Home » Archived » OHF » Document instance returned from retrieveDocumentSet() has incomplete data
Document instance returned from retrieveDocumentSet() has incomplete data [message #39248] Thu, 27 December 2007 06:10 Go to next message
Hi folks!
I'm having an issue fetching a CDAR2 document from the public NIST
repository. I'm calling the retrieveDocumentSet() XDS.b transaction on the
B_Consumer class. In the list of documents returned, The
Document.getDocumentData() byte array does not return me the entire
content even with the latest IHE components. This is causing my XSL
transformations to fail as the XML is malformed.
The uniqueId of the document is
"1.2.3.4.100000022002209036.1196211173506.1" and the repository unique ID
is "1.19.6.24.109.42.1"
(http://129.6.24.109:9080/axis2/services/xdsrepositoryb).
Anyone experiencing a similar issue? Any help would be appreciated.
Thanks guys.
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39279 is a reply to message #39248] Thu, 27 December 2007 10:14 Go to previous messageGo to next message
Hi Sudemh,
Interesting... I was able to retrieve the full document with no
problems. Is there an error being thrown in the retrieve, such as a
timeout, or something?
-Matt
Sumedh wrote:
> Hi folks!
> the B_Consumer class. In the list of documents returned, The
> ID is "1.19.6.24.109.42.1"
> Thanks guys.
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39310 is a reply to message #39279] Thu, 27 December 2007 11:58 Go to previous messageGo to next message
Hey Matt,
Nope, no exceptions/errors whatsoever in the Console. The status comes
back as a 'Success'. Even the public ATNA syslogs look good. The byte
array is just not complete for that document.
If its of any help, my document consumer is on a Windows XP box with Java
1.6.0_03 and using the IHE components as of Dec 19th.
Any ideas?
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39341 is a reply to message #39310] Thu, 27 December 2007 16:57 Go to previous messageGo to next message
Hmmm, weird. Ok, here's a couple thoughts/ideas:
1) We haven't tested OHF with Java 6 at all - it is "unsupported".
However, I can't imagine what you're describing being caused by Java 6
(we've seen other errors, but not incomplete buffers). If you have a
Java 5 JRE sitting around, if you could try it there and see what
happens, that may fix it immediately and we'll have to look at Java 6
support shortly.
2) Could you look at the length of the byte array and let us know how
much is being received. The length I'm seeing is 9570 (trying to
determine if there is some buffering issue, showing a cutoff at 1024
bytes or something).
-Matt
Sumedh wrote:
> Hey Matt,
> Java 1.6.0_03 and using the IHE components as of Dec 19th.
> Any ideas?
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39371 is a reply to message #39341] Fri, 28 December 2007 00:54 Go to previous messageGo to next message
Thanks.
1) It seems to be like some sort of buffering issue to me although I'll
try with JRE 5 and let you know. Also as a side note, I'm using emf-2.3.0
as a dependency as well (not sure if that comes into the picture here
somehow).
2) I consistently get back 5688 bytes from document.getDocumentData() in
my JUnit testcase. Following is a snippet of the same.
<code>
B_Consumer consumer = new B_Consumer(registryURI, null, xdsRepositoryMap);
RetrieveDocumentSetRequestType retrieveDocumentSetRequest =
RetrieveFactory.eINSTANCE.createRetrieveDocumentSetRequestTy pe();
DocumentRequestType documentRequest =
RetrieveFactory.eINSTANCE.createDocumentRequestType();
documentRequest.setRepositoryUniqueId("1.19.6.24.109.42.1");
documentRequest.setDocumentUniqueId("1.2.3.4.100000022002209036.1196211173506.1 ");
retrieveDocumentSetRequest.getDocumentRequest().add(document Request);
List<Document> documents = new ArrayList<Document>();
XDSResponseType response =
consumer.retrieveDocumentSet(retrieveDocumentSetRequest, documents,
fetchDefaultPatientCX());
</code>
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39402 is a reply to message #39371] Sat, 29 December 2007 01:50 Go to previous messageGo to next message
hmm...So this goes away if I switch to JDK 5 and add Stax 1.2 as a
dependency.
This looks to be a bug for JDK 6 though, not sure who I should log it for
though :/
Thanks for all the help Matt.
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39433 is a reply to message #39402] Sat, 29 December 2007 13:27 Go to previous messageGo to next message
Thanks for the update... please add it as a bug for XDS Consumer. I
can't guarantee we'll get it working immediately, unless it's a critical
issue for you.
-Matt
> dependency.
> for though :/
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39464 is a reply to message #39433] Thu, 03 January 2008 02:17 Go to previous messageGo to next message
Logged this for xds.consumer:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214023
I would really appreciate if this were fixed before Connectathon though.
Thanks.
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39495 is a reply to message #39464] Thu, 03 January 2008 11:28 Go to previous messageGo to next message
Thanks - have you been having any other problems with OHF when using
Java 6? We knew at one point that some problems existed. If this is
the only issue you're experiencing hopefully we can get it fixed before
Connectathon.
-Matt
> Thanks.
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39558 is a reply to message #39495] Thu, 03 January 2008 13:56 Go to previous messageGo to next message
There's another one that I've found but I'll open another thread for it.
Not sure if its something just on Java 6 though (shouldn't be).
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39589 is a reply to message #39558] Thu, 03 January 2008 14:11 Go to previous messageGo to next message
Sumedh,
I ran the XDS.b Retrieve Document Set tests on the same ID in Java 6
(1.6.0_03) and received the full document back - on both the MTOM and
the MTOM+XOP repository endpoints. If possible, could you please post a
full OHF log of the transaction so I can try and find out where the
problem is happening.
-Matt
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39711 is a reply to message #39589] Fri, 04 January 2008 02:42 Go to previous messageGo to next message
Here you go:
DEBUG - Begin Document Retrieve.
WARN - Defaulting to IP Address for AuditSourceID. This should be set by
calling setAuditSourceId.
DEBUG - Starting Audit start messages [1]
DEBUG - Sending ActorStartStopMessage Audit message.
INFO - <13>Jan 4 02:25:03 machine1 <?xml version="1.0"
encoding="ASCII"?><AuditMessage
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="healthcare-security-audit.xsd ">
<EventIdentification EventActionCode="E"
EventDateTime="2008-01-04T02:25:03.312-05:00" EventOutcomeIndicator="0">
<EventID code="110100" codeSystemName="DCM" displayName="Application
Activity"/>
<EventTypeCode code="110120" codeSystemName="DCM" displayName="Application
Start"/>
</EventIdentification>
<ActiveParticipant UserID="OHF_XDS_B_CONSUMER" UserIsRequestor="false">
<RoleIDCode code="110150" codeSystemName="DCM" displayName="Application"/>
</ActiveParticipant>
<ActiveParticipant UserID="XdsTester" UserIsRequestor="true">
<RoleIDCode code="110151" codeSystemName="DCM" displayName="Application
Launcher"/>
<AuditSourceIdentification AuditSourceID="192.168.1.100"/>
</AuditMessage>
DEBUG - sending 1 document requests to:
log4j:WARN No appenders could be found for logger
(org.apache.axis2.util.Loader).
log4j:WARN Please initialize the log4j system properly.
