Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build (Ant) Mucking With Bundle MANIFEST.MF
| PDE Build (Ant) Mucking With Bundle MANIFEST.MF [message #39314] |
Wed, 07 January 2009 16:35  |
I am integrating my plugin builds into a continuous integration type
system. I've noticed that the difference between the bundle JARs produced
with my new build system and those produced by my old, monolithic PDE
build is that the new JARs have had their bundle manifests molested at
some point by Ant. They now contain the following lines:
Ant-Version: Apache Ant 1.7.0
Created-By: 1.5.0_06-b05 (Sun Microsystems Inc.)
First off, I'd like to know why this is happening now and it never has
before. The generated build.xml files that PDE build is using look the
same (the call to the Ant <jar ..> task is identical). Does anyone know
what prevents this from happening in a normal PDE build, or what may
trigger it to happen in general?
Second, are these lines going to screw up my bundle? I don't think they
are, but I would like to prevent them from appearing anyway.
Thanks in advance,
Mark.
| Re: PDE Build (Ant) Mucking With Bundle MANIFEST.MF [message #39593 is a reply to message #39314] |
Thu, 08 January 2009 16:36   |
<sigh>
Well it took me almost two days of wading through PDE build scripts and
logs but I found the root cause of this issue. If you try to execute
targets directly from the generated build.xml file (which I must do for
continuous integration purposes), you get different results than the full
PDE build would produce. This is because the full, feature-based PDE
build uses *other* generated assembly files that happen to do things
slightly different. For example, the "build.update.jar" target in a
generated build.xml for a given bundle looks like this:
<target name="build.update.jar" depends="init" description="Build the
plug-in: my.plugin.id for an update site.">
<delete dir="${temp.folder}"/>
<mkdir dir="${temp.folder}"/>
<antcall target="build.jars"/>
<antcall target="gather.bin.parts">
<param name="destination.temp.folder" value="${temp.folder}/"/>
</antcall>
<jar destfile="${plugin.destination}/my.plugin.id_1.0.0.HEAD.jar "
basedir="${temp.folder}/my.plugin.id_1.0.0.HEAD" filesetmanifest="merge"/>
</target>
However, if you look at the mess of generated assembly scripts in the
top-level PDE build directory and examine the one that *actually* builds
the plugin's update JAR in a full-fledged PDE build scenario, you will
find the following targets:
<target name="jarUp" description="Create a jar from the given location.">
<available property="${source}/${elementName}_exists"
file="${source}/${elementName}"/>
<available property="jaringManifest"
file="${source}/${elementName}/META-INF/MANIFEST.MF"/>
<condition property="jaringTask" value="jarIng"
else="jarIng_NoManifest" >
<isset property="jaringManifest"/>
</condition>
<antcall target="${jaringTask}">
<param name="source" value="${source}"/>
<param name="elementName" value="${elementName}"/>
</antcall>
</target>
<target name="jarIng" if="${source}/${elementName}_exists">
<jar destfile="${source}/${elementName}.jar"
basedir="${source}/${elementName}"
manifest="${source}/${elementName}/META-INF/MANIFEST.MF"
filesetmanifest="skip"/>
<delete dir="${source}/${elementName}"/>
</target>
<target name="jarIng_NoManifest" if="${source}/${elementName}_exists">
basedir="${source}/${elementName}" filesetmanifest="merge"/>
</target>
The "main" target in the assembly script only uses the "gather.bin.parts"
target from the the bundle's generated build.xml, and then proceeds to
call this specially-generated "jarUp" target, which contains a special
case for a bundle that contains a manifest file, calling the Ant <jar ..>
task in a different way. Interesting. Looks like I am off to Bugzilla.
The generated build.xml should contain similar logic in my opinion. There
are lots of cases where people will want to use the targets in a generated
build.xml directly, and there isn't a easy way around this problem for my
particular situation that I can see.
So back to my original question then: Do the extra, crufty lines that Ant
sticks into my MANIFEST.MF files screw up anything related to OSGi bundles?
Mark.
On Wed, 07 Jan 2009 16:35:16 -0500, Mark Melvin <mark.melvin@onsemi.com>
wrote:
> produced with my new build system and those produced by my old,
> monolithic PDE build is that the new JARs have had their bundle
> manifests molested at some point by Ant. They now contain the following
> lines:
> Thanks in advance,
> Mark.
| Re: PDE Build (Ant) Mucking With Bundle MANIFEST.MF [message #39684 is a reply to message #39593] |
Fri, 09 January 2009 09:49   |
If you file any bug reports, please post them links here so we can
follow them.
On 1/8/2009 4:36 PM, Mark Melvin wrote:
> <sigh>
> full PDE build would produce. This is because the full, feature-based
> PDE build uses *other* generated assembly files that happen to do things
> </antcall>
> </target>
> <condition property="jaringTask" value="jarIng" else="jarIng_NoManifest" >
> </condition>
> </antcall>
> </target>
> </target>
> </target>
> "gather.bin.parts" target from the the bundle's generated build.xml, and
> then proceeds to call this specially-generated "jarUp" target, which
> contains a special case for a bundle that contains a manifest file,
> calling the Ant <jar ..> task in a different way. Interesting. Looks
> like I am off to Bugzilla. The generated build.xml should contain
> similar logic in my opinion. There are lots of cases where people will
> want to use the targets in a generated build.xml directly, and there
> isn't a easy way around this problem for my particular situation that I
> can see.
> Ant sticks into my MANIFEST.MF files screw up anything related to OSGi
> bundles?
> Mark.
> wrote:
>> following lines:
>> know what prevents this from happening in a normal PDE build, or what
>> may trigger it to happen in general?
>> they are, but I would like to prevent them from appearing anyway.
>> Thanks in advance,
>> Mark.
| Re: PDE Build (Ant) Mucking With Bundle MANIFEST.MF [message #587953 is a reply to message #39314] |
<sigh>
</antcall>
</target>
</condition>
</antcall>
</target>
</target>
</target>
Mark.
wrote:
> lines:
> Thanks in advance,
> Mark.
| Re: PDE Build (Ant) Mucking With Bundle MANIFEST.MF [message #587986 is a reply to message #39593] |
follow them.
> <sigh>
> </antcall>
> </target>
> </condition>
> </antcall>
> </target>
> </target>
> </target>
> can see.
> bundles?
> Mark.
> wrote:
>> following lines:
>> Thanks in advance,
>> Mark.
Current Time: Tue Nov 11 12:08:19 EST 2025
Powered by FUDForum. Page generated in 0.05355 seconds
