Home » Newcomers » Newcomers » JBoss plugin: XDoclet cannot run
JBoss plugin: XDoclet cannot run [message #40232] Fri, 25 March 2005 14:56 Go to next message
Originally posted by: alex.gestalt.com
I am facing a problem that may straddle different newsgroups, so please
bear with me if this is not the right NG.
I am trying to run XDoclet from the JBoss plugin in Eclipse, and when I
add a "sunone" or "weblogic" to the XDoclet configuration, it returns the
following error:
BUILD FAILED: C:\Program
Files\Eclipse3\workspace\EJBChapter6Pricing\xdoclet-build.xm l:36: Can't
create a sunone element under ejbdoclet. Make sure the jar file containing
the corresponding subtask class is on the classpath specified in the
<taskdef> that defined {2}.
Could anyone tell me what JAR I am missing, where to get it from, and how
to add it to the plugin classpath?
Thank you for any help.
Alex Molochnikov
Gestalt Corporation
Re: JBoss plugin: XDoclet cannot run [message #40562 is a reply to message #40232] Fri, 25 March 2005 19:42 Go to previous message
Never mind... I figured it out.
In case someone else runs into the same problem, here is an example for
Sun ONE XDoclet plugin:
1. download XDoclet distribution from their site
2. unpack the zipped file and extract file xdoclet-sun-module-1.2.2.jar
3. copy it into the JBoss plugins directory (e.g.
org.jboss.ide.eclipse.xdoclet.core_1.4.1.e31-jre15)
4. restart Eclipse
Previous Topic:Crash after Upgrading to Eclipse 3.0.2
Next Topic:Switch to Java 1.5
Current Time: Sat Aug 30 22:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.08770 seconds
