VE - creation of element failed [message #39612] |
Mon, 31 May 2004 13:23  |
Originally posted by: sophiean.club-internet.fr
As required, I have installed :
Eclipse-M8
GEF-runtime-I20040330.
emf-runtime-I200403250631.
VE-runtime-1.0M1
Trying to build my first class using VE I got the following message:
"Creation of element failed"
with this error log,
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:313)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 756)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:107)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:606)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:319)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:413)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:769)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2578)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2256)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
at org.eclipse.jface.window.Window.open(Window.java:650)
org.eclipse.jdt.internal.ui.wizards.AbstractOpenWizardAction .run(AbstractOpenWizardAction.java:158)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:550)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:502)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:435)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1562)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1536)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Caused by: java.lang.NullPointerException
org.eclipse.core.internal.runtime.InternalPlatform.asLocalUR L(InternalPlatform.java:184)
at org.eclipse.core.runtime.Platform.asLocalURL(Platform.java:2 52)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.getGeneratorInstance(NewVisualClassCreationWiz ard.java:112)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.applyContributor(NewVisualClassCreationWizard. java:293)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 41)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:100)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:34)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:700)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1559)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3196)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3153)
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:50)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
... 37 more
Could someone help me?
Thanks.
Sophie
Re: Any idea? [message #40230 is a reply to message #40224] |
Sun, 06 June 2004 14:15  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
That's an interesting question. So far we haven't done NLS testing. That
is waiting to be done for the 1.0.0 environment.
But looking at the piece of code that failed, I don't see why the locale
should matter. that area of code doesn't have anything to do with locales.
Thanks, Rich Kulp
Re: Any idea? [message #591239 is a reply to message #39612] |
Fri, 04 June 2004 09:01  |
I need to build an interface this week-end. Could someone help me?
Thanks.
PS: I have also installed jre as required.
Sylvie wrote:
> Hello,
> Eclipse-M8
> VE-runtime-1.0M1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 37 more
> Thanks.
> Sophie
Re: Any idea? [message #591261 is a reply to message #39982] |
Fri, 04 June 2004 10:11  |
I don't know why. We are not getting it in our M1 installations and it
shouldn't be failing here.
However, you don't need to use the new visual wizard. You can use the
standard new class wizard and create your class, and then do Open
with->Visual Editor.
Thanks, Rich Kulp
Re: Any idea? [message #591315 is a reply to message #40044] |
Sat, 05 June 2004 04:13  |
Why do you think it is looking for? A library? Should I import some?
For the moment I'm going to do the way you suggest.
If someone has an explanation do not hesitate, it's rather frustrating!
Thanks.
Sylvie
Re: Any idea? [message #591321 is a reply to message #40217] |
Sat, 05 June 2004 11:12  |
> Thanks.
> Sylvie
Re: Any idea? [message #591330 is a reply to message #40217] |
Sat, 05 June 2004 11:15  |
I have installed eclipse on a an english os and now it works fine.
What can I do to run it on my french os.
Thanks.
Sylvie
> Thanks.
> Sylvie
Re: Any idea? [message #591339 is a reply to message #40224] |
Thanks, Rich Kulp
FUDForum. Page generated in 0.04772 seconds