DEBUG - Beginning XDS SOAP Send
DEBUG - ****** SOAP REQUEST BODY ******
DEBUG - <retrieve:RetrieveDocumentSetRequest
xmlns:retrieve="urn:ihe:iti:xds-b:2007"><retrieve:DocumentRequest ><retrieve:RepositoryUniqueId>1.19.6.24.109.42.1</retrieve:RepositoryUniqueId ><retrieve:DocumentUniqueId>1.2.3.4.100000022002209036.1196211173506.1 </retrieve:DocumentUniqueId></retrieve:DocumentRequest></retrieve:RetrieveDocumentSetRequest >
DEBUG - ********************************
DEBUG - SOAP Envelope Set
DEBUG - Initializing ATNA ConfigurationManager
DEBUG - Received SOAP Response
DEBUG - ****** SOAP RESPONSE BODY ******
DEBUG - <xdsb:RetrieveDocumentSetResponse
xmlns:xdsb="urn:ihe:iti:xds-b:2007"><rs:RegistryResponse
xmlns:rs="urn:oasis:names:tc:ebxml-regrep:xsd:rs:3.0"
status="urn:oasis:names:tc:ebxml-regrep:ResponseStatusType:Success "></rs:RegistryResponse><xdsb:DocumentResponse><xdsb:Document > PCEtLSANCi8qKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqDQog KiBDb3B5cmlnaHQgKGMpIDIwMDYgSUJNIENvcnBvcmF0aW9uIGFuZCBvdGhl cnMuDQogKiBBbGwgcmlnaHRzIHJlc2VydmVkLiBUaGlzIHByb2dyYW0gYW5k IHRoZSBhY2NvbXBhbnlpbmcgbWF0ZXJpYWxzDQogKiBhcmUgbWFkZSBhdmFp bGFibGUgdW5kZXIgdGhlIHRlcm1zIG9mIHRoZSBFY2xpcHNlIFB1YmxpYyBM aWNlbnNlIHYxLjANCiAqIHdoaWNoIGFjY29tcGFuaWVzIHRoaXMgZGlzdHJp YnV0aW9uLCBhbmQgaXMgYXZhaWxhYmxlIGF0DQogKiBodHRwOi8vd3d3LmVj bGlwc2Uub3JnL2xlZ2FsL2VwbC12MTAuaHRtbA0KICoNCiAqIENvbnRyaWJ1 dG9yczoNCiAqICAgICBJQk0gQ29ycG9yYXRpb24gLSBpbml0aWFsIEFQSSBh bmQgaW1wbGVtZW50YXRpb24NCiAqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioqLw0KIC0tPg0KIDxDbGluaWNhbERvY3VtZW50IHhtbG5zPSJ1 cm46aGw3LW9yZzp2MyIgIHhtbG5zOnhzaT0iaHR0cDovL3d3dy53My5vcmcv MjAwMS9YTUxTY2hlbWEtaW5zdGFuY2UiIGNsYXNzQ29kZT0iRE9DQ0xJTiIg bW9vZENvZGU9IkVWTiIgeHNpOnNjaGVtYUxvY2F0aW9uPSJ1cm46aGw3LW9y Zzp2MyBDREEueHNkIj4NCiAgPHR5cGVJZCBleHRlbnNpb249IlBPQ0RfSEQw MDAwNDAiIHJvb3Q9IjIuMTYuODQwLjEuMTEzODgzLjEuMyIvPg0KICA8aWQg cm9vdD0iMS4zLjYuNC4xLjQuMS4yODM1LjIuNzc3NyIvPg0KICA8Y29kZSBj b2RlPSIzNDEzMy05IiBjb2RlU3lzdGVtPSIyLjE2Ljg0MC4xLjExMzg4My42 LjEiIGNvZGVTeXN0ZW1OYW1lPSJMT0lOQyINCiAgIGRpc3BsYXlOYW1lPSJT VU1NQVJJWkFUSU9OIE9GIEVQSVNPREUgTk9URSIvPg0KICA8dGl0bGU+R29v ZCBIZWFsdGggQ2xpbmljIENhcmUgUmVjb3JkIFN1bW1hcnk8L3RpdGxlPg0K ICA8ZWZmZWN0aXZlVGltZSB2YWx1ZT0iMjAwNTAzMjkyMjQ0MTErMDUwMCIv Pg0KICA8Y29uZmlkZW50aWFsaXR5Q29kZSBjb2RlPSJOIiBjb2RlU3lzdGVt PSIyLjE2Ljg0MC4xLjExMzg4My41LjI1Ii8+DQogIDxsYW5ndWFnZUNvZGUg Y29kZT0iZW4tVVMiLz4NCiAgPHJlY29yZFRhcmdldD4NCiAgICA8cGF0aWVu dFJvbGU+DQogICAgICA8aWQgZXh0ZW5zaW9uPSIxMjM0NSIgcm9vdD0iMi4x Ni44NDAuMS4xMTM4ODMuMy45MzMiLz4NCiAgICAgIDxhZGRyPg0KICAgICAg ICA8c3RyZWV0QWRkcmVzc0xpbmU+MTcgRGF3cyBSZC48L3N0cmVldEFkZHJl c3NMaW5lPg0KICAgICAgICA8Y2l0eT5CbHVlIEJlbGw8L2NpdHk+DQogICAg ICAgIDxzdGF0ZT5NQTwvc3RhdGU+DQogICAgICAgIDxwb3N0YWxDb2RlPjAy MzY4PC9wb3N0YWxDb2RlPg0KICAgICAgICA8Y291bnRyeT5VU0E8L2NvdW50 cnk+DQogICAgICA8L2FkZHI+DQogICAgICA8cGF0aWVudD4NCiAgICAgICAg PG5hbWU+DQogICAgICAgICAgPHByZWZpeD5NcnMuPC9wcmVmaXg+DQogICAg ICAgICAgPGdpdmVuPkVsbGVuPC9naXZlbj4NCiAgICAgICAgICA8ZmFtaWx5 PlJvc3M8L2ZhbWlseT4NCiAgICAgICAgPC9uYW1lPg0KICAgICAgICA8YWRt aW5pc3RyYXRpdmVHZW5kZXJDb2RlIGNvZGU9IkYiIGNvZGVTeXN0ZW09IjIu MTYuODQwLjEuMTEzODgzLjUuMSIvPg0KICAgICAgICA8YmlydGhUaW1lIHZh bHVlPSIxOTYwMDEyNyIvPg0KICAgICAgPC9wYXRpZW50Pg0KICAgPC9wYXRp ZW50Um9sZT4NCiAgPC9yZWNvcmRUYXJnZXQ+DQogIDxhdXRob3I+DQogICAg PHRpbWUgdmFsdWU9IjE5OTkwNTIyIi8+DQogICAgPGFzc2lnbmVkQXV0aG9y Pg0KICAgICAgPGlkIGV4dGVuc2lvbj0iMTExMTExMTEiICByb290PSIxLjMu NS4zNS4xLjQ0MzYuNyIvPg0KICAgICAgPGFzc2lnbmVkUGVyc29uPg0KICAg ICAgICA8bmFtZT4NCiAgICAgICAgICA8cHJlZml4PkRyLjwvcHJlZml4Pg0K ICAgICAgICAgIDxnaXZlbj5CZXJuYXJkPC9naXZlbj4NCiAgICAgICAgICA8 ZmFtaWx5Pldpc2VtYW48L2ZhbWlseT4NCiAgICAgICAgICA8c3VmZml4PlNy Ljwvc3VmZml4Pg0KICAgICAgICA8L25hbWU+DQogICAgICA8L2Fzc2lnbmVk UGVyc29uPg0KICAgIAk8cmVwcmVzZW50ZWRPcmdhbml6YXRpb24+DQoJICAg PGlkIGV4dGVuc2lvbj0iYWFhYWFiYmJiYiIgcm9vdD0iMS4zLjUuMzUuMS40 NDM2LjciLz4NCgkgICA8bmFtZT5Eci4gV2lzZW1hbnMgQ2xpbmljPC9uYW1l Pg0KICAgICAgPC9yZXByZXNlbnRlZE9yZ2FuaXphdGlvbj4NCiAgICA8L2Fz c2lnbmVkQXV0aG9yPg0KICA8L2F1dGhvcj4NCiAgPGF1dGhvcj4NCiAgICA8 dGltZSB2YWx1ZT0iMjAwNTAzMjkyMjQ0MTErMDUwMCIvPg0KICAgIDxhc3Np Z25lZEF1dGhvcj4NCiAgICAgIDxpZCByb290PSIxLjMuNi40LjEuNC4xLjI4 MzUuMi4xMjM0Ii8+DQogICAgICA8YXNzaWduZWRBdXRob3JpbmdEZXZpY2U+ DQoJIDxjb2RlIGNvZGU9IkNBUFRVUkUiIGRpc3BsYXlOYW1lPSJJbWFnZSBD YXB0dXJlIiBjb2RlU3lzdGVtPSIxLjIuODQwLjEwMDA4LjIuMTYuNCIvPiAN CgkgPG1hbnVmYWN0dXJlck1vZGVsTmFtZT5TT01FIFNDQU5ORVIgTkFNRSBB TkQgTU9ERUwgIDwvbWFudWZhY3R1cmVyTW9kZWxOYW1lPg0KICAgICAgICAg PHNvZnR3YXJlTmFtZT5TQ0FOIFNPRlRXQVJFIE5BTUUgdjAuMDwvc29mdHdh cmVOYW1lPg0KICAgICAgPC9hc3NpZ25lZEF1dGhvcmluZ0RldmljZT4NCiAg ICAgIDxyZXByZXNlbnRlZE9yZ2FuaXphdGlvbj4NCgkgICA8aWQgcm9vdD0i MS4zLjYuNC4xLjQuMS4yODM1LjIiLz4NCgkgICA8bmFtZT5TT01FIFNjYW5u aW5nIEZhY2lsaXR5PC9uYW1lPg0KICAgICAgICAgPGFkZHI+DQogICAgICAg