Home » Archived » Maven Integration (M2E) » Imported plugin code into eclipse. Compile problem.
Imported plugin code into eclipse. Compile problem. [message #3451] Fri, 25 April 2008 03:21 Go to next message
Originally posted by: eclipsedev.20.geekrunner.spamgourmet.com
I tried importing the project for org.maven.ide.eclipse into eclipse
3.3.1.1 but it's giving me a red flag on NexusIndexManager.java. The line
in question looks like this:
int sourcesExists = artifactInfo.sourcesExists.ordinal();
and the error is:
The type Enum_ is not generic; it cannot be parameterized with
arguments <ArtifactAvailability>.
Any ideas?
Gavin
Re: Imported plugin code into eclipse. Compile problem. [message #3487 is a reply to message #3451] Fri, 25 April 2008 09:43 Go to previous messageGo to next message
Originally posted by: igorfie.yahoo.com
Gavin,
Sounds like you have java 1.5 compatibility enabled for
org.maven.ide.eclipse project. Have you followed these instructions
http://docs.codehaus.org/display/M2ECLIPSE/Configuring+Devel opment+Environment
to setup m2eclipse development emnironment?
> line in question looks like this:
> and the error is:
> Any ideas?
> Gavin
Re: Imported plugin code into eclipse. Compile problem. [message #3520 is a reply to message #3487] Fri, 25 April 2008 10:12 Go to previous message
I've tried to reproduce it and checked out m2eclipse code into clean
Eclipse 3.3.1.1 workspace that doesn't have 1.4 JRE registered but don't
see this compilation error. Would be interesting to figure out what is
going on here.
regards,
Eugene
Igor Fedorenko wrote:
> Gavin,
>> and the error is:
>> Any ideas?
>> Regards,
>> Gavin
Previous Topic:xml-based editor for maven pom
Next Topic:contributing to m2eclipse
Current Time: Tue Jul 08 12:12:52 EDT 2025
Powered by FUDForum. Page generated in 0.04706 seconds
