Home » Eclipse Projects » Subversive » Repository Structure
Repository Structure [message #39270] Mon, 15 December 2008 05:13 Go to next message
In the newer versions of Subversive we got problems regarding the
repository structure that is not any more supported correctly.
Our structure on the repository is as follows:
/trunk
/branches
/tags
/components/component1/trunk
/components/component1/branches
/components/component1/tags
The problem occurs, when I go to "SVN Repositories" and navigate to
component1. In older versions I could then choose New->Tag.. and the tags
was created in /components/component1/tags. In the new versions it is
created in /tags.
Is this a bug or can I change a setting?
Re: Repository Structure [message #39553 is a reply to message #39270] Wed, 17 December 2008 08:11 Go to previous messageGo to next message
Hello Pete,
We didn't change the behaviour relative to repository structure, so you
should have tags created in /components/component1/tags.
Could you please tell what exact version of Subversive do you use?
Do you have an enabled "Respect project structure" option at
Windows/Preferences/Team/SVN in Repository tab.
> /trunk
> /branches
> /tags
> created in /tags.
Re: Repository Structure [message #39646 is a reply to message #39553] Thu, 18 December 2008 11:27 Go to previous messageGo to next message
Hello Igor
Thank you for your help.
The version of subversive is 0.7.5.I20081029-1900 with connector "Native
JavaHL (svn:1.4.5 (r25188) jni:0.9.0)" and eclipse "3.3.2 Build id:
M20080221-1800". Yes, we have enabled "Respect project structure" in the
preferences.
Re: Repository Structure [message #39707 is a reply to message #39646] Tue, 23 December 2008 10:55 Go to previous messageGo to next message
Hello Pete,
It could be a bug, so could you please provide additional information?
I'm interested in your exact repository structure, especially .project files
(it's important), and on which folder you called the action. Probably it
would be better to make a screenshot of you repository which includes your
'components' folder (this is from your example) with all expanded
sub-folders and root folder with trunk/branches/tags.
It would be great if you can provide an url to your repository (of course if
it's possible) and I can test it.
> Hello Igor
> preferences.
Re: Repository Structure [message #40941 is a reply to message #39707] Thu, 05 February 2009 02:11 Go to previous messageGo to next message
Hello Igor
Thank you for the response. I got a new, empty repository and tried to
reproduce the problem with a simple structure similar to the complex one
(many components and code) we use. But I was not able to reproduce it
there.
We have no .project files in the repository as they are generated by the
build system. Could this be a problem in this case?
I called the action "New->Tag..." in the view "SVN Repository Exploring
perspective" in "SVN Repositories" on the component-folder.
Could you give me your email-address in order that I can send you
screenshots?
Unfortunately, it is not possible to give you access to our repository, I
checked this.
Kind Regards
Pete
Igor Burilo wrote:
> Hello Pete,
>> Hello Igor
>> preferences.
Re: Repository Structure [message #41093 is a reply to message #40941] Thu, 05 February 2009 09:28 Go to previous messageGo to next message
Hello Pete,
As I remember we fixed the similar problem, please, update to latest version
and try again.
My email: igor.burilo@polarion.org
> Hello Igor
> there.
> screenshots?
> checked this.
> Kind Regards
> Pete
> Igor Burilo wrote:
>> Hello Pete,
>> files (it's important), and on which folder you called the action.
>> Probably it would be better to make a screenshot of you repository which
>> includes your 'components' folder (this is from your example) with all
>> expanded sub-folders and root folder with trunk/branches/tags.
>> if it's possible) and I can test it.
>>> Hello Igor
>>> preferences.
Re: Repository Structure [message #41122 is a reply to message #40941] Thu, 05 February 2009 09:47 Go to previous messageGo to next message
Hi Pete and Igor:
> screenshots?
You should use http://www.imageshack.us/ for upload pictures and paste here link, because
many peoples are interesting for this and many users regularly read this newsgroup
So can you add link to the picture ? i want to see it too
thank you
Re: Repository Structure [message #41392 is a reply to message #41093] Mon, 09 February 2009 02:06 Go to previous message
Hello Igor and snop3
Thanks you for this hint, I installed the new version and did not any more
experience the problem. It is still under test now and I hope the problem
is not reproducible.
Thanks for the email-address, I send you screenshots only if the problem
occurs again.
Kind regards
Pete
Igor Burilo wrote:
> Hello Pete,
> and try again.
>> Hello Igor
>> there.
>> screenshots?
>> checked this.
>> Kind Regards
>> Pete
>> Igor Burilo wrote:
>>> Hello Pete,
>>>> Hello Igor
>>>> preferences.
Previous Topic:Assign hotkeys for Team>Commit/Update
Next Topic:Subversive weekly builds vs. latest release
Current Time: Sat Jul 26 05:10:11 EDT 2025
Powered by FUDForum. Page generated in 0.07416 seconds
