Home » Archived » EPF » Custom Categories and Guidance Type of: Term Definition
Custom Categories and Guidance Type of: Term Definition [message #3463] Sun, 26 February 2006 12:15 Go to next message
Originally posted by: rich.weiskopf.anvi.com
When selecting the 'Add' button on the 'Assign' tab for a custom category,
Guidance of type 'term definition' is not presented for selection. All other
types are. I was attempting to build a Custom category of 'Glossary' for
inclusion in the applet menu.
Re: Custom Categories and Guidance Type of: Term Definition [message #3595 is a reply to message #3463] Mon, 27 February 2006 22:16 Go to previous messageGo to next message
That is by design. Terms were not intended to be 'browsable' pages that you
place into a view, but rather elements that get published into the glossary
page in the published site.
However, you can file a bugzilla and we can consider it as an enhancement.
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Rich Weiskopf" <rich.weiskopf@anvi.com> wrote in message
news:dtsnmg$lbh$1@utils.eclipse.org...
> other types are. I was attempting to build a Custom category of 'Glossary'
> for inclusion in the applet menu.
Re: Custom Categories and Guidance Type of: Term Definition [message #3628 is a reply to message #3595] Tue, 28 February 2006 10:24 Go to previous messageGo to next message
Peter,
Thanks for your reply.
It appears i was trying to re-invent the wheel
Rich
"Peter Haumer" <phaumer@us.ibm.com> wrote in message
news:du0f9h$hne$1@utils.eclipse.org...
> you place into a view, but rather elements that get published into the
> glossary page in the published site.
> Peter Haumer.
> PETER HAUMER
>> category, Guidance of type 'term definition' is not presented for
>> selection. All other types are. I was attempting to build a Custom
>> category of 'Glossary' for inclusion in the applet menu.
Re: Custom Categories and Guidance Type of: Term Definition [message #3725 is a reply to message #3595] Thu, 02 March 2006 13:12 Go to previous message
My apologies, I was wrong. Although the rationale is still correct that we
do not recommend to make terms browsable elements, because people might be
starting putting too much information into the term definition, which might
be better placed into a concept guidance element.
The reason why the term definitions did not show up in the Add Dialog is
because of a bug with the "All" filter. If you switch to the "Guidance"
filter in the filter combo box on the top of the dialog, you see the terms
showing up. I will file a bugzilla to get this fixed.
So again, you can do it, but I recommend against it.
Peter Haumer.
PETER HAUMER
> Peter Haumer.
> PETER HAUMER
Re: Custom Categories and Guidance Type of: Term Definition [message #561663 is a reply to message #3463] Mon, 27 February 2006 22:16 Go to previous message
Peter Haumer.
PETER HAUMER
Re: Custom Categories and Guidance Type of: Term Definition [message #561685 is a reply to message #3595] Tue, 28 February 2006 10:24 Go to previous message
Peter,
Rich
> Peter Haumer.
> PETER HAUMER
Re: Custom Categories and Guidance Type of: Term Definition [message #561742 is a reply to message #3595] Thu, 02 March 2006 13:12 Go to previous message
Peter Haumer.
PETER HAUMER
> Peter Haumer.
> PETER HAUMER
Previous Topic:EPF integration with the development process
Next Topic:Content Development Guidelines
Current Time: Mon Jul 21 21:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.03277 seconds
