JVM [message #39200] |
Tue, 20 May 2003 04:02  |
Originally posted by: dylan.browne.btinternet.com
I have a machine running Java 1.2.0, (which I have to maintain to monitor
old code), but I want to run the latest Eclipse on it. I tried installing
Java 1.4, pointing Eclipse at that, but now of course, my default Java
version is 1.4 and not 1.2.0 as required. Can anyone help with how I can
run the two side by side.
Thanks in advance.
DB
Re: JVM [message #52693 is a reply to message #39200] |
Wed, 28 May 2003 18:42  |
Originally posted by: John_Arthorne.oti.com_
Unzip the 1.4 VM somewhere that it is not on your system path. Then
launch Eclipse by pointing it explicitly at the 1.4 VM, for example:
eclipse -VM d:\jdk1.4\jre\bin\javaw.exe
That way other programs will still see the Java 1.2 on your path, but
Eclipse will see the 1.4 VM.
DB wrote:
> Thanks in advance.
> DB
FUDForum. Page generated in 0.04598 seconds
