Home » Archived » Albireo » CTRL-C stack overflow
CTRL-C stack overflow [message #3404] Wed, 10 October 2007 13:35 Go to next message
Originally posted by: canadianguy.gmail.com
I have noticed an interesting problem when you are using a Swing editor.
In a text field in the editor, hit CTRL-C. Open another editor. Watch the
stack overflow errors pile up.
Exception in thread "AWT-EventQueue-0" java.lang.StackOverflowError
at java.util.Arrays.mergeSort(Arrays.java:1270)
at java.util.Arrays.sort(Arrays.java:1210)
at java.util.Collections.sort(Collections.java:159)
javax.swing.SortingFocusTraversalPolicy.enumerateAndSortCycl e(SortingFocusTr
aversalPolicy.java:119)
javax.swing.SortingFocusTraversalPolicy.getFirstComponent(So rtingFocusTraver
salPolicy.java:434)
javax.swing.LayoutFocusTraversalPolicy.getFirstComponent(Lay outFocusTraversa
lPolicy.java:148)
javax.swing.DefaultFocusManager.getFirstComponent(DefaultFoc usManager.java:9
9)
javax.swing.LegacyGlueFocusTraversalPolicy.getFirstComponent (LegacyGlueFocus
TraversalPolicy.java:115)
javax.swing.LegacyGlueFocusTraversalPolicy.getDefaultCompone nt(LegacyGlueFoc
usTraversalPolicy.java:133)
salPolicy.java:447)
I was able to fix this by moving the focus policy from the frame down to the
JApplet. I notice your article code says to 'consider' this in its
comments, is there any reason why you didn't do it?
-James
Modified code (inside addRootPaneContainer):
JApplet applet = new JApplet();
// In JRE 1.4, the JApplet makes itself a focus cycle root. This
// interferes with the focus handling installed on the parent frame,
so
// change it back to a non-root here.
// TODO: consider moving the focus policy from the Frame down to the
JApplet
EmbeddedChildFocusTraversalPolicy policy = new
EmbeddedChildFocusTraversalPolicy(awtHandler);
applet.setFocusTraversalPolicy(policy);
frame.add(applet);
return applet;
Re: CTRL-C stack overflow [message #3437 is a reply to message #3404] Wed, 10 October 2007 14:04 Go to previous messageGo to next message
The choice of JApplet was made rather late, relative to the article's
release. I wanted to think it through before making the change. In
particular, if the AWT frame gets focus, will it always delegate to the
JApplet's focus policy?
If you are running in JDK 1.5+, I believe you could have also solved the
problem by calling setFocusTraversalPolicyProvider(false) on the
JApplet, leaving the focus traversal policy on the frame. This call is
now necessary to truly turn off the JApplet's own default focus
handling. This is a new API in 1.5. My testing was largely with JDK 1.4
at the time, so this call was not necessary and not available.
> at
> at
> salPolicy.java:434)
> at
> lPolicy.java:148)
> at
> 9)
> at
> at
> at
> salPolicy.java:447)
> -James
> so
> JApplet
> frame.add(applet);
> return applet;
Re: CTRL-C stack overflow [message #6708 is a reply to message #3404] Wed, 02 April 2008 16:33 Go to previous messageGo to next message
Hey all,
It's been a while. I am still using my modified version of the original
article code. I was wondering if anyone has experienced problems with
ctrl+x crashing the VM. It seems to be unrelated to the ctrl+c problem I
had before.
Anyone? Anyone?
-James
"James Peltzer" <canadianguy@gmail.com> wrote in message
news:fej2em$2oi$1@build.eclipse.org...
the
> at
> at
> salPolicy.java:434)
> at
> lPolicy.java:148)
> at
> 9)
> at
> at
> at
> salPolicy.java:447)
the
> -James
frame,
> so
the
> JApplet
> frame.add(applet);
> return applet;
Re: CTRL-C stack overflow [message #6715 is a reply to message #6708] Thu, 03 April 2008 08:24 Go to previous message
Never mind. As it turns out, it was an ID-10-T error.
The original RCP application I built on top of had an accelerator set for
'ctrl+x' to shutdown the application. This was never removed and sat around
for a year before I noticed it.
Sorry to waste anyone's time.
-James
news:ft0qlu$f2o$1@build.eclipse.org...
> Hey all,
> had before.
> Anyone? Anyone?
> -James
> the
> > at
> > at
> > salPolicy.java:434)
> > at
> > lPolicy.java:148)
> > at
> > 9)
> > at
> > at
> > at
> > salPolicy.java:447)
> the
> > -James
> frame,
> > so
> the
> > JApplet
> > frame.add(applet);
> > return applet;
Re: CTRL-C stack overflow [message #572952 is a reply to message #3404] Wed, 10 October 2007 14:04 Go to previous message
> at
> at
> salPolicy.java:434)
> at
> lPolicy.java:148)
> at
> 9)
> at
> at
> at
> salPolicy.java:447)
> -James
> so
> JApplet
> frame.add(applet);
> return applet;
Re: CTRL-C stack overflow [message #573770 is a reply to message #3404] Wed, 02 April 2008 16:33 Go to previous message
Hey all,
had before.
Anyone? Anyone?
-James
the
> at
> at
> salPolicy.java:434)
> at
> lPolicy.java:148)
> at
> 9)
> at
> at
> at
> salPolicy.java:447)
the
> -James
frame,
> so
the
> JApplet
> frame.add(applet);
> return applet;
Re: CTRL-C stack overflow [message #573829 is a reply to message #6708] Thu, 03 April 2008 08:24 Go to previous message
-James
> Hey all,
> had before.
> Anyone? Anyone?
> -James
> the
> > at
> > at
> > salPolicy.java:434)
> > at
> > lPolicy.java:148)
> > at
> > 9)
> > at
> > at
> > at
> > salPolicy.java:447)
> the
> > -James
> frame,
> > so
> the
> > JApplet
> > frame.add(applet);
> > return applet;
Previous Topic:EclipseCon 2008
Next Topic:Albireo alpha available
Current Time: Tue Jul 22 08:28:32 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
