Re: [eclipse.webtools forum] Re: IBM.ZIP file incorrect [message #40147 is a reply to message #40053] |
Sat, 21 August 2004 09:04  |
Originally posted by: leetree1.yahoo.com
Excellent, I see what you mean, thanks a lot for the advise.
/Boris
Dominique De Vito wrote:
>>>Thanks for the info.
>>>OK, corrected.
>>>Dominique
>>>// Eclipse+ObjectWeb
>>>James Mitchell wrote:
>>>>Someone please change the link ("...download the ibm.zip and extract ...")
>>>>on this page:
>>> http://www.eclipse.org/webtools/initial-contribution/IBM/Get ting%20Started.h
>>>>tml
>>>>"ibm.zip" is linked to
>>>> http://www.eclipse.org/webtools/initial-contribution/ibm.zip
>>>>but that just gives a "page not found"
>>>>After googling for ibm.zip, I found this page:
>>>>http://www.eclipse.org/webtools/development/main.html
>>>>which has the same "ibm.zip" link, but this one goes to:
>>> http://download.eclipse.org/webtools/downloads/initial-contr ibutions/ibm.zip
>>>>Notice the extra "downloads" directory.
>>>>James Mitchell
>>>>Software Engineer / Open Source Evangelist
>>>>EdgeTech, Inc.
>>>>678.910.8017
>>>>AIM: jmitchtx
>>Is the ibm.zip abvailable in source form?
> yes. see the different *src.zip into ibm.zip.
>>Or do I need to decompile?
> no
>>Is this checkek into CVS yeet? If so where (what is the CVSROOT) and what
>>is the package?
> See the "getting started" :
> The Content is provided as is for evaluation purposes only. The Content
> can and will most likely change before appearing in the Eclipse CVS
> repository. The APIs and packages will be reworked once the contribution
> is accepted. The code has not been extensively tested and should be
> considered a snapshot in time of ongoing development.
> Dominique
FUDForum. Page generated in 0.04064 seconds
