Home » Language IDEs » C / C++ IDE (CDT) » eclipse internal error with gdb project
eclipse internal error with gdb project [message #39050] Thu, 01 August 2002 13:19 Go to next message
Originally posted by: sid.x.com
I decided to use eclipse for a project that I'm working on, I'm porting
GDB to a new processor target, and I get out of memory errors. These
errors sometimes are so bad that I need to re-install eclipse before it
will startup again. I believe that anyone can reproduce what I'm doing by
going to ftp.gnu.org and getting gdb5.2 source. I configure it for my
target but that is not necessary to see the problem. I created a Makefile
at the root of my patchtree which looks like this:
DIRS := obj_lx86
dirs: $(DIRS)
cd $(DIRS); make all
all: dirs
clean:
cd $(DIRS); make clean;
At this level I have three items in my directory, the above Makefile, a
obj_lx86 directory where the built objects reside, and a gdb-5.2 diretory
where the source resides.
I create an eclipse "C" "Standard Make C Project" project. Eclipse then
goes ahead and builds the tree. When I try to browse the source I get out
of memory errors.
I've tried both IBM's java and Sun's java and I've attached the .log from
runs with both version of java.
!SESSION Aug 01, 2002 11:36:39.44
java.fullversion=J2RE 1.3.0 IBM build cx130-20010925 (JIT enabled: jitc)
BootLoader constants: OS=linux, ARCH=x86, WS=motif, NL=en_US
Command-line arguments: -os linux -ws motif -arch x86 -install
file:/home/sid/eclipse/eclipse2/
!ENTRY org.eclipse.ui 4 4 Aug 01, 2002 11:36:39.45
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Aug 01, 2002 11:36:43.403
!MESSAGE java.lang.OutOfMemoryError
!STACK 0
!ENTRY org.eclipse.ui 4 4 Aug 01, 2002 11:36:50.385
!ENTRY org.eclipse.ui 4 0 Aug 01, 2002 11:36:50.388
!STACK 0
!ENTRY org.eclipse.ui 4 2 Aug 01, 2002 11:36:56.905
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui".
!STACK 0
org.eclipse.cdt.internal.ui.editor.CEditor$AdaptedSourceView er$VerifyKeyListenersManager.uninstall(CEditor.java:1501)
org.eclipse.cdt.internal.ui.editor.CEditor$AdaptedSourceView er$VerifyKeyListenersManager.removeListener(CEditor.java:148 5)
org.eclipse.cdt.internal.ui.editor.CEditor$AdaptedSourceView er.removeVerifyKeyListener(CEditor.java:1528)
org.eclipse.ui.texteditor.AbstractTextEditor$ActivationCodeT rigger.uninstall(AbstractTextEditor.java:535)
org.eclipse.ui.texteditor.AbstractTextEditor.dispose(Abstrac tTextEditor.java:1905)
at org.eclipse.cdt.internal.ui.editor.CEditor.dispose(CEditor.j ava:598)
at org.eclipse.ui.internal.WorkbenchPage$5.run(WorkbenchPage.ja va:902)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:831)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:900)
org.eclipse.ui.internal.WorkbenchPage.closeAllEditors(Workbe nchPage.java:661)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:919)
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:406)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:871)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:322)
org.eclipse.ui.internal.WorkbenchWindow.access$3(WorkbenchWi ndow.java:311)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:367)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:365)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:103)
at org.eclipse.ui.internal.Workbench$2.run(Workbench.java:202)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1 73)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:15 0)
at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:291)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:289)
org.eclipse.ui.internal.ExceptionHandler.closeWorkbench(Exce ptionHandler.java:109)
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:88)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:560 )
at org.eclipse.jface.window.Window.open(Window.java:537)
org.eclipse.ui.internal.dialogs.InternalErrorDialog.open(Int ernalErrorDialog.java:65)
org.eclipse.ui.internal.dialogs.InternalErrorDialog.openQues tion(InternalErrorDialog.java:166)
org.eclipse.ui.internal.ExceptionHandler.openQuestionDialog( ExceptionHandler.java:187)
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:92)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1180)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1160)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:248)
at org.eclipse.core.launcher.Main.run(Main.java:698)
at org.eclipse.core.launcher.Main.main(Main.java:534)
!ENTRY org.eclipse.ui 4 4 Aug 01, 2002 11:39:37.504
!MESSAGE Problems saving workspace
!ENTRY org.eclipse.ui 4 1 Aug 01, 2002 11:39:37.505
!MESSAGE Problems occurred while trying to save the state of the workbench.
!SUBENTRY 1 org.eclipse.ui 4 1 Aug 01, 2002 11:39:37.506
!MESSAGE Internal Error
!STACK 0
!SESSION Aug 01, 2002 11:45:53.457
java.version=1.3.1_02
!ENTRY org.eclipse.ui 4 4 Aug 01, 2002 11:45:53.459
!ENTRY org.eclipse.ui 4 0 Aug 01, 2002 11:45:53.463
!STACK 0
<<no stack trace available>>
!ENTRY org.eclipse.ui 4 2 Aug 01, 2002 11:46:04.266
"org.eclipse.ui".
!STACK 0
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:94)
!ENTRY org.eclipse.ui 4 4 Aug 01, 2002 11:46:10.790
!ENTRY org.eclipse.ui 4 1 Aug 01, 2002 11:46:10.792
!SUBENTRY 1 org.eclipse.ui 4 1 Aug 01, 2002 11:46:10.793
!STACK 0
Re: eclipse internal error with gdb project [message #39078 is a reply to message #39050] Thu, 01 August 2002 13:39 Go to previous messageGo to next message
sid manning wrote:
BTW: from the log file you might think that my system just ran out of
memory, but that is not the case. I never use > 66% of my system memory
while this operation is underway.
Re: eclipse internal error with gdb project [message #39108 is a reply to message #39078] Fri, 02 August 2002 04:26 Go to previous message
Originally posted by: g.wagenknecht.intershop.de
"sid manning" <sid@x.com> schrieb im Newsbeitrag
news:aibroh$e12$1@rogue.oti.com...
Did you try to start eclipse telling the JVM to use more memory? Default is
only 64MB. You can pass JVM arguments to the eclipse executable useing
parameter "-vmargs -Xmx256m -Xms256m" (this will allow eclipse to take a
maximum of 256 MB heap size).
Cu, Gunnar
Previous Topic:code assist?
Next Topic:Wow to use eclipse.cdt together with IBMs z/OS C/C++ productivity toolkit
Current Time: Tue Jul 22 07:34:13 EDT 2025
Powered by FUDForum. Page generated in 0.03330 seconds