ICAgIDxzdHJlZXRBZGRyZXNzTGluZT4yMSBOb3J0aCBBdmU8L3N0cmVldEFk ZHJlc3NMaW5lPg0KICAgICAgICAgICA8Y2l0eT5CdXJsaW5ndG9uPC9jaXR5 Pg0KICAgICAgICAgICA8c3RhdGU+TUE8L3N0YXRlPg0KICAgICAgICAgICA8 cG9zdGFsQ29kZT4wMTgwMzwvcG9zdGFsQ29kZT4NCiAgICAgICAgICAgPGNv dW50cnk+VVNBPC9jb3VudHJ5Pg0KICAgICAgICAgPC9hZGRyPg0KICAgICAg PC9yZXByZXNlbnRlZE9yZ2FuaXphdGlvbj4NCiAgIDwvYXNzaWduZWRBdXRo b3I+DQogPC9hdXRob3I+DQogIDxkYXRhRW50ZXJlcj4NCiAgICA8dGltZSB2 YWx1ZT0iMjAwNTAzMjkyMjQ0MTErMDUwMCIvPg0KICAgIDxhc3NpZ25lZEVu dGl0eT4NCiAgICAgIDxpZCBleHRlbnNpb249IjIyMjIyMjIyIiAgcm9vdD0i MS4zLjYuNC4xLjQuMS4yODM1LjIiLz4NCiAgICAgIDxhc3NpZ25lZFBlcnNv bj4NCiAgICAgICAgPG5hbWU+DQogICAgICAgICAgPHByZWZpeD5NcnMuPC9w cmVmaXg+DQogICAgICAgICAgPGdpdmVuPkJlcm5pY2U8L2dpdmVuPg0KICAg ICAgICAgIDxmYW1pbHk+U21pdGg8L2ZhbWlseT4NCiAgICAgICAgPC9uYW1l Pg0KICAgICAgPC9hc3NpZ25lZFBlcnNvbj4NCiAgICA8L2Fzc2lnbmVkRW50 aXR5Pg0KICA8L2RhdGFFbnRlcmVyPg0KICA8Y3VzdG9kaWFuPg0KICAgIDxh c3NpZ25lZEN1c3RvZGlhbj4NCiAgICAgIDxyZXByZXNlbnRlZEN1c3RvZGlh bk9yZ2FuaXphdGlvbj4NCgkgICA8aWQgcm9vdD0iMS4zLjYuNC4xLjQuMS4y ODM1LjIiLz4NCgkgICA8bmFtZT5TT01FIFNjYW5uaW5nIEZhY2lsaXR5PC9u YW1lPg0KICAgICAgICAgPGFkZHI+DQogICAgICAgICAgIDxzdHJlZXRBZGRy ZXNzTGluZT4yMSBOb3J0aCBBdmU8L3N0cmVldEFkZHJlc3NMaW5lPg0KICAg ICAgICAgICA8Y2l0eT5CdXJsaW5ndG9uPC9jaXR5Pg0KICAgICAgICAgICA8 c3RhdGU+TUE8L3N0YXRlPg0KICAgICAgICAgICA8cG9zdGFsQ29kZT4wMTgw MzwvcG9zdGFsQ29kZT4NCiAgICAgICAgICAgPGNvdW50cnk+VVNBPC9jb3Vu dHJ5Pg0KICAgICAgICAgPC9hZGRyPg0KICAgICAgPC9yZXByZXNlbnRlZEN1 c3RvZGlhbk9yZ2FuaXphdGlvbj4NCiAgICA8L2Fzc2lnbmVkQ3VzdG9kaWFu Pg0KICA8L2N1c3RvZGlhbj4NCiAgPGxlZ2FsQXV0aGVudGljYXRvcj4NCiAg ICA8dGltZSB2YWx1ZT0iMTk5OTA1MjIiLz4NCiAgICA8c2lnbmF0dXJlQ29k ZSBjb2RlPSJTIi8+DQogICAgPGFzc2lnbmVkRW50aXR5Pg0KICAgICAgPGlk IGV4dGVuc2lvbj0iMTExMTExMTEiICByb290PSIxLjMuNS4zNS4xLjQ0MzYu NyIvPg0KICAgICAgPGFzc2lnbmVkUGVyc29uPg0KICAgICAgICA8bmFtZT4N CiAgICAgICAgICA8cHJlZml4PkRyLjwvcHJlZml4Pg0KICAgICAgICAgIDxn aXZlbj5CZXJuYXJkPC9naXZlbj4NCiAgICAgICAgICA8ZmFtaWx5Pldpc2Vt YW48L2ZhbWlseT4NCiAgICAgICAgICA8c3VmZml4PlNyLjwvc3VmZml4Pg0K ICAgICAgICA8L25hbWU+DQogICAgICA8L2Fzc2lnbmVkUGVyc29uPg0KICAg IDwvYXNzaWduZWRFbnRpdHk+DQogIDwvbGVnYWxBdXRoZW50aWNhdG9yPg0K ICA8ZG9jdW1lbnRhdGlvbk9mPg0KICAgIDxzZXJ2aWNlRXZlbnQgPg0KICAg ICAgPGVmZmVjdGl2ZVRpbWU+DQogICAgICAgIDxsb3cgdmFsdWU9IjE5ODAw MTI3Ii8+DQogICAgICAgIDxoaWdoIHZhbHVlPSIxOTk5MDUyMiIvPg0KICAg ICAgPC9lZmZlY3RpdmVUaW1lPg0KICAgIDwvc2VydmljZUV2ZW50Pg0KICA8 L2RvY3VtZW50YXRpb25PZj4NCiAgPGNvbXBvbmVudD4NCiAgICA8bm9uWE1M Qm9keT4NCiAgICAgIDx0ZXh0IG1lZGlhVHlwZT0iYXBwbGljYXRpb24vcGRm IiByZXByZXNlbnRhdGlvbj0iQjY0Ij4NCkpWQkVSaTB4TGpNS0pjZnNqNklL TlNBd0lHOWlhZ284UEM5TVpXNW5kR2dnTmlBd0lGSXZSbWxzZEdWeUlDOUdi R0YwDQpaVVJsWTI5a1pUNCtDbk4wY21WaGJRcDRuR1dQTVdzRE1ReUZkLzhL amZKd3FtVmJrcjBHUXFGYmc3ZlFvU1JOV3VoQg0KUS80LzFMNjdURUVZbWUr OUoxczNDTVFRUm0zOU5MdVhnOEgxN2dLODluTjFOOGVMQWJaMm1tSFh1cWwy UURWVWhuWngNCmE1aUJjeVF0b01JVU03VFpIYkg1S1pFVkRnbS8vU1NVc3di Rkh4L0p6QkxldTV5WXhPSXpFOGJQY1JXcWRhR0RtY1pPDQpCV2MvOWJmVU5P UGZPdGU0NE85anh0Y0lLc2txcDBKWm91SjVkZVlxZUJuNThabUt0SVUrMnB0 anFXUVJKcEd5ckhEdQ0KSzdDWEllMmJlKy8xRHpYUVArUmxibVJ6ZEhKbFlX MEtaVzVrYjJKcUNqWWdNQ0J2WW1vS01qQXhDbVZ1Wkc5aWFnbzANCklEQWdi MkpxQ2p3OEwxUjVjR1V2VUdGblpTOU5aV1JwWVVKdmVDQmJNQ0F3SURZeE1p QTNPVEpkQ2k5U2IzUmhkR1VnDQpNQzlRWVhKbGJuUWdNeUF3SUZJS0wxSmxj MjkxY21ObGN6dzhMMUJ5YjJOVFpYUmJMMUJFUmlBdlZHVjRkRjBLTDBWNA0K ZEVkVGRHRjBaU0F4TUNBd0lGSUtMMFp2Ym5RZ01URWdNQ0JTQ2o0K0NpOURi MjUwWlc1MGN5QTFJREFnVWdvK1BncGwNCmJtUnZZbW9LTXlBd0lHOWlhZ284 UENBdlZIbHdaU0F2VUdGblpYTWdMMHRwWkhNZ1d3bzBJREFnVWdwZElDOURi M1Z1DQpkQ0F4Q2o0K0NtVnVaRzlpYWdveElEQWdiMkpxQ2p3OEwxUjVjR1Vn TDBOaGRHRnNiMmNnTDFCaFoyVnpJRE1nTUNCUw0KQ2o0K0NtVnVaRzlpYWdv M0lEQWdiMkpxQ2p3OEwxUjVjR1V2UlhoMFIxTjBZWFJsQ2k5UFVFMGdNVDQr Wlc1a2IySnENCkNqRXdJREFnYjJKcUNqdzhMMUkzQ2pjZ01DQlNQajRLWlc1 a2IySnFDakV4SURBZ2IySnFDanc4TDFJNUNqa2dNQ0JTDQpQajRLWlc1a2Iy SnFDamtnTUNCdlltb0tQRHd2UW1GelpVWnZiblF2VlVKWlFrRlFLME5OVWpF d0wwWnZiblJFWlhOag0KY21sd2RHOXlJRGdnTUNCU0wxUjVjR1V2Um05dWRB b3ZSbWx5YzNSRGFHRnlJRFEyTDB4aGMzUkRhR0Z5SURFeE5TOVgNCmFXUjBh SE5iSURJM09DQXdDakFnTlRBd0lEQWdNQ0F3SURBZ01DQXdJREFnTUNBd0lE QWdNQ0F3SURBZ01Bb3dJREFnDQpNQ0F3SURBZ01DQXdJREFnTUNBd0lEQWdN Q0F3SURBZ01DQXdDakFnTUNBd0lEQWdOekl5SURBZ01DQXdJREFnTUNBdw0K SURBZ01DQXdJREFnTUFvd0lEVXdNQ0F3SURBZ05UVTJJRFEwTkNBek1EWWdN Q0ExTlRZZ01qYzRJREFnTUNBeU56Z2cNCk9ETXpJREFnTUFvMU5UWWdNQ0F3 SURNNU5GMEtMMFZ1WTI5a2FXNW5MMWRwYmtGdWMybEZibU52WkdsdVp5OVRk V0owDQplWEJsTDFSNWNHVXhQajRLWlc1a2IySnFDamdnTUNCdlltb0tQRHd2 Vkhsd1pTOUdiMjUwUkdWelkzSnBjSFJ2Y2k5Rw0KYjI1MFRtRnRaUzlWUWxs Q1FWQXJRMDFTTVRBdlJtOXVkRUpDYjNoYk1DQXRNVGswSURneE15QTNNRFZk TDBac1lXZHoNCklEUUtMMEZ6WTJWdWRDQTNNRFVLTDBOaGNFaGxhV2RvZENB M01EVUtMMFJsYzJObGJuUWdMVEU1TkFvdlNYUmhiR2xqDQpRVzVuYkdVZ01B b3ZVM1JsYlZZZ01USXhDaTlOYVhOemFXNW5WMmxrZEdnZ016TXpDaTlEYUdG eVUyVjBLQzlrTDNBdg0KWlM5bUwzQmxjbWx2WkM5ekwyZ3ZhUzl2Ym1VdlZD OXNMMkV2YlNrdlJtOXVkRVpwYkdVeklERXlJREFnVWo0K0NtVnUNClpHOWlh