Home » Eclipse Projects » Plugin Development Environment (PDE) » Name of Active project
Name of Active project [message #3402] |
Mon, 19 May 2008 18:16  |
Originally posted by: cschilli.rumms.uni-mannheim.de
I am currently expanding an EMF generated Editor Plugin.
I run some tests on resources, which were created with the
editor and stored in a project.
Now want to retrieve the current active project, so that
i can analyze resources from arbitrary projects.
I use the following code to obtain the name of the current resource
IEditorPart editor = HandlerUtil.getActiveEditor(event);
String plmInstanceFileName = editor.getEditorInput().getName();
But to create the whole URI for my Resource Loader i need the
the current project name too.
"platform:/resource/" + currentActiveProjectName + "/" +
plmInstanceFileName
Can somebody tell me, how I can retrieve the project name ?
Thanks and regards
Christian
Re: Name of Active project [message #3602 is a reply to message #3570] |
Wed, 21 May 2008 09:51   |
Christian wrote:
> Eric Rizzo schrieb:
>> Christian wrote:
>>> Hi,
>> What exactly do you mean by the "active" project?
>> Eric
> The project to which the Resource belongs, which is currently
> open with the "activeEditor".
> I allready have an IEditorInput Object, but did not know, how to
> get the full resource URI, of the resouce, whicht is currently
> opened.
If you are certain that the input is a file, you can cast it to a
FileEditorInput and then call getFile().getProject() to get the IProject
that contains it.
Hope this helps,
Eric
Re: Name of Active project [message #3667 is a reply to message #3602] |
Fri, 23 May 2008 10:03  |
Eric Rizzo schrieb:
> Christian wrote:
>> Eric Rizzo schrieb:
>>> Christian wrote:
>>>> Hi,
>>> Eric
>> opened.
> that contains it.
> Hope this helps,
> Eric
Hi Eric,
that was exactly what i was looking for !
Many thanks
Christian
Re: Name of Active project [message #567067 is a reply to message #3402] |
Tue, 20 May 2008 11:21  |
Christian wrote:
Eric
Re: Name of Active project [message #567100 is a reply to message #3538] |
Tue, 20 May 2008 13:24  |
Eric Rizzo schrieb:
> Christian wrote:
> Eric
opened.
I hope that i am properly describing my problem.
Christian
Re: Name of Active project [message #567129 is a reply to message #3570] |
Christian wrote:
> Eric Rizzo schrieb:
>> Christian wrote:
>>> Hi,
>> Eric
> opened.
that contains it.
Hope this helps,
Eric
Re: Name of Active project [message #567178 is a reply to message #3602] |
Eric Rizzo schrieb:
> Christian wrote:
>> Eric Rizzo schrieb:
>>> Christian wrote:
>>>> Hi,
>>> Eric
>> opened.
> that contains it.
> Hope this helps,
> Eric
Hi Eric,
Many thanks
Christian
Current Time: Sun Aug 31 21:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.04668 seconds
