Home » Modeling » OCL » Re: OCL Help
Re: OCL Help [message #3396] Sat, 03 February 2007 12:26 Go to next message
--------------030302080200020605060603
Ole,
There's an OCL newsgroup which I've added to the to list.
You'll likely be interested in this article Christian wrote:
http://www.eclipse.org/articles/Article-EMF-Codegen-with-OCL /article.html
The sexier/interesting approach probably won't perform quite as well.
Ole Ersoy wrote:
> I hope this is the right place to ask.
> I have an EOperation that generates code like this
> (I filled in the implementation):
> * <!-- begin-user-doc -->
> * <!-- end-user-doc -->
> * @generated NOT
> public Mapping getTargetMapping(EObject sourceEObject) {
> EClass sourceEClass = sourceEObject.eClass();
> return getEClass2MappingMap().get(sourceEClass);
> So this works, but OCL is sexier.
> Anyone know how to write the OCL does implements the body?
> self.eClass2MappingMap()....
> - Ole
<html>
<head>
http-equiv="Content-Type">
</head>
Ole,<br>
<br>
Re: OCL Help [message #3430 is a reply to message #3396] Sat, 03 February 2007 14:26 Go to previous messageGo to next message
Originally posted by: ole_ersoy.yahoo.com
Ed,
Terrific - Thanks. Yes - I love that article. It's my inspiration for
trying out OCL.
I'll probably just keep the hand coded version in the end though.
Would be cool if EMF generated
the hand written version of the OCL.
I just need 48 hours more in the day for that.
Thanks again,
- Ole
Re: OCL Help [message #3464 is a reply to message #3430] Sat, 03 February 2007 15:05 Go to previous messageGo to next message
Ole,
If I can find the time, at some point I'll try to find a way to be able
to support this via extension points so that any expression language
could be plugged in...
Ole Ersoy wrote:
> Ed,
> for trying out OCL.
> Would be cool if EMF generated the hand written version of the OCL.
> Thanks again,
> - Ole
Re: OCL Help [message #3497 is a reply to message #3430] Mon, 05 February 2007 12:12 Go to previous messageGo to next message
Hi, Ole,
Thanks! I'm glad that you enjoyed that article. You may be interested to
know that I am working on an update for the M5 milestone of OCL, which
illustrates the new generic API (based on the J2SE 5.0 support of EMF 2.3).
Unfortunately, your particular EOperation poses a problem for OCL, as it is
not currently capable of accessing operations such as eClass() unless your
model types explicitly subclass EObject (in your ecore model, not just in
code). See https://bugs.eclipse.org/bugs/show_bug.cgi?id=152003 for
details of that, and various posts in this newsgroup and its predecessors
discussing the addition of custom attributes and operations (such as
eClass()) into the OCL environment:
http://wiki.eclipse.org/index.php/CustomizingOclEnvironments
Previous history of this newsgroup is available in the HTML archives, under
the IDs eclipse.modeling.mdt.uml2.ocl and eclipse.technology.emft.
As Ed indicates, for a high-performance API, you probably want to stick with
Java or else devise codegen extensions that will transform OCL expressions
into (efficient) Java code. However, OCL is very good for providing an
abstract and portable *specification* of your constraints and for testing
that they really are what you want them to be before you make the effort of
writing Java code. Even with the annotations implemented in the article,
you can use @generated NOT to override the OCL with your Java
implementation. :-)
Christian
Ole Ersoy wrote:
> Ed,
> trying out OCL.
> Thanks again,
> - Ole
Re: OCL Help [message #3563 is a reply to message #3464] Mon, 05 February 2007 23:15 Go to previous message
Ed,
Sounds great. I'd love to help out with that as well. I'm almost done
with the Ecore2Ecore excercise. Hope to have something well tested on
Bugzilla tomorrow.
Then I just have to finish up this Maven RPM Factory thing that the
Ecore2Ecore stuff is going to be used for, and after that I'm diving in
to the method generation head first :-)
- Ole
Previous Topic:Getting started questions from the mailing list
Next Topic:[Announce] EclipseCon 2007 Registration
Current Time: Sun May 11 18:37:30 EDT 2025
Powered by FUDForum. Page generated in 0.04606 seconds