Z294TWlBd0lHOWlhZ284UEM5R2FXeDBaWEl2Um14aGRHVkVaV052WkdVS0wx TjFZblI1Y0dVdlZIbHdaVEZEDQpMMHhsYm1kMGFDQXhOVEF5UGo1emRISmxZ VzBLZUp5bGxIdE1VMmNZeHMvcDdSd1ZVZHVkTU1YMVZFUG1kV3pNS2JKbw0K TmlRd1VIR1JtM2V3UWdXMDVWSmFGUkN0Q05MeXRvQ2lsWXYyc3JhQUJVb0ZH aEh3cnRQb1dKZzZkWXZUd1RUNkJ6cW4NCmtxL2trTGlEeXJZczJ4L0xjazYr bkpPYzczM2Y1L2M4MzhFeEhnZkRjVndRRmgwVDlOSEkwL3RlZjl3N2xlTjlq d3RNDQp3dEM1b1hnKytIREJoK2VhS3ZoQmlGWlBRb3Nub01DSkdCZkhJNWF0 RGN2TXlsV21wNmFwSkRQRFprbUNRa0tDSmFFSw0KbVRJOVdab2hpWmFxMG1R S3FZcDlrVXRpTTVQVFphcmNRRW1vWEM2SkdkbVJJNG1SNWNpVTIyUXByMXVI WlNxeTFDcVoNClVoS2RtU0pUWm1BWU5qNGxTN1k1SnkwOVRpNVZCQVpoV0Rp MkVvdkF2c0Rpc0Noc0tUWWZpOGFXWUN1d0NaZ1E4MlVsDQpZQVJXaWZ2anUv REhuQ291emMzai9zcjdnSGVKRC93bS91QXJQRG9lODMzRm1WT0dhYXhxajNl eUZXMzJDSnZ2SVZPUA0KbjJpbmQrSjVLb3BBTTR4OEp4Rys5MEEzN1gxQk1B RWF2cHo0cnJKb0xjM0lDVkYzUzhaR1I3dy9NM2I2TElaaVJFOW0NCklzRzFq dVpHTzQwc1BFWktRQzdvTkhtS2RZbnFqWkFJcVk2YzQ5bnQyb3ZRRG03RDVZ WU9pL040MHpsd2dXZW5NOUdZDQpCenJJSmQvTXdpUTQwVnlyZDdKSGFSY085 cUxhZTM2aXV5Z01QYVFhVG5jM25BYnk1cFY1REo4Wkh4NGNtaXd6dDJmUg0K QlJiUWc1bU00MVhrZStKdkE0bkd2WGlDS0NTYS9aVGhMWlltcWJmVG9vR2V0 Nk5mUDFDY1JBK25FWWthaUJUTGlXYjkNCkdZTUQ2dUMwemxWS09vbElEWFRR YUJIaCt3cnZ6c1kwZHFTd29DVld2UDRlS3V6aGVxZWdmTXBhQnBhbjhRUE1K SWI4DQpNSUJkcDd5Y2pRamsyNEc0cGtON0Rmc0tkY1Y3ZFhSYVFCRHNnVFdR ZkV6bFZuUkJEN1NRZWd1MUg4MjZiMjhHOHZraA0KeGorRlpsc0VsV0hnOVBL ZDZKUDdsVlljOFhvZTlYTlJoRGVBUWdJbk13YVJnbCs2dWs2VTFVQlJqWGgz U2U0dVVKS3ENCjJ1MTFEVFZtbTN0elUwTDRnb1JwWW9aWUpQK1J1VE1xcDFY ZmFhaUhOdWlFTmkzcDNFYUU2b3d0STUxS1dURlc3d0tUDQpzT2tyVlJmS1p4 Yy8wUU9VZ2hJb2E4bFArUkJHcms1TFhoeWNldkhuSFdKdFZXbjVIaUIzUVZF dXpieEw1RUdSc1VLdg0KTjVuRUJnTVlqcHBPU0R0S0xTeGk0dVMzTjg0cWp1 MCtURzlwVEttVVZwS2lPN0hHeUtwTFUxeU85ajdFcVFpU0c4VDYNCndvTmdB TElLS2t6ME0rSUlITkRzMDhIdVhXSnR5WjdDRXEyc2ZoUHNCSkx4bFVYR3B0 Vm0xcW5weHV6NjRoc0ZiMFBBDQprbmtkUnh4eGVwR3NsK3ZkZ0NvbzZBT252 S1hneUJielNnaUdwQy96VThsUzlFendsMVFPSHhsbDRkS2ZOdFNCQTg3bw0K bXYrMGRqbng0dnFGYTFlTjhURmlwdUJmdmx3RlNpZzl4bzZCVTVkZkcrUkI0 d2VGdHdiRDJVUHhHSVY3VjFDTVpLVGYNCk53ZUwyVk5nSGEzU3FEOW5zTEZ4 ZHIycEVsVlMwVXFMbnBWN2oxT05Ta3VtWEoyVm5XWE5kdGJiTFkxaVZ1SDFo U09sDQpReXdvMUkyMzJGSGxBMVJwNXc0RkRvVlF3MGl3ZzFIejdZSnFOTCtt Q2MyQm8reG9oM1NXRXRDQWloeTJFZWxRTUYyYw0KTEJlMGwvMEdKOW5yT2JT elppY1QwNkc2bWZiYUNEQkQ5ZEZ5SXl2SkJPejJtaTNWekh6U0xoalZNNFN6 VExrOVhCUSsNCnRKVDZSM0pOK3JNR085aWhXK2YrZzV5dlY2dXg1am5SVmt2 ZHd5NnIwSE5uM1NNVTNIdlQ3aWZLMTZDKzIxUjVjcDIwDQpFMGpMbGVxNzlB VmxMTEZTV2F6WlV0SlJJVWJyQ2ZCQWE2bzdwWFZON1RvZ1F5TFdSeW5NZVk3 Nm8yYkg0WDFORy9SMA0KbmF2YjJBaGs5OFdVaituTmhPaVVaclUyWEx0YzhY bTZjaFVra1o4T0tLLzJuR3pyTkltTDBFSnFCakUzTEQxeDdTYlgNCnFmT2Vl eWhrUDR1U0d4ci94aVcxVllnNFY1ZVBwSVc5L1VRdXhFRURGR1A1MzRINHo5 RkJzY1RmazVvbksrZ1BOU2JDDQpFbGkvTVRPYUZOMTZTVERUL21ELzFwdEJ2 RytRaStMT1VnMDV0b3lNbkp5TURGdE9RNFBOMWlCbThiTWEzYzRUWmh4bA0K ZmM5Rm5VUHZVRFl3cU1UUnkrYkJWaURsaEJtK2hqTU9jcmlHU05YdURoSnZs UXRjWmYzc3I2QU4rc0hGNW1NckVhUTENCnVtbGZ0WFhvTXl0VGR3UmxHQVhN cHNPRWMyenZPUEZZWHJEWlo0ejFvSTlQcjlsblBJYjlEbnNDT2JnS1pXNWtj M1J5DQpaV0Z0Q21WdVpHOWlhZ295SURBZ2IySnFDanc4TDFCeWIyUjFZMlZ5 S0VGR1VFd2dSMmh2YzNSelkzSnBjSFFnT0M0MQ0KTVNrS0wwTnlaV0YwYVc5 dVJHRjBaU2hFT2pJd01EWXdOVEkyTVRJME1UQXlLUW92VFc5a1JHRjBaU2hF T2pJd01EWXcNCk5USTJNVEkwTVRBeUtRb3ZRM0psWVhSdmNpaGtkbWx3YzF3 b2Exd3BJRFV1T1RWaElFTnZjSGx5YVdkb2RDQXlNREExDQpJRkpoWkdsallX d2dSWGxsSUZOdlpuUjNZWEpsS1FvdlZHbDBiR1VvVTJOaGJsTmhiWEJzWlM1 a2Rta3BQajVsYm1Sdg0KWW1vS2VISmxaZ293SURFekNqQXdNREF3TURBd01E QWdOalUxTXpVZ1ppQUtNREF3TURBd01EVXlOQ0F3TURBd01DQnUNCklBb3dN REF3TURBeU9ERTJJREF3TURBd0lHNGdDakF3TURBd01EQTBOalVnTURBd01E QWdiaUFLTURBd01EQXdNRE13DQpOU0F3TURBd01DQnVJQW93TURBd01EQXdN REUxSURBd01EQXdJRzRnQ2pBd01EQXdNREF5T0RZZ01EQXdNREFnYmlBSw0K TURBd01EQXdNRFUzTWlBd01EQXdNQ0J1SUFvd01EQXdNREF3T1RnNElEQXdN REF3SUc0Z0NqQXdNREF3TURBMk56TWcNCk1EQXdNREFnYmlBS01EQXdNREF3 TURZeE15QXdNREF3TUNCdUlBb3dNREF3TURBd05qUXpJREF3TURBd0lHNGdD akF3DQpNREF3TURFeU1qa2dNREF3TURBZ2JpQUtkSEpoYVd4bGNnbzhQQ0F2 VTJsNlpTQXhNeUF2VW05dmRDQXhJREFnVWlBdg0KU1c1bWJ5QXlJREFnVWdv dlNVUWdXenhHTkVORE4wRkZRalUwUWpNMlJrSXlPRE5ETlVNek1qUTNPVUZF TWpnelJqNDgNClJqUkRRemRCUlVJMU5FSXpOa1pDTWpnelF6VkRNekkwTnps QlJESTRNMFkrWFFvK1BncHpkR0Z5ZEhoeVpXWUtNekF4DQpNZ29sSlVWUFJn bz0NCiAgICAgIDwvdGV4dD4NCiAgICA8L25vblhNTEJvZHk+DQogIDwvY29t cG9uZW50Pg0KPC9DbGluaWNhbERvY3VtZW50Pg0K </xdsb:Document><xdsb:RepositoryUniqueId>1.19.6.24.109.42.1 </xdsb:RepositoryUniqueId><xdsb:DocumentUniqueId>1.2.3.4.100000022002209036.1196211173506.1 </xdsb:DocumentUniqueId><xdsb:mimeType>text/xml</xdsb:mimeType ></xdsb:DocumentResponse></xdsb:RetrieveDocumentSetResponse >
DEBUG - Beginning XDS.b MTOM attachment extraction
DEBUG - Extracted attachment with id
1.2.3.4.100000022002209036.1196211173506.1 from repository
1.19.6.24.109.42.1
DEBUG - Ending XDS.b MTOM attachment extraction
DEBUG - Ending XDS SOAP Processing
DEBUG - Loading response in EMF.
