Home » Archived » EPF » Links from own process diagram to tasks, workproducts, etc
Re: Links from own process diagram to tasks, workproducts, etc [message #39866 is a reply to message #39803] |
Thu, 06 September 2007 11:40   |
I'm copying the response given in epf-dev by Jiang Xuan:
Hi Esti,
I'm not sure I followed your question, do you means you want create
customize diagram in your process? If so, please follow below steps.
1. Create a supporting material in your content package
2. Insert your own process diagram into main description of supporting
material
3. Create a image map link of your process diagram
4. DnD the Task (work product or others elements) to RTE then switch to HTML
tab to get the element link
5. Paste the link as image map link
6. OPen your own process, switch to WBS
7. Right click on your process, select Diagrams->User Defined Diagrams
8. Check the diagram type and click 'Select'
9. Select the supporting material you created just now and click OK
Then do a browse or publish, the user defined diagram will replace the tools
generated one.
Thanks & Regards, Jiang Xuan
"Esti" <esti@danfoss.com> wrote in message
news:096f05b264e481fab6a9d52b60598de0$1@www.eclipse.org...
> --- This message was posted on epf-dev@eclipse.org ----
> Dear EPF community,
> I have my own process diagram and want to upload this diagram onto EPF,
> and create links to tasks, workproducts, etc.
> Is it possible? How do we do it?
> Thanks in advance.
> Best Regards,
> Esti
Re: Links from own process diagram to tasks, workproducts, etc [message #40158 is a reply to message #39866] |
Fri, 07 September 2007 03:40   |
Originally posted by: esti.danfoss.com
> Hi Esti,
> material
> generated one.
>> Dear EPF community,
>> Thanks in advance.
>> Best Regards,
>> Esti
Hi Ricardo and Jiang,
Thanks for the tips.
/Esti
Re: Links from own process diagram to tasks, workproducts, etc [message #582846 is a reply to message #39803] |
Hi Esti,
material
generated one.
> Dear EPF community,
> Thanks in advance.
> Best Regards,
> Esti
Re: Links from own process diagram to tasks, workproducts, etc [message #582990 is a reply to message #39866] |
> Hi Esti,
> material
> generated one.
>> Dear EPF community,
>> Thanks in advance.
>> Best Regards,
>> Esti
/Esti
Current Time: Wed Jun 18 07:33:02 EDT 2025
Powered by FUDForum. Page generated in 0.31221 seconds
