Home » Archived » XML Schema Definition (XSD) » First schema loading time
First schema loading time [message #3442] Tue, 22 October 2002 05:42 Go to next message
Originally posted by: wgkang.tagfree.com
Hi.
First schema loding need too long time.
XSDResourceFactoryImpl factory = new XSDResourceFactoryImpl();
Resource resource =
factory.createResource(URI.createFileURI("c://a.xsd"));
XSDResourceImpl xsdresource = (XSDResourceImpl) resource;
Map namespaceMap = new HashMap();
namespaceMap.put("aaa", "http://aaa/aaa");
xsdresource.load(namespaceMap);
The cause of this problem was "xsdresource.load(namespaceMap);" --> last
line
How do I loading a class beforehand? and What class?
Thanks.
-wgkang-
Re: First schema loading time [message #3478 is a reply to message #3442] Tue, 22 October 2002 11:42 Go to previous message
I'm having trouble figuring out what you are asking. Perhaps starting with
the working example that's in org.eclipse.xsd.test would be a good thing.
XSDMainTest.java contains all the details relevant for setting up a
headless or standalone environment and for loading schemas from files/URLs.
wgkang wrote:
> Hi.
> Resource resource =
> line
> Thanks.
> -wgkang-
Ed Merks
Re: First schema loading time [message #563110 is a reply to message #3442] Tue, 22 October 2002 11:42 Go to previous message
wgkang wrote:
> Hi.
> Resource resource =
> line
> Thanks.
> -wgkang-
Ed Merks
Previous Topic:First schema loading time
Next Topic:CVS / Bug-Fixing-Process
Current Time: Sat Jul 26 09:10:17 EDT 2025
Powered by FUDForum. Page generated in 0.31862 seconds