DEBUG - Success.
DEBUG - RegistryResponse error list is null.
DEBUG - Sending PHIImportEvent Audit message.
INFO - <13>Jan 4 02:25:06 machine1 <?xml version="1.0"
<EventIdentification EventActionCode="R"
EventDateTime="2008-01-04T02:25:06.468-05:00" EventOutcomeIndicator="0">
<EventTypeCode code="ITI-43" codeSystemName="IHE Transactions"
displayName="Retrieve Document Set"/>
<EventID code="110107" codeSystemName="DCM" displayName="Import"/>
<ActiveParticipant
UserID="http://129.6.24.109:9080/axis2/services/xdsrepositoryb"
<RoleIDCode code="110152" codeSystemName="DCM" displayName="Destination"/>
<RoleIDCode code="110153" codeSystemName="DCM" displayName="Source"/>
<ParticipantObjectIdentification
ParticipantObjectID=" 270a59d7a8b145b^^^&amp;1.3.6.1.4.1.21367.2005.3.7&am p;ISO "
ParticipantObjectTypeCode="1" ParticipantObjectTypeCodeRole="1">
<ParticipantObjectIDTypeCode code="2"/>
</ParticipantObjectIdentification>
ParticipantObjectID="1.2.3.4.100000022002209036.1196211173506.1 "
ParticipantObjectTypeCode="2" ParticipantObjectTypeCodeRole="3">
<ParticipantObjectIDTypeCode code="9"/>
</AuditMessage>
DEBUG - Now have recieved 1 documents.
DEBUG - Starting Audit stop messages [1]
EventDateTime="2008-01-04T02:25:06.500-05:00" EventOutcomeIndicator="0">
Activity"/>
<EventTypeCode code="110121" codeSystemName="DCM" displayName="Application
Stop"/>
Launcher"/>
</AuditMessage>
ERROR: 'XML document structures must start and end within the same
entity.'
ERROR: 'com.sun.org.apache.xml.internal.utils.WrappedRuntimeExcepti on:
XML document structures must start and end within the same entity.'
Let me know if you want me to turn on logging for something else as well.
The last 'ERRORS' are from my XSLT transformations.
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #39802 is a reply to message #39711] Fri, 04 January 2008 12:31 Go to previous messageGo to next message
OK, thanks for the log. The "SOAP RESPONSE BODY" being printed out
shows a complete document being there at that phase - aka the document
is being received in full and relayed by Axis to OHF - so the problem is
probably in the deserialization. I'm going to try a couple more things
this morning and get back to you.
In the meantime, could you please try the same transaction on the
following repository endpoint:
http://129.6.24.109:9080/axis2/services/xdsrepositorybopt
I don't think it'll make any difference, but it wouldn't hurt to try.
Thanks a bunch,
-Matt
Sumedh wrote:
> Here you go:
> by calling setAuditSourceId.
> Activity"/>
> displayName="Application Start"/>
> Launcher"/>
> </AuditMessage>
taW5zdGFuY2UiIGNsYXNzQ29kZT0iRE9DQ0xJTiIgbW9vZENvZGU9IkVWTiI geHNpOnNjaGVtYUxvY2F0aW9uPSJ1cm46aGw3LW9yZzp2MyBDREEueHNkIj4 NCiAgPHR5cGVJZCBleHRlbnNpb249IlBPQ0RfSEQwMDAwNDAiIHJvb3Q9IjI uMTYuODQwLjEuMTEzODgzLjEuMyIvPg0KICA8aWQgcm9vdD0iMS4zLjYuNC4 xLjQuMS4yODM1LjIuNzc3NyIvPg0KICA8Y29kZSBjb2RlPSIzNDEzMy05IiB jb2RlU3lzdGVtPSIyLjE2Ljg0MC4xLjExMzg4My42LjEiIGNvZGVTeXN0ZW1 OYW1lPSJMT0lOQyINCiAgIGRpc3BsYXlOYW1lPSJTVU1NQVJJWkFUSU9OIE9 GIEVQSVNPREUgTk9URSIvPg0KICA8dGl0bGU+R29vZCBIZWFsdGggQ2xpbml jIENhcmUgUmVjb3JkIFN1bW1hcnk8L3RpdGxlPg0KICA8ZWZmZWN0aXZlVGl tZSB2YWx1ZT0iMjAwNTAzMjkyMjQ0MTErMDUwMCIvPg0KICA8Y29uZmlkZW5 0aWFsaXR5Q29kZSBjb2RlPSJOIiBjb2RlU3lzdGVtPSIyLjE2Ljg0MC4xLjE xMzg4My41LjI1Ii8+DQogIDxsYW5ndWFnZUNvZGUgY29kZT0iZW4tVVMiLz4 NCiAgPHJlY29yZFRhcmdldD4NCiAgICA8cGF0aWVudFJvbGU+DQogICAgICA 8aWQgZXh0ZW5zaW9uPSIxMjM0NSIgcm9vdD0iMi4xNi44NDAuMS4xMTM4ODM uMy45MzMiLz4NCiAgICAgIDxhZGRyPg0KICAgICAgICA8c3RyZWV0QWRkcmV zc0xpbmU+MTcgRGF3cyBSZC48L3N0cmVldEFkZHJlc3NMaW5lPg0KICAgICA gICA8Y2l0eT5CbHVlIEJlbGw8L2Npd
Hk+DQogICAgICAgIDxzdGF0ZT5NQTwvc3RhdGU+DQogICAgICAgIDxwb3N0Y WxDb2RlPjAyMzY4PC9wb3N0YWxDb2RlPg0KICAgICAgICA8Y291bnRyeT5VU 0E8L2NvdW50cnk+DQogICAgICA8L2FkZHI+DQogICAgICA8cGF0aWVudD4NC iAgICAgICAgPG5hbWU+DQogICAgICAgICAgPHByZWZpeD5NcnMuPC9wcmVma Xg+DQogICAgICAgICAgPGdpdmVuPkVsbGVuPC9naXZlbj4NCiAgICAgICAgI CA8ZmFtaWx5PlJvc3M8L2ZhbWlseT4NCiAgICAgICAgPC9uYW1lPg0KICAgI CAgICA8YWRtaW5pc3RyYXRpdmVHZW5kZXJDb2RlIGNvZGU9IkYiIGNvZGVTe XN0ZW09IjIuMTYuODQwLjEuMTEzODgzLjUuMSIvPg0KICAgICAgICA8Ymlyd GhUaW1lIHZhbHVlPSIxOTYwMDEyNyIvPg0KICAgICAgPC9wYXRpZW50Pg0KI CAgPC9wYXRpZW50Um9sZT4NCiAgPC9yZWNvcmRUYXJnZXQ+DQogIDxhdXRob 3I+DQogICAgPHRpbWUgdmFsdWU9IjE5OTkwNTIyIi8+DQogICAgPGFzc2lnb mVkQXV0aG9yPg0KICAgICAgPGlkIGV4dGVuc2lvbj0iMTExMTExMTEiICByb 290PSIxLjMuNS4zNS4xLjQ0MzYuNyIvPg0KICAgICAgPGFzc2lnbmVkUGVyc 29uPg0KICAgICAgICA8bmFtZT4NCiAgICAgICAgICA8cHJlZml4PkRyLjwvc HJlZml4Pg0KICAgICAgICAgIDxnaXZlbj5CZXJuYXJkPC9naXZlbj4NCiAgI CAgICAgICA8ZmFtaWx5Pldpc2VtYW48L2ZhbWlseT4NCiAgICAgICAgICA8c 3VmZml4PlNyLjwvc3VmZml4Pg0KICA
