Home » Modeling » M2T (model-to-text transformation) » JET2 Custom tags problem
JET2 Custom tags problem [message #39104] Thu, 10 January 2008 09:14 Go to next message
Originally posted by: jahincapie.avansoft.com
Hi everybody,
I know that a lot of messages about this very same topic have been posted
already, and believe me when I tell you that I've been searching for a week
or more within these posts. I've follow all the steps described in some of
those posts to create a custom tag library; however it hasn't work at all.
Here is what I've done:
1. I have a JET plug-in project in which I created the custom tag:
- There is an extension in org.eclipse.jet.tagLibraries in which a
functionTag is defined
- This tagLibrary is added to the tagLibraries element in the
org.eclipse.jet.transform extension within the same plug-in, with the option
autoImport=true
- This plug-in wag exported as a .jar, so it can be used in another
plug-in extension.
2. There is another plug-in that has an extension in
org.eclipse.jet.deployedTransforms referencing the .jar generated for the
above mentioned plug-in
Now, the problem is that when I put the custom tag in the template... the
JET engine doesn't recognize it, so instead of getting what is coded in the
class implementing the tag, I get the tag definition in the generated file.
So, if anyone can give me some help, I would appreciate it a lot
Thanks.
Andr
Re: JET2 Custom tags problem [message #39753 is a reply to message #39104] Tue, 15 January 2008 09:23 Go to previous messageGo to next message
Andr
Re: JET2 Custom tags problem [message #42647 is a reply to message #39753] Wed, 05 March 2008 10:02 Go to previous messageGo to next message
Paul,
I seem to be having the same issue that Andres had.. But my Custom Tags are
deployed as a plugin in the Eclipse plugins directory...
What I have is MyCustomTags.jar and MyJetTemplates.jar plugins installed in
Eclipse.
In my workspace I have a project (MyJetExtensions) which extends the
MyJetTemplates project. Both MyJetTemplates and MyJetExtensions both
reference the Custom tags plugin. Running the MyjetTemplates on my
model works fine. Running MyJetExtensions on the model produces the "errors"
Any advice would be greatly appreciated..
Gary
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:fmifnd$e0o$1@build.eclipse.org...
> Andr
Re: JET2 Custom tags problem [message #42708 is a reply to message #42647] Wed, 05 March 2008 11:17 Go to previous messageGo to next message
Gary:
JET may not be importing tag libraries the way you expect. In particular, it
DOES NOT used the standard plug-in dependency mechanism.
Rather, you need to modify plugin.xml in MyJetTemplates to include a tag
library reference via an importLibrary element. You need to provide the
fully qualified tag library ID (plug-in ID + . + ID declared in the
tagLibraries extension point). Here's a typical example.
<plugin>
<extension
id=""
name=""
point="org.eclipse.jet.transform">
<transform
startTemplate="templates/main.jet"
templateLoaderClass="org.eclipse.jet.compiled._jet_transformation "
<description></description>
<tagLibraries>
<importLibrary id="org.eclipse.jet.controlTags" usePrefix="c"
autoImport="true"/>
<importLibrary id="org.eclipse.jet.javaTags" usePrefix="java"
autoImport="true"/>
<importLibrary id="org.eclipse.jet.formatTags" usePrefix="f"
autoImport="true"/>
<importLibrary id="org.eclipse.jet.workspaceTags" usePrefix="ws"
autoImport="false"/>
<importLibrary id="your-tag-plug-in-id.your-taglib-id"
usePrefix="your-prefix" autoImport="true"/>
</tagLibraries>
</transform>
</extension>
</plugin>
Hope this helps.
Paul
"Gary Pinkham" <gpinkham@kronos.com> wrote in message
news:fqmcna$7js$1@build.eclipse.org...
> Paul,
> are deployed as a plugin in the Eclipse plugins directory...
> in Eclipse.
> "errors"
> Gary
>> Andr
Re: JET2 Custom tags problem [message #42739 is a reply to message #42708] Wed, 05 March 2008 11:27 Go to previous messageGo to next message
I actually copied the importLibrary from the 1st Jet plugin (which does work
(deployed as a plugin jar as well)...
What I copied was this:
<importLibrary id="com.foo.jet.common.taglib.control" usePrefix="custom"
autoImport="true"/>
As I mentioned it seems to work for the original Jet plugin but not the
extension...
Thanks!
Gary
news:fqmh58$skb$1@build.eclipse.org...
> Gary:
> it DOES NOT used the standard plug-in dependency mechanism.
> <plugin>
> <extension
> id=""
> name=""
> <transform
> <tagLibraries>
> autoImport="true"/>
> autoImport="true"/>
> autoImport="true"/>
> usePrefix="ws" autoImport="false"/>
> </tagLibraries>
> </transform>
> </extension>
> </plugin>
> Hope this helps.
> Paul
>> Paul,
>> in Eclipse.
>> "errors"
>> Gary
>>> Andr
Re: JET2 Custom tags problem [message #43828 is a reply to message #42739] Wed, 26 March 2008 10:43 Go to previous message
Gary:
Can you setup a small test case and submit a bugzilla? That should help me
get to the bottom of this.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org
Paul
news:fqmhku$2um$1@build.eclipse.org...
>work (deployed as a plugin jar as well)...
> autoImport="true"/>
> extension...
> Thanks!
> Gary
>> Gary:
>> <plugin>
>> <extension
>> id=""
>> name=""
>> <transform
>> <tagLibraries>
>> autoImport="true"/>
>> autoImport="true"/>
>> autoImport="true"/>
>> </tagLibraries>
>> </transform>
>> </extension>
>> </plugin>
>> Hope this helps.
>> Paul
>>> Paul,
>>> in Eclipse.
>>> "errors"
>>> Gary
>>>> Andr
Previous Topic:UML Activities and Jet
Next Topic:Jet editor advertising
Current Time: Thu Jul 17 19:44:17 EDT 2025
Powered by FUDForum. Page generated in 0.10063 seconds
