overrides extension points. Check out the plugin.xml, examplecats.xmi
and Area.override in that zip, should you be interested :)
- Jeff
Ivan wrote:
> ohh.... thanks~ :-)
>> Hi Ivan
>> support).
>> Best regards,
>> Joe Winchester
Re: How to extend the palette ? [message #40610 is a reply to message #40581] Tue, 08 June 2004 22:29 Go to previous messageGo to next message
Thanks guy~ :-)
I would like to comment some thing about this.... I think de eclipe way
to extend palette a bit.... harder than JDev or JBuilder....
Any plan to create something that will auto generate those files out ? :-)
Thanks guy :-)
> download page also can be used as good reference for the palette,
> beaninfo and overrides extension points. Check out the plugin.xml,
> examplecats.xmi and Area.override in that zip, should you be
> interested :)
> - Jeff
> Ivan wrote:
>> ohh.... thanks~ :-)
>>> Hi Ivan
>>> an example of where the VE already does it, so the ideas in the
>>> article still largely apply and the syntax is just different. To
>>> see the correct syntax/method look at the org.eclipse.ve.jfc plugin
>>> (that adds AWT/Swing to the palette) and also org.eclipse.ve.swt
>>> Best regards,
>>> Joe Winchester
Re: How to extend the palette ? [message #40703 is a reply to message #40610] Wed, 09 June 2004 08:43 Go to previous messageGo to next message
Hi Ivan,
Please create a bugzilla feature request for us to do this. It's
something we need to do, but the feature request will help us to put it
in plan and also have a discussion as to the best approach. We need to
tackle different scenarios such as a) plugin provider wants to provide a
palette 2) user wants ad-hoc customization and also we need to think
about the whole approach where the user updates the build path first and
the palette responds - other ideas might include everything available on
the palette with non-build path entries disabled somehow, and selecting
them would add them to the build path. The problem with this is that
they could represent things like different JRE levels so we need to
think about how to present that without confusion.
Getting a discussion about this on a bugzilla feature request would be
great, so please open and contribute your ideas.
Joe Winchester
Re: How to extend the palette ? [message #40734 is a reply to message #40610] Wed, 09 June 2004 09:00 Go to previous message
Originally posted by: mendelgili.netscape.net
Ivan wrote:
> Thanks guy~ :-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48889
Re: How to extend the palette ? [message #591466 is a reply to message #40434] Tue, 08 June 2004 05:25 Go to previous message
Hi Ivan
Joe Winchester
Re: How to extend the palette ? [message #591475 is a reply to message #40496] Tue, 08 June 2004 08:55 Go to previous message
ohh.... thanks~ :-)
> Hi Ivan
> support).
> Best regards,
> Joe Winchester
Re: How to extend the palette ? [message #591501 is a reply to message #40527] Tue, 08 June 2004 12:08 Go to previous message
- Jeff
Ivan wrote:
> ohh.... thanks~ :-)
>> Hi Ivan
>> support).
>> Best regards,
>> Joe Winchester
Re: How to extend the palette ? [message #591509 is a reply to message #40581] Tue, 08 June 2004 22:29 Go to previous message
Thanks guy~ :-)
Thanks guy :-)
> interested :)
> - Jeff
> Ivan wrote:
>> ohh.... thanks~ :-)
>>> Hi Ivan
>>> Best regards,
>>> Joe Winchester
Re: How to extend the palette ? [message #591538 is a reply to message #40610] Wed, 09 June 2004 08:43 Go to previous message
Hi Ivan,
Joe Winchester
Re: How to extend the palette ? [message #591545 is a reply to message #40610] Wed, 09 June 2004 09:00 Go to previous message
Ivan wrote:
> Thanks guy~ :-)
Previous Topic:Java Beans window can't find event.
Next Topic:VE and Eclipse 3.0 RC1
Current Time: Thu Jul 17 13:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.10579 seconds