gICAgICA8L25hbWU+DQogICAgICA8L2Fzc2lnbmVkUGVyc29uPg0KICAgIAk 8cmVwcmVzZW50ZWRPcmdhbml6YXRpb24+DQoJICAgPGlkIGV4dGVuc2lvbj0 iYWFhYWFiYmJiYiIgcm9vdD0iMS4zLjUuMzUuMS40NDM2LjciLz4NCgkgICA 8bmFtZT5Eci4gV2lzZW1hbnMgQ2xpbmljPC9uYW1lPg0KICAgICAgPC9yZXB yZXNlbnRlZE9yZ2FuaXphdGlvbj4NCiAgICA8L2Fzc2lnbmVkQXV0aG9yPg0 KICA8L2F1dGhvcj4NCiAgPGF1dGhvcj4NCiAgICA8dGltZSB2YWx1ZT0iMjA wNTAzMjkyMjQ0MTErMDUwMCIvPg0KICAgIDxhc3NpZ25lZEF1dGhvcj4NCiA gICAgIDxpZCByb290PSIxLjMuNi40LjEuNC4xLjI4MzUuMi4xMjM0Ii8+DQo gICAgICA8YXNzaWduZWRBdXRob3JpbmdEZXZpY2U+DQoJIDxjb2RlIGNvZGU 9IkNBUFRVUkUiIGRpc3BsYXlOYW1lPSJJbWFnZSBDYXB0dXJlIiBjb2RlU3l zdGVtPSIxLjIuODQwLjEwMDA4LjIuMTYuNCIvPiANCgkgPG1hbnVmYWN0dXJ lck1vZGVsTmFtZT5TT01FIFNDQU5ORVIgTkFNRSBBTkQgTU9ERUwgIDwvbWF udWZhY3R1cmVyTW9kZWxOYW1lPg0KICAgICAgICAgPHNvZnR3YXJlTmFtZT5 TQ0FOIFNPRlRXQVJFIE5BTUUgdjAuMDwvc29mdHdhcmVOYW1lPg0KICAgICA gPC9hc3NpZ25lZEF1dGhvcmluZ0RldmljZT4NCiAgICAgIDxyZXByZXNlbnR lZE9yZ2FuaXphdGlvbj4NCgkgICA8aWQgcm9vdD0iMS4zLjYuNC4xLjQuMS4 yODM1LjIiLz4NCgkgICA8bmFtZT5TT
01FIFNjYW5uaW5nIEZhY2lsaXR5PC9uYW1lPg0KICAgICAgICAgPGFkZHI+D QogICAgICAgICAgIDxzdHJlZXRBZGRyZXNzTGluZT4yMSBOb3J0aCBBdmU8L 3N0cmVldEFkZHJlc3NMaW5lPg0KICAgICAgICAgICA8Y2l0eT5CdXJsaW5nd G9uPC9jaXR5Pg0KICAgICAgICAgICA8c3RhdGU+TUE8L3N0YXRlPg0KICAgI CAgICAgICA8cG9zdGFsQ29kZT4wMTgwMzwvcG9zdGFsQ29kZT4NCiAgICAgI CAgICAgPGNvdW50cnk+VVNBPC9jb3VudHJ5Pg0KICAgICAgICAgPC9hZGRyP g0KICAgICAgPC9yZXByZXNlbnRlZE9yZ2FuaXphdGlvbj4NCiAgIDwvYXNza WduZWRBdXRob3I+DQogPC9hdXRob3I+DQogIDxkYXRhRW50ZXJlcj4NCiAgI CA8dGltZSB2YWx1ZT0iMjAwNTAzMjkyMjQ0MTErMDUwMCIvPg0KICAgIDxhc 3NpZ25lZEVudGl0eT4NCiAgICAgIDxpZCBleHRlbnNpb249IjIyMjIyMjIyI iAgcm9vdD0iMS4zLjYuNC4xLjQuMS4yODM1LjIiLz4NCiAgICAgIDxhc3NpZ 25lZFBlcnNvbj4NCiAgICAgICAgPG5hbWU+DQogICAgICAgICAgPHByZWZpe D5NcnMuPC9wcmVmaXg+DQogICAgICAgICAgPGdpdmVuPkJlcm5pY2U8L2dpd mVuPg0KICAgICAgICAgIDxmYW1pbHk+U21pdGg8L2ZhbWlseT4NCiAgICAgI CAgPC9uYW1lPg0KICAgICAgPC9hc3NpZ25lZFBlcnNvbj4NCiAgICA8L2Fzc 2lnbmVkRW50aXR5Pg0KICA8L2RhdGFFbnRlcmVyPg0KICA8Y3VzdG9kaWFuP g0KICAgIDxhc3NpZ25lZEN1c3RvZGl
hbj4NCiAgICAgIDxyZXByZXNlbnRlZEN1c3RvZGlhbk9yZ2FuaXphdGlvbj4 NCgkgICA8aWQgcm9vdD0iMS4zLjYuNC4xLjQuMS4yODM1LjIiLz4NCgkgICA 8bmFtZT5TT01FIFNjYW5uaW5nIEZhY2lsaXR5PC9uYW1lPg0KICAgICAgICA gPGFkZHI+DQogICAgICAgICAgIDxzdHJlZXRBZGRyZXNzTGluZT4yMSBOb3J 0aCBBdmU8L3N0cmVldEFkZHJlc3NMaW5lPg0KICAgICAgICAgICA8Y2l0eT5 CdXJsaW5ndG9uPC9jaXR5Pg0KICAgICAgICAgICA8c3RhdGU+TUE8L3N0YXR lPg0KICAgICAgICAgICA8cG9zdGFsQ29kZT4wMTgwMzwvcG9zdGFsQ29kZT4 NCiAgICAgICAgICAgPGNvdW50cnk+VVNBPC9jb3VudHJ5Pg0KICAgICAgICA gPC9hZGRyPg0KICAgICAgPC9yZXByZXNlbnRlZEN1c3RvZGlhbk9yZ2FuaXp hdGlvbj4NCiAgICA8L2Fzc2lnbmVkQ3VzdG9kaWFuPg0KICA8L2N1c3RvZGl hbj4NCiAgPGxlZ2FsQXV0aGVudGljYXRvcj4NCiAgICA8dGltZSB2YWx1ZT0 iMTk5OTA1MjIiLz4NCiAgICA8c2lnbmF0dXJlQ29kZSBjb2RlPSJTIi8+DQo gICAgPGFzc2lnbmVkRW50aXR5Pg0KICAgICAgPGlkIGV4dGVuc2lvbj0iMTE xMTExMTEiICByb290PSIxLjMuNS4zNS4xLjQ0MzYuNyIvPg0KICAgICAgPGF zc2lnbmVkUGVyc29uPg0KICAgICAgICA8bmFtZT4NCiAgICAgICAgICA8cHJ lZml4PkRyLjwvcHJlZml4Pg0KICAgICAgICAgIDxnaXZlbj5CZXJuYXJkPC9 naXZlbj4NCiAgICAgICAgICA8ZmFta
Wx5Pldpc2VtYW48L2ZhbWlseT4NCiAgICAgICAgICA8c3VmZml4PlNyLjwvc 3VmZml4Pg0KICAgICAgICA8L25hbWU+DQogICAgICA8L2Fzc2lnbmVkUGVyc 29uPg0KICAgIDwvYXNzaWduZWRFbnRpdHk+DQogIDwvbGVnYWxBdXRoZW50a WNhdG9yPg0KICA8ZG9jdW1lbnRhdGlvbk9mPg0KICAgIDxzZXJ2aWNlRXZlb nQgPg0KICAgICAgPGVmZmVjdGl2ZVRpbWU+DQogICAgICAgIDxsb3cgdmFsd WU9IjE5ODAwMTI3Ii8+DQogICAgICAgIDxoaWdoIHZhbHVlPSIxOTk5MDUyM iIvPg0KICAgICAgPC9lZmZlY3RpdmVUaW1lPg0KICAgIDwvc2VydmljZUV2Z W50Pg0KICA8L2RvY3VtZW50YXRpb25PZj4NCiAgPGNvbXBvbmVudD4NCiAgI CA8bm9uWE1MQm9keT4NCiAgICAgIDx0ZXh0IG1lZGlhVHlwZT0iYXBwbGljY XRpb24vcGRmIiByZXByZXNlbnRhdGlvbj0iQjY0Ij4NCkpWQkVSaTB4TGpNS 0pjZnNqNklLTlNBd0lHOWlhZ284UEM5TVpXNW5kR2dnTmlBd0lGSXZSbWxzZ EdWeUlDOUdiR0YwDQpaVVJsWTI5a1pUNCtDbk4wY21WaGJRcDRuR1dQTVdzR E1ReUZkLzhLamZKd3FtVmJrcjBHUXFGYmc3ZlFvU1JOV3VoQg0KUS80LzFMN jdURUVZbWUrOUoxczNDTVFRUm0zOU5MdVhnOEgxN2dLODluTjFOOGVMQWJaM m1tSFh1cWwyUURWVWhuWngNCmE1aUJjeVF0b01JVU03VFpIYkg1S1pFVkRnb S8vU1NVc3diRkh4L0p6QkxldTV5WXhPSXpFOGJQY1JXcWRhR0RtY1pPDQpCV 2MvOWJmVU5PUGZPdGU0NE85anh0Y0l
Lc2txcDBKWm91SjVkZVlxZUJuNThabUt0SVUrMnB0anFXUVJKcEd5ckhEdQ0 KSzdDWEllMmJlKy8xRHpYUVArUmxibVJ6ZEhKbFlXMEtaVzVrYjJKcUNqWWd NQ0J2WW1vS01qQXhDbVZ1Wkc5aWFnbzANCklEQWdiMkpxQ2p3OEwxUjVjR1V 2VUdGblpTOU5aV1JwWVVKdmVDQmJNQ0F3SURZeE1pQTNPVEpkQ2k5U2IzUmh kR1VnDQpNQzlRWVhKbGJuUWdNeUF3SUZJS0wxSmxjMjkxY21ObGN6dzhMMUJ 5YjJOVFpYUmJMMUJFUmlBdlZHVjRkRjBLTDBWNA0KZEVkVGRHRjBaU0F4TUN Bd0lGSUtMMFp2Ym5RZ01URWdNQ0JTQ2o0K0NpOURiMjUwWlc1MGN5QTFJREF nVWdvK1BncGwNCmJtUnZZbW9LTXlBd0lHOWlhZ284UENBdlZIbHdaU0F2VUd GblpYTWdMMHRwWkhNZ1d3bzBJREFnVWdwZElDOURiM1Z1DQpkQ0F4Q2o0K0N tVnVaRzlpYWdveElEQWdiMkpxQ2p3OEwxUjVjR1VnTDBOaGRHRnNiMmNnTDF CaFoyVnpJRE1nTUNCUw0KQ2o0K0NtVnVaRzlpYWdvM0lEQWdiMkpxQ2p3OEw xUjVjR1V2UlhoMFIxTjBZWFJsQ2k5UFVFMGdNVDQrWlc1a2IySnENCkNqRXd JREFnYjJKcUNqdzhMMUkzQ2pjZ01DQlNQajRLWlc1a2IySnFDakV4SURBZ2I ySnFDanc4TDFJNUNqa2dNQ0JTDQpQajRLWlc1a2IySnFDamtnTUNCdlltb0t QRHd2UW1GelpVWnZiblF2VlVKWlFrRlFLME5OVWpFd0wwWnZiblJFWlhOag0 KY21sd2RHOXlJRGdnTUNCU0wxUjVjR1V2Um05dWRBb3ZSbWx5YzNSRGFHRnl JRFEyTDB4aGMzUkRhR0Z5SURFeE5TO
