retrieving stereotypes [message #39599] |
Mon, 01 October 2007 03:31  |
Originally posted by: firstname.name.gmail.com
I would like to know how to retrieve applied stereotype to a model element in a
OCL way. I know that a element my navigate to a stereotype with the
extension_MyStereotype role, but how to do that if we want to query all
stereotypes. A solution may be to look at all properties starting by
"extension_" but this is a non-navigable association...
thanks.
F. Lagarde
Re: retrieving stereotypes [message #39693 is a reply to message #39599] |
Mon, 01 October 2007 09:43  |
Hi, François,
Generically finding all extensions would require reflection capabilities
that OCL does not offer. To do what you need, you would have to create a
custom Environment implementation that adds some additional operation
implemented in Java using the UML2 API. Of course, you will have to
declare a result type for such an operation, which implies that your
stereotypes all have some common ancestor other than OclAny in order for
this to be useful.
Christian
François Lagarde wrote:
> Hello,
> in a
> thanks.
FUDForum. Page generated in 0.03215 seconds
