Home » Eclipse Projects » Remote Application Platform (RAP) » pack() in JavaScript - how?
pack() in JavaScript - how? [message #40135] Mon, 23 July 2007 08:05 Go to next message
Originally posted by: mehow.infogenia.pl
Sorry if this is more like a Qooxdoo question rather than a RAP question.
I'm almost done with my first custom widget (see "Custom widgets" thread
for a screenshot), the only missing part is the functionality to
collapse/expand the widget by changing its height when the toggle button
is clicked.
In SWT I would realize this behaviour by changing computeTrim()
implementation based on the current state (expanded/collapsed) and
calling pack() each time the state is changed*.
This time however I'd like the event to be processed completely on the
client side as there's no need to send it to the server. Do you think
it's possible?
What I'm afraid of is that the layouting is done on the server side and
hence I won't be able to restore the state of the children widgets when
the widget is expanded without calling server-side.
* in fact I would call layout()/pack() on the parent widget, so that it
can use the space freed by the collapsed widget. But it seems to make
things even harder with RAP/Qooxdoo.
Any suggestions would be appreciated,
Michal
Re: pack() in JavaScript - how? [message #40172 is a reply to message #40135] Mon, 23 July 2007 16:31 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Michał,
I am not sure if I entirely understood your question. The "custom
widget" screenshot looks much like the ExpandableComposite/Section that
comes with Eclipse Forms.
If that is what you would like to build, the only option is to do the
layouting on the server side. What you are afraid of would happen, the
client-side does not know how to layout the siblings of your widget.
You could have a look at the Forms widgets and see how they handle
expanding and collapsing. In fact, these parts were copied as-is from
the original implementation.
Rüdiger
Michał Tkacz wrote:
> Hello,
> is clicked.
> it's possible?
> Michal
Re: pack() in JavaScript - how? [message #40301 is a reply to message #40172] Tue, 24 July 2007 04:19 Go to previous message
Rüdiger Herrmann pisze:
> Hi Michał,
Yes, the principle is the same.
Ok, thanks for pointing me to these classes, I forgot to check them.
Michał
> Cheers,
> Rüdiger
> Michał Tkacz wrote:
>> Hello,
>> thread for a screenshot), the only missing part is the functionality
>> to collapse/expand the widget by changing its height when the toggle
>> button is clicked.
>> it's possible?
>> and hence I won't be able to restore the state of the children widgets
>> when the widget is expanded without calling server-side.
>> it can use the space freed by the collapsed widget. But it seems to
>> make things even harder with RAP/Qooxdoo.
>> Michal
Previous Topic:M5 only runs on JDK1.5+ ?
Next Topic:SessionSingletonBase encapsulated
Current Time: Mon May 05 23:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