VgNCmFXUjBhSE5iSURJM09DQXdDakFnTlRBd0lEQWdNQ0F3SURBZ01DQXdJR EFnTUNBd0lEQWdNQ0F3SURBZ01Bb3dJREFnDQpNQ0F3SURBZ01DQXdJREFnT UNBd0lEQWdNQ0F3SURBZ01DQXdDakFnTUNBd0lEQWdOekl5SURBZ01DQXdJR EFnTUNBdw0KSURBZ01DQXdJREFnTUFvd0lEVXdNQ0F3SURBZ05UVTJJRFEwT kNBek1EWWdNQ0ExTlRZZ01qYzRJREFnTUNBeU56Z2cNCk9ETXpJREFnTUFvM U5UWWdNQ0F3SURNNU5GMEtMMFZ1WTI5a2FXNW5MMWRwYmtGdWMybEZibU52W kdsdVp5OVRkV0owDQplWEJsTDFSNWNHVXhQajRLWlc1a2IySnFDamdnTUNCd lltb0tQRHd2Vkhsd1pTOUdiMjUwUkdWelkzSnBjSFJ2Y2k5Rw0KYjI1MFRtR nRaUzlWUWxsQ1FWQXJRMDFTTVRBdlJtOXVkRUpDYjNoYk1DQXRNVGswSURne E15QTNNRFZkTDBac1lXZHoNCklEUUtMMEZ6WTJWdWRDQTNNRFVLTDBOaGNFa GxhV2RvZENBM01EVUtMMFJsYzJObGJuUWdMVEU1TkFvdlNYUmhiR2xqDQpRV zVuYkdVZ01Bb3ZVM1JsYlZZZ01USXhDaTlOYVhOemFXNW5WMmxrZEdnZ016T XpDaTlEYUdGeVUyVjBLQzlrTDNBdg0KWlM5bUwzQmxjbWx2WkM5ekwyZ3ZhU zl2Ym1VdlZDOXNMMkV2YlNrdlJtOXVkRVpwYkdVeklERXlJREFnVWo0K0NtV nUNClpHOWlhZ294TWlBd0lHOWlhZ284UEM5R2FXeDBaWEl2Um14aGRHVkVaV 052WkdVS0wxTjFZblI1Y0dVdlZIbHdaVEZEDQpMMHhsYm1kMGFDQXhOVEF5U Go1emRISmxZVzBLZUp5bGxIdE1VMmN
ZeHMvcDdSd1ZVZHVkTU1YMVZFUG1kV3pNS2JKbw0KTmlRd1VIR1JtM2V3UWd XMDVWSmFGUkN0Q05MeXRvQ2lsWXYyc3JhQUJVb0ZHaEh3cnRQb1dKZzZkWXZ Ud1RUNkJ6cW4NCmtxL2trTGlEeXJZczJ4L0xjazYrbkpPYzczM2Y1L2M4Mzh FeEhnZkRjVndRRmgwVDlOSEkwL3RlZjl3N2xlTjlqd3RNDQp3dEM1b1hnKyt IREJoK2VhS3ZoQmlGWlBRb3Nub01DSkdCZkhJNWF0RGN2TXlsV21wNmFwSkR QRFprbUNRa0tDSmFFSw0KbVRJOVdab2hpWmFxMG1RS3FZcDlrVXRpTTVQVFp hcmNRRW1vWEM2SkdkbVJJNG1SNWNpVTIyUXByMXVIWlNxeTFDcVoNClVoS2R tU0pUWm1BWU5qNGxTN1k1SnkwOVRpNVZCQVpoV0RpMkVvdkF2c0Rpc0Noc0t UWWZpOGFXWUN1d0NaZ1E4MlVsDQpZQVJXaWZ2anUvREhuQ291emMzai9zcjd nSGVKRC93bS91QXJQRG9lODMzRm1WT0dhYXhxajNleUZXMzJDSnZ2SVZPUA0 KbjJpbmQrSjVLb3BBTTR4OEp4Rys5MEEzN1gxQk1BRWF2cHo0cnJKb0xjM0l DVkYzUzhaR1I3dy9NM2I2TElaaVJFOW0NCklzRzFqdVpHTzQwc1BFWktRQzd vTkhtS2RZbnFqWkFJcVk2YzQ5bnQyb3ZRRG03RDVZWU9pL040MHpsd2dXZW5 NOUdZDQpCenJJSmQvTXdpUTQwVnlyZDdKSGFSY085cUxhZTM2aXV5Z01QYVF hVG5jM25BYnk1cFY1REo4Wkh4NGNtaXd6dDJmUg0KQlJiUWc1bU00MVhrZSt KdkE0bkd2WGlDS0NTYS9aVGhMWlltcWJmVG9vR2V0Nk5mUDFDY1JBK25FWWt haUJUTGlXYjkNCkdZTUQ2dUMwemxWS
09vbElEWFRRYUJIaCt3cnZ6c1kwZHFTd29DVld2UDRlS3V6aGVxZWdmTXBhQ nBhbjhRUE1KSWI4DQpNSUJkcDd5Y2pRamsyNEc0cGtON0Rmc0tkY1Y3ZFhSY VFCRHNnVFdRZkV6bFZuUkJEN1NRZWd1MUg4MjZiMjhHOHZraA0KeGorRlpsc 0VsV0hnOVBLZDZKUDdsVlljOFhvZTlYTlJoRGVBUWdJbk13YVJnbCs2dWs2V TFVQlJqWGgzU2U0dVVKS3ENCjJ1MTFEVFZtbTN0elUwTDRnb1JwWW9aWUpQK 1J1VE1xcDFYZmFhaUhOdWlFTmkzcDNFYUU2b3d0STUxS1dURlc3d0tUDQpzT 2tyVlJmS1p4Yy8wUU9VZ2hJb2E4bFArUkJHcms1TFhoeWNldkhuSFdKdFZXb jVIaUIzUVZFdXpieEw1RUdSc1VLdg0KTjVuRUJnTVlqcHBPU0R0S0xTeGk0d VMzTjg0cWp1MCtURzlwVEttVVZwS2lPN0hHeUtwTFUxeU85ajdFcVFpU0c4V DYNCndvTmdBTElLS2t6ME0rSUlITkRzMDhIdVhXSnR5WjdDRXEyc2ZoUHNCS kx4bFVYR3B0Vm0xcW5weHV6NjRoc0ZiMFBBDQprbmtkUnh4eGVwR3NsK3ZkZ 0NvbzZBT252S1hneUJielNnaUdwQy96VThsUzlFendsMVFPSHhsbDRkS2ZOd FNCQTg3bw0KbXYrMGRqbng0dnFGYTFlTjhURmlwdUJmdmx3RlNpZzl4bzZCV TVkZkcrUkI0d2VGdHdiRDJVUHhHSVY3VjFDTVpLVGYNCk53ZUwyVk5nSGEzU 3FEOW5zTEZ4ZHIycEVsVlMwVXFMbnBWN2oxT05Ta3VtWEoyVm5XWE5kdGJiT FkxaVZ1SDFoU09sDQpReXdvMUkyMzJGSGxBMVJwNXc0RkRvVlF3MGl3ZzFIe jdZSnFOTCttQ2MyQm8reG9oM1NXRXR
DQWloeTJFZWxRTUYyYw0KTEJlMGwvMEdKOW5yT2JTelppY1QwNkc2bWZiYUN EQkQ5ZEZ5SXl2SkJPejJtaTNWekh6U0xoalZNNFN6VExrOVhCUSsNCnRKVDZ SM0pOK3JNR085aWhXK2YrZzV5dlY2dXg1am5SVmt2ZHd5NnIwSE5uM1NNVTN IdlQ3aWZLMTZDKzIxUjVjcDIwDQpFMGpMbGVxNzlBVmxMTEZTV2F6WlV0SlJ JVWJyQ2ZCQWE2bzdwWFZON1RvZ1F5TFdSeW5NZVk3Nm8yYkg0WDFORy9SMA0 KbmF2YjJBaGs5OFdVaituTmhPaVVaclUyWEx0YzhYbTZjaFVra1o4T0tLLzJ uR3pyTkltTDBFSnFCakUzTEQxeDdTYlgNCnFmT2VleWhrUDR1U0d4ci94aVc xVllnNFY1ZVBwSVc5L1VRdXhFRURGR1A1MzRINHo5RkJzY1RmazVvbksrZ1B OU2JDDQpFbGkvTVRPYUZOMTZTVERUL21ELzFwdEJ2RytRaStMT1VnMDV0b3l Nbkp5TURGdE9RNFBOMWlCbThiTWEzYzRUWmh4bA0KZmM5Rm5VUHZVRFl3cU1 UUnkrYkJWaURsaEJtK2hqTU9jcmlHU05YdURoSnZsUXRjWmYzc3I2QU4rc0h GNW1NckVhUTENCnVtbGZ0WFhvTXl0VGR3UmxHQVhNcHNPRWMyenZPUEZZWHJ EWlo0ejFvSTlQcjlsblBJYjlEbnNDT2JnS1pXNWtjM1J5DQpaV0Z0Q21WdVp HOWlhZ295SURBZ2IySnFDanc4TDFCeWIyUjFZMlZ5S0VGR1VFd2dSMmh2YzN SelkzSnBjSFFnT0M0MQ0KTVNrS0wwTnlaV0YwYVc5dVJHRjBaU2hFT2pJd01 EWXdOVEkyTVRJME1UQXlLUW92VFc5a1JHRjBaU2hFT2pJd01EWXcNCk5USTJ NVEkwTVRBeUtRb3ZRM0psWVhSdmNpa
GtkbWx3YzF3b2Exd3BJRFV1T1RWaElFTnZjSGx5YVdkb2RDQXlNREExDQpJR kpoWkdsallXd2dSWGxsSUZOdlpuUjNZWEpsS1FvdlZHbDBiR1VvVTJOaGJsT mhiWEJzWlM1a2Rta3BQajVsYm1Sdg0KWW1vS2VISmxaZ293SURFekNqQXdNR EF3TURBd01EQWdOalUxTXpVZ1ppQUtNREF3TURBd01EVXlOQ0F3TURBd01DQ nUNCklBb3dNREF3TURBeU9ERTJJREF3TURBd0lHNGdDakF3TURBd01EQTBOa lVnTURBd01EQWdiaUFLTURBd01EQXdNRE13DQpOU0F3TURBd01DQnVJQW93T URBd01EQXdNREUxSURBd01EQXdJRzRnQ2pBd01EQXdNREF5T0RZZ01EQXdNR EFnYmlBSw0KTURBd01EQXdNRFUzTWlBd01EQXdNQ0J1SUFvd01EQXdNREF3T 1RnNElEQXdNREF3SUc0Z0NqQXdNREF3TURBMk56TWcNCk1EQXdNREFnYmlBS 01EQXdNREF3TURZeE15QXdNREF3TUNCdUlBb3dNREF3TURBd05qUXpJREF3T URBd0lHNGdDakF3DQpNREF3TURFeU1qa2dNREF3TURBZ2JpQUtkSEpoYVd4b GNnbzhQQ0F2VTJsNlpTQXhNeUF2VW05dmRDQXhJREFnVWlBdg0KU1c1bWJ5Q XlJREFnVWdvdlNVUWdXenhHTkVORE4wRkZRalUwUWpNMlJrSXlPRE5ETlVNe k1qUTNPVUZFTWpnelJqNDgNClJqUkRRemRCUlVJMU5FSXpOa1pDTWpnelF6V kRNekkwTnpsQlJESTRNMFkrWFFvK1BncHpkR0Z5ZEhoeVpXWUtNekF4DQpNZ 29sSlVWUFJnbz0NCiAgICAgIDwvdGV4dD4NCiAgICA8L25vblhNTEJvZHk+D QogIDwvY29tcG9uZW50Pg0KPC9DbGl
uaWNhbERvY3VtZW50Pg0K</xdsb:Document><xdsb:RepositoryUniqueId >1.19.6.24.109.42.1</xdsb:RepositoryUniqueId><xdsb:DocumentUniqueId >1.2.3.4.100000022002209036.1196211173506.1</xdsb:DocumentUniqueId ><xdsb:mimeType>text/xml</xdsb:mimeType></xdsb:DocumentResponse ></xdsb:RetrieveDocumentSetResponse>
> 1.19.6.24.109.42.1
> DEBUG - Success.
> <ActiveParticipant
> </AuditMessage>
> Activity"/>
> displayName="Application Stop"/>
> Launcher"/>
> </AuditMessage>
> entity.'
