Home » Archived » XML Schema Definition (XSD) » XSDSchema document question
XSDSchema document question [message #39290] Tue, 23 March 2004 08:25 Go to next message
What is the optional Document property on an XSDSchema element intended to
be used for? I have some optional name value pair user defined properties
I'm looking for a home for and this seems like a logical place.
thanks,
Lance Phillips
Re: XSDSchema document question [message #39321 is a reply to message #39290] Tue, 23 March 2004 09:11 Go to previous messageGo to next message
Lance,
This is the DOM Document of the schema. You can't reuse this. You should use
annotations for additional data.
> thanks,
> Lance Phillips
Re: XSDSchema document question [message #39352 is a reply to message #39321] Tue, 23 March 2004 09:41 Go to previous messageGo to next message
Ed,
How do I add an annotation directly to the Schema? I only see
mechanisms for adding annotations directly to schema components. The
getAnnotations method on Schema is an infoset property, so adding to it has
no effect.
thansk,
Lance
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:40604598.B1362C30@ca.ibm.com...
> Lance,
use
to
properties
> > thanks,
> > Lance Phillips
Re: XSDSchema document question [message #39383 is a reply to message #39352] Tue, 23 March 2004 09:43 Go to previous messageGo to next message
Lance,
Add to XSDSchema.getContents().
> Ed,
> no effect.
> thansk,
> Lance
> > Lance,
> use
> to
> properties
> > > thanks,
> > > Lance Phillips
Re: XSDSchema document question [message #39414 is a reply to message #39383] Tue, 23 March 2004 09:51 Go to previous message
Wow... what a brain cramp... sorry Ed! Please don't think I'm stupid ;)
lp
news:40604D1F.9CD0D61F@ca.ibm.com...
> Lance,
> > Ed,
has
> > no effect.
> > thansk,
> > Lance
> > > Lance,
should
> > use
intended
> > to
> > properties
> > > > thanks,
> > > > Lance Phillips
Re: XSDSchema document question [message #584426 is a reply to message #39290] Tue, 23 March 2004 09:11 Go to previous message
Lance,
> thanks,
> Lance Phillips
Re: XSDSchema document question [message #584445 is a reply to message #39321] Tue, 23 March 2004 09:41 Go to previous message
Ed,
no effect.
thansk,
Lance
> Lance,
use
to
properties
> > thanks,
> > Lance Phillips
Re: XSDSchema document question [message #584460 is a reply to message #39352] Tue, 23 March 2004 09:43 Go to previous message
Lance,
> Ed,
> no effect.
> thansk,
> Lance
> > Lance,
> use
> to
> properties
> > > thanks,
> > > Lance Phillips
Re: XSDSchema document question [message #584472 is a reply to message #39383] Tue, 23 March 2004 09:51 Go to previous message
lp
> Lance,
> > Ed,
has
> > no effect.
> > thansk,
> > Lance
> > > Lance,
should
> > use
intended
> > to
> > properties
> > > > thanks,
> > > > Lance Phillips
Previous Topic:XSDSchema document question
Next Topic:redefine
Current Time: Mon Jul 21 21:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.06118 seconds
