Home » Modeling » M2T (model-to-text transformation) » [JET] How can I make scriptlet not occupy a new line in the generated file?
Re: [JET] How can I make scriptlet not occupy a new line in the generated file? [message #39934 is a reply to message #39412] |
Tue, 15 January 2008 10:12   |
JET2 has an algorithm for removing whitespace that it figures might be
unwanted. If you are dealing only with scriptlets and expressions, it comes
down to this:
If the scriptlet starts on a line that is and it is preceded by nothing but
whitespace (blanks, tabs, etc) and ends on a line where it is trailed by
nothing but whitespace, then the JET compiler will remove the preceding
whitespace, the trailing whitespace, and the trailing new-line.
So, the following text in a JET template should have NO effect on the
output:
<% for(int i = 0; i < -1; i++) {%>
nothing
Nor would:
nothing
Put anything before <% or after %>, though, and you would get some text
generated (and a new line).
I have played with more sophisticated rules for stripping whitespace, but
have found that they just create confusion, and, in some cases do not do
what you want.
Paul
"Michael" <my25@macs.hw.ac.uk> wrote in message
news:fmai57$o5c$1@build.eclipse.org...
> As we know, in the JET template file, we will embed many Java
> scriplets. If a scriplet appear as a line in the template file, then, in
> the generated file, a blank line is wlso resulted. I think this is not a
> desired situation. I don't know how to make this happne. Please help me.
> Thanks.
> Michael.
Re: [JET] How can I make scriptlet not occupy a new line in the generated file? [message #40330 is a reply to message #39934] |
Fri, 18 January 2008 09:26   |
Thanks for your help.
Thanks for your ruels. I also found this rule doesn't work sometimes. I
am wandering whether this is a bug of GET.
I hope it would be solved as soon as possible.
Cheers.
Michael.
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:fmiiis$49t$1@build.eclipse.org...
> comes down to this:
> but whitespace (blanks, tabs, etc) and ends on a line where it is trailed
> by nothing but whitespace, then the JET compiler will remove the preceding
> output:
> nothing
> Nor would:
> nothing
> what you want.
> Paul
>> Thanks.
>> Michael.
Re: [JET] How can I make scriptlet not occupy a new line in the generated file? [message #40450 is a reply to message #40330] |
Mon, 21 January 2008 11:04  |
Michael:
Best way to get a problem fixed is to submit a bugzilla, and attach specific
instructions on how to reproduce (or attaching actual problem templates).
Here's the link to submit a bug:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&priority=P3&bu g_severity=normal&bug_status=NEW&form_name=enter_bug &assigned_to=m2t.jet-inbox%40eclipse.org
Paul
news:fmqcuc$orj$1@build.eclipse.org...
> Cheers.
> Michael.
>> comes down to this:
>> preceding whitespace, the trailing whitespace, and the trailing new-line.
>> output:
>> nothing
>> Nor would:
>> nothing
>> what you want.
>> Paul
>>> Hi,
>>> Thanks.
>>> Michael.
Current Time: Fri Aug 08 02:08:14 EDT 2025
Powered by FUDForum. Page generated in 0.15663 seconds