> well. The last 'ERRORS' are from my XSLT transformations.
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #40018 is a reply to message #39802] Tue, 08 January 2008 15:10 Go to previous message
Hi Sumedh,
I am running a new OHF build right now (will be out shortly) that adds
additional debug info into the document buffering in
retrieveDocumentSet. Hopefully this will allow us to pinpoint where the
data loss is happening. I have yet to reproduce the problem in Java 6,
so I'm still guessing here and hoping for the best.
There will be two spots where the document size is printed. Once is
immediately after the document extraction in B_XDSSoapClient, with a
line looking like this:
[DEBUG][B_XDSSoapClient.java:174] Extracted attachment with id
1.19.6.24.109.42.1 with size 9570.
The other is at the end of processing, after all document retrieves have
been buffered. This is after OHF is finished touching the documents and
no other changes happen before the return to the caller. It will look
something like this:
[DEBUG][B_Consumer.java:502] Received 1 documents in total
[DEBUG][B_Consumer.java:507] - Document #1
[ID=1.2.3.4.100000022002209036.1196211173506.1, REP=1.19.6.24.109.42.1,
SIZE=9570]
Please try running this again and post the results of your log. If the
value is incorrect on the first log message, I will know where to begin
to look. If it's different between the first and second log message,
I'll be a little more puzzled but will also have other places to look.
Thank you,
-Matt
> Thanks a bunch,
> -Matt
> Sumedh wrote:
>> Here you go:
>> Activity"/>
>> displayName="Application Launcher"/>
>> </AuditMessage>
E
Npd
ICA
5TT
ZGl
Fta
Y0l
5TO
MmN
xWS
RXR
Npa
bGl
>> 1.19.6.24.109.42.1
>> DEBUG - Success.
>> <ActiveParticipant
>> </AuditMessage>
>> Activity"/>
>> </AuditMessage>
>> entity.'
>> ERROR:
>> 'com.sun.org.apache.xml.internal.utils.WrappedRuntimeExcepti on: XML
>> regards,
>> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #583977 is a reply to message #39248] Thu, 27 December 2007 10:14 Go to previous message
Hi Sudemh,
-Matt
Sumedh wrote:
> Hi folks!
> Thanks guys.
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #583992 is a reply to message #39279] Thu, 27 December 2007 11:58 Go to previous message
Hey Matt,
Any ideas?
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #583999 is a reply to message #39310] Thu, 27 December 2007 16:57 Go to previous message
support shortly.
-Matt
Sumedh wrote:
> Hey Matt,
> Any ideas?
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584013 is a reply to message #39341] Fri, 28 December 2007 00:54 Go to previous message
Thanks.
somehow).
<code>
</code>
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584026 is a reply to message #39371] Sat, 29 December 2007 01:50 Go to previous message
dependency.
though :/
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584042 is a reply to message #39402] Sat, 29 December 2007 13:27 Go to previous message
issue for you.
-Matt
> dependency.
> for though :/
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584055 is a reply to message #39433] Thu, 03 January 2008 02:17 Go to previous message
Thanks.
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584064 is a reply to message #39464] Thu, 03 January 2008 11:28 Go to previous message
Connectathon.
-Matt
> Thanks.
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584092 is a reply to message #39495] Thu, 03 January 2008 13:56 Go to previous message
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584100 is a reply to message #39558] Thu, 03 January 2008 14:11 Go to previous message
Sumedh,
-Matt
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584150 is a reply to message #39589] Fri, 04 January 2008 02:42 Go to previous message
Here you go:
Activity"/>
Start"/>
Launcher"/>
</AuditMessage>
1.19.6.24.109.42.1
DEBUG - Success.
<ActiveParticipant
</AuditMessage>
Activity"/>
Stop"/>
Launcher"/>
</AuditMessage>
entity.'
regards,
Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584197 is a reply to message #39711] Fri, 04 January 2008 12:31 Go to previous message
Thanks a bunch,
-Matt
Sumedh wrote:
> Here you go:
> Activity"/>
> Launcher"/>
> </AuditMessage>
> 1.19.6.24.109.42.1
> DEBUG - Success.
> <ActiveParticipant
> </AuditMessage>
> Activity"/>
> Launcher"/>
> </AuditMessage>
> entity.'
> regards,
> Sumedh
Re: Document instance returned from retrieveDocumentSet() has incomplete data [message #584286 is a reply to message #39802] Tue, 08 January 2008 15:10 Go to previous message
Hi Sumedh,
SIZE=9570]
Thank you,
-Matt
> Thanks a bunch,
> -Matt
> Sumedh wrote:
>> Here you go:
>> Activity"/>
>> </AuditMessage>
E
Npd
ICA
5TT
ZGl
Fta
Y0l
5TO
MmN
xWS
RXR
Npa
bGl
>> 1.19.6.24.109.42.1
>> DEBUG - Success.
>> <ActiveParticipant
>> </AuditMessage>
>> Activity"/>
>> </AuditMessage>
>> entity.'
>> ERROR:
>> regards,
>> Sumedh
Previous Topic:Setting "NetworkAccessPointID" on the ActiveParticipant in ATNA messages
Next Topic:Folder creation
Current Time: Tue Jul 22 02:40:48 EDT 2025
Powered by FUDForum. Page generated in 0.15072 seconds
