Home » Modeling » Epsilon » Debugging ETL transformations
Debugging ETL transformations [message #3445] Wed, 12 November 2008 07:00 Go to next message
Originally posted by: szchaler.acm.org
Is there a good way to debug ETL transformations?
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
WWW http://www.steffen-zschaler.de/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Re: Debugging ETL transformations [message #3512 is a reply to message #3445] Wed, 12 November 2008 08:17 Go to previous messageGo to next message
There is no debugger yet I'm afraid, so I guess the only way is to use
plain old println() calls.
Dimitrios
Steffen Zschaler wrote:
> Steffen
Re: Debugging ETL transformations [message #561866 is a reply to message #3445] Wed, 12 November 2008 08:17 Go to previous messageGo to next message
Dimitrios
> Steffen
Re: Debugging ETL transformations [message #876964 is a reply to message #3512] Fri, 25 May 2012 11:53 Go to previous messageGo to next message
I was looking for this post so I thought I'd bump it. Is there any plans on working on a debuger in the Epsilon Roadmap?
Re: Debugging ETL transformations [message #877347 is a reply to message #876964] Sat, 26 May 2012 10:16 Go to previous messageGo to next message
AFAIK, Epsilon got a debugger about a year ago Smile. You should be able to set a breakpoint on any line of EOL code, and it should work as long as you set up an appropriate debug launch configuration.
The debugger still needs quite a bit of work, though. You can't step over operation calls and the frame stack could be a bit cleaner, but it's a good start Smile. Have a look at the Epsilon bug tracker for any pending feature requests.
Re: Debugging ETL transformations [message #878576 is a reply to message #877347] Tue, 29 May 2012 10:50 Go to previous message
Oooops, will definitively take a look and be sure to make some comments.
Previous Topic:Method 'satisfiesOne' not found for ...
Next Topic:[ETL] 'group' keyword
Current Time: Wed Jul 30 08:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.27590 seconds
