Home » Archived » XML Schema Definition (XSD) » getName() returns null too
getName() returns null too [message #40362] Sat, 03 April 2004 12:24 Go to next message
Originally posted by: stibrany.tenax.sk
Hello.
Another "returns null" question :-)
When I call getName() method of XSDElementDeclaration, it gives me null,
although getQName() returns correct answer. How can I get element name
without "...:" prefix?
Thank you.
-Peter Stibrany
Re: getName() returns null too [message #40511 is a reply to message #40362] Mon, 05 April 2004 06:38 Go to previous messageGo to next message
Peter,
An XSDElementDeclaration is used to represent either the actual "abstract"
element declaration or an element declaration reference, in which case all
the properties are null and the getResolveElementDeclaration is needed to
navigate to the actual declaration with all the properties, like name, that
you want to examine. Again, depending on how you traverse the model, you
can avoid seeing element declaration references if you aren't interested in
seeing them.
Peter Stibrany wrote:
> Hello.
> Thank you.
> -Peter Stibrany
Re: getName() returns null too [message #40597 is a reply to message #40511] Mon, 05 April 2004 15:40 Go to previous message
Ed Merks wrote:
> Peter,
> seeing them.
Thank you for answer. I think I am starting to understand this "abstract"
versus "concrete" thing. When I am reading XML Schema specs, they are
mostly talking about "abstract" view of schema, and that is what I really
want. I will more carefully look at XSD methods and double-check before I
post my questions here.
-Peter Stibrany
Re: getName() returns null too [message #585093 is a reply to message #40362] Mon, 05 April 2004 06:38 Go to previous message
Peter,
seeing them.
> Hello.
> Thank you.
> -Peter Stibrany
Re: getName() returns null too [message #585162 is a reply to message #40511] Mon, 05 April 2004 15:40 Go to previous message
Ed Merks wrote:
> Peter,
> seeing them.
-Peter Stibrany
Previous Topic:referenced schema feature/reference
Next Topic:Announcement: FAQ update planned
Current Time: Thu Oct 23 16:09:44 EDT 2025
Powered by FUDForum. Page generated in 0.13545 seconds
