Home » Archived » Visual Editor (VE) » VE1.0M1 problems with GridBagLayout
VE1.0M1 problems with GridBagLayout [message #39009] |
Wed, 26 May 2004 16:20  |
I have just installed VE1.0M1. I defined a panel with a GridBagLayout and
placed a Swing Component on that panel. Now I'm wondering why for that
Swing component the constraint can't be changed on the properties tab. Is
this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39126 is a reply to message #39095] |
Wed, 26 May 2004 17:01   |
Let me guess, you're running Eclipse on Linux GTK? The +/- buttons on
the property sheet don't work due to a nasty SWT/GTK bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38855
Unfortunately until it's fixed, you'll need to edit the weights from the
source. The fill property can be changed in the alignment dialog.
Please consider adding a comment to that bugzilla bug, stating your OS
version and gtk level, so we'll have one more voice stating that it
doesn't work for them.
- Jeff
exquisitus wrote:
> Hi Jeff,
> yes, I tried to expand the constraint property on the Properties view by
> clicking on the +, but it was not expanded. I wanted to change the fill,
> the weightx and weighty property but was not allowed to do it. What's
> wrong, any idea?
> exqusitus
> Jeff Myers wrote:
>>Er, whoops, it's still called the Alignment Window in M1, not Customize
>>Layout. ;)
>> - Jeff
>>Jeff Myers wrote:
>>>Are you expanding the contstraint property on the Properties view? Which
>>>particular constraint field can't you set?
>>>You might also want to look at the Customize Layout window for easier
>>>manipulation of a component's constraints.
>>> - Jeff
>>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39157 is a reply to message #39126] |
Wed, 26 May 2004 16:59   |
Hi Jeff,
great guess! You're absolutely right. I'm using Linux GTK.
Although my problem is not fixed, I will add a comment to the bugzilla bug
you've mentioned.
thanks,
exquisitus
> - Jeff
> exquisitus wrote:
> > Hi Jeff,
> > wrong, any idea?
> > exqusitus
> >>Layout. ;)
> >> - Jeff
> >>> - Jeff
> >>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39187 is a reply to message #39126] |
Wed, 26 May 2004 17:17  |
Actually there's a keyboard shortcut available. Select the constraint
property on the property sheet, and press "Shift +" This will expand the
property sheet item. Pressing the "-" key will collapse the item.
- Jeff
> - Jeff
> exquisitus wrote:
>> Hi Jeff,
>> wrong, any idea?
>> exqusitus
Re: VE1.0M1 problems with GridBagLayout [message #590817 is a reply to message #39009] |
Wed, 26 May 2004 16:30  |
Which particular constraint field can't you set?
- Jeff
> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590838 is a reply to message #39042] |
Wed, 26 May 2004 16:31  |
Layout. ;)
- Jeff
> - Jeff
>> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590848 is a reply to message #39069] |
Wed, 26 May 2004 16:45  |
Hi Jeff,
wrong, any idea?
exqusitus
> Layout. ;)
> - Jeff
> > - Jeff
> >> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590859 is a reply to message #39095] |
- Jeff
exquisitus wrote:
> Hi Jeff,
> wrong, any idea?
> exqusitus
>>Layout. ;)
>> - Jeff
>>> - Jeff
>>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590865 is a reply to message #39126] |
Hi Jeff,
you've mentioned.
thanks,
exquisitus
> - Jeff
> exquisitus wrote:
> > Hi Jeff,
> > wrong, any idea?
> > exqusitus
> >>Layout. ;)
> >> - Jeff
> >>> - Jeff
> >>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590876 is a reply to message #39126] |
- Jeff
> - Jeff
> exquisitus wrote:
>> Hi Jeff,
>> wrong, any idea?
>> exqusitus
Current Time: Wed Jul 16 18:04:52 EDT 2025
Powered by FUDForum. Page generated in 0.05738 seconds
