Home » Archived » EPF » HTML import: problem with images
HTML import: problem with images [message #39741] Thu, 06 September 2007 06:34 Go to next message
I'm about to move some MS Word content into MC; I have exported the MS
Word content in (filtred) HTML, copied (Firefox) and pasted to Rich Text
Editor (MC).
However, the <img> tags point to original source location - no image import
has happend.
What is wrong?
I'm using EPF 1.2 release.
Roman
Re: HTML import: problem with images [message #39994 is a reply to message #39741] Thu, 06 September 2007 17:30 Go to previous messageGo to next message
This is supposed to work. Can you paste an example of an <img> link from
Firefox?
What happens if you try pasting directly from Word into the RTE?
Re: HTML import: problem with images [message #40185 is a reply to message #39994] Fri, 07 September 2007 07:42 Go to previous messageGo to next message
Hi Jeff,
if I paste the text directly from word I don't see any <img> tags and
related pictures at all.
If I paste it from firefox I see tags like this:
<p class="MsoBodyText">
<span lang="EN-US"><img height="229"
src=" file:///c:/Documents%20and%20Settings/smirarom/Desktop/How%2 0to%20plan%20iteration_files/image001.jpg"
width="479" /></span>
The location
points to saved images from word rather than ./resource within library.
An observation: if the resource folder (+ images) already exists then it
works (replaces all locations with: ./resource/...)
Roman
"Jeff Hardy" <jefhardy@us.ibm.com> wrote in message
news:5b40ded2f1c568c013de91ffaaa67918$1@www.eclipse.org...
> Firefox?
Re: HTML import: problem with images [message #40531 is a reply to message #40185] Wed, 12 September 2007 20:35 Go to previous messageGo to next message
Can you try to load (in Firefox) the HTML file from a location that does
not contain spaces? Perhaps EPF is not handling those correctly while
pasting.
Re: HTML import: problem with images [message #40618 is a reply to message #40531] Sun, 16 September 2007 10:54 Go to previous message
Hi Jeff,
I did it - I have used a location without spaces and - same result:
<img height="229" src="file:///c:/workbench/iteration_files/image001.jpg"
width="479" />
Roman
news:85794b8a6ba16ff8ba4d11f70448d01c$1@www.eclipse.org...
> pasting.
Re: HTML import: problem with images [message #582914 is a reply to message #39741] Thu, 06 September 2007 17:30 Go to previous message
Firefox?
Re: HTML import: problem with images [message #583003 is a reply to message #39994] Fri, 07 September 2007 07:42 Go to previous message
Hi Jeff,
The location
Roman
> Firefox?
Re: HTML import: problem with images [message #583214 is a reply to message #40185] Wed, 12 September 2007 20:35 Go to previous message
pasting.
Re: HTML import: problem with images [message #583246 is a reply to message #40531] Sun, 16 September 2007 10:54 Go to previous message
Hi Jeff,
width="479" />
Roman
> pasting.
Previous Topic:Roles
Next Topic:EPF and proxy settings
Current Time: Mon Jul 21 21:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.23820 seconds
