Windows 200 Build Invocation with CDT [message #39964] |
Thu, 15 August 2002 10:33  |
Originally posted by: djohn.tandelsys.com
Could someone tell me what I could change the 'Build Invocation'
preference in my C/C++ project to to at least get the program to 'rebuild
all'.
I have Cygwin installed, and have 'cygwin/bin' in the PATH environment
variable, so the command "make" does invoke the 'make' tool. However, how
do I pass the directory of the current project to the 'make' program , from
Eclipse ?
(simply putting 'make' as Build Invocation terminates with make telling
me there is not makefile, as it is probably looking in the home for the
administrator)
make $1 did not work (a complete guess) i tried some other methods, but
couldn't figure it out.
Hope this isn't some kind of incredibly trivial question...
thanks
Re: Windows 200 Build Invocation with CDT [message #39996 is a reply to message #39964] |
Thu, 15 August 2002 16:11   |
Actually i suppose simply typing in the pathname for each project's
Properties>>Build Invocation is fine, but NOW I have another problem:
So it finds and uses 'make' alright, and spits out:
Makefile.am
configure.in
bootstrap.sc
acconfig.h
and some other blank files like "readme" etc.
So then it tries to use
sh -c .bootstrap.sc && sh -c ./configure && sh -c 'touch -m configure'
but can't find the files folder /usr/autotool/devel/bin/aclocal, autoheader
or autoconf
this is because there is no such "usr/autotool" directory in cygwin. Is
automake/autotool a program I can get from somewhere? Does this mean it is
impossible to compile using Windows & Cygwin? I understand that Windows is
currently not formally supported, but if anyone could help it would be
great. I want to at least know if Windows support for Eclipse is in too
early a stage for me to be trying this...
"www.eclipse.org/eclipse.tools (CDT dev)" <djohn@tandelsys.com> wrote in
message news:ajgdnu$kue$1@rogue.oti.com...
> all'.
from
> Eclipse ?
telling
> administrator)
> thanks
Re: Windows 200 Build Invocation with CDT [message #40250 is a reply to message #39996] |
Mon, 19 August 2002 04:28  |
Originally posted by: cknaus.oti.com
In article <ajh1hp$26s$1@rogue.oti.com>,
> Makefile.am
> configure.in
> bootstrap.sc
> acconfig.h
> or autoconf
The latest cygwin ships with autotools (autoconfig, automake, ...).
autotools are used to facilitate porting to different UNIX like platforms.
You can always download them from gnu.org.
-- Claude
FUDForum. Page generated in 0.03890 seconds
