Home » Eclipse Projects » Remote Application Platform (RAP) » encoding problem in Tomcat
encoding problem in Tomcat [message #38943] |
Tue, 17 July 2007 08:52  |
I have a small problem with my RAP Application deploying in a Tomcat
servlet container. The application works fine with Eclipse in the Jetty
container under Win XP. But when I deploy the application to a Linux
Box with Tomcat 5.5 the german umlauts which are coded in the Application
i.e. a Text of a Tab are not displayed correctly.
Any hints would be appreciated.
Tom
Re: encoding problem in Tomcat [message #111612 is a reply to message #39694] |
Fri, 07 November 2008 10:10   |
Originally posted by: benjamin.wolff.web.de
sorry for this 'gravedigging' :).
Since i'm also experiencing encoding problems now, there are some questions i'd
like to ask.
the internal standard encoding of RAP is UTF-8, right? looking at the sourcecode
of a RAP app in the browser there is a meta tag that defines UTF-8 as encoding:
<meta http-equiv="content-type" content="text/html; charset=UTF-8">
the problem is, i realised these encoding issues too late and coded my
applications with ISO-8859-1. is there a common way to convert to utf-8 encoding?
just changing the encoding of the workspace results in scrambled german 'umlauts'
like ö, ä, ü... or is there only the search/replace mechanism?
i guess the suggested approach is to switch to utf-8 for all future applications?
how do you handle your encoding issues, what encoding do you use with which
environment (os, servlet container, browser configuration)?
on the other hand, since tomcat uses iso-8859-1 by default, is it possible to
change the RAP encoding for the generated html pages? would it make sense, what
would be the impact?
i'd really like to hear your advices and experience about this issue because it
can be very very annoying and causes lots of trouble atm ://.
Greetings,
-Ben
Thomas Kühne schrieb:
> I am sorry, but I can't work out my problem. Does anybody got another hint
> for
> my encoding Problem?
> Regars,
> Thomas
> "RAP" <tom@code.de> schrieb im Newsbeitrag
> news:f7iqsk$a0r$1@build.eclipse.org...
>> hmm, I read the forum entry's but they don't solve my problem. I added
>> URIEncoding="UTF-8" to my connector
>> setting for port 8080 and AJP. It ist strange that strings which I request
>> via a SOAP Request from another server
>> are correctly displayed (they are UTF-8 encoded). But strings which came
>> out of the java code or a properties file
>> are not encoded correctly.
>> Bug 187895 says :
>> "If I compile in Windows with cp1232 or in MacOS with MacRoman then all
>> works
>> fine and all my problems are out."
>> What does this mean compile with cp1232? As i know cp1232 is a kind of
>> character encoding.
>> Sorry, I never heard this before.
>> Regards,
>> Tom
>> "Rüdiger Herrmann" <rherrmann@innoopract.com> schrieb im Newsbeitrag
>> news:f7iej5$6qa$1@build.eclipse.org...
>>> Tom,
>>> does one of these hits solve your problem?
>>> http://www.eclipse.org/search/search.cgi?q=encoding&cmd= Search%21&form=extended&wf=574a74&ps=10&m=al l&t=5&ul=%2Fnewslists%2Fnews.eclipse.technology.rap& amp;wm=wrd&t=News&t=Mail
>>> Cheers,
>>> Rüdiger
>>> RAP wrote:
>>>> Hi,
>>>> Application
>>>> Regards,
>>>> Tom
Re: encoding problem in Tomcat [message #111995 is a reply to message #111612] |
Mon, 10 November 2008 12:56   |
Originally posted by: rherrmann.innoopract.com
Ben W. wrote:
> Hello,
> questions i'd like to ask.
> sourcecode of a RAP app in the browser there is a meta tag that defines
> UTF-8 as encoding:
> encoding? just changing the encoding of the workspace results in
> scrambled german 'umlauts' like ö, ä, ü... or is there only the
Currently, UTF-8 is used to encode text that is transferred between
client and server.
There is no need to convert your resources.
As long as your text resources are registered with the correct
charset, everything should work. See the JavaDoc of IResource for
example.
> applications? how do you handle your encoding issues, what encoding do
> you use with which environment (os, servlet container, browser
> configuration)?
> possible to change the RAP encoding for the generated html pages? would
> it make sense, what would be the impact?
AFAIK, tomcat does not have its own default encoding. It uses the
default VM encoding.
> because it can be very very annoying and causes lots of trouble atm ://.
> Greetings,
> -Ben
>> hint for
>> Regars,
>> Thomas
>>> Hi,
>>> added URIEncoding="UTF-8" to my connector
>>> request via a SOAP Request from another server
>>> came out of the java code or a properties file
>>> Bug 187895 says :
>>> all works
>>> of character encoding.
>>> Regards,
>>> Tom
>>>> Tom,
>>>> Cheers,
>>>> Rüdiger
>>>> RAP wrote:
>>>>> Hi,
>>>>> Jetty
>>>>> Application
>>>>> Regards,
>>>>> Tom
Re: encoding problem in Tomcat [message #112146 is a reply to message #111995] |
Tue, 11 November 2008 09:33   |
Hello again,
to describe the problem that i had: i used to develop the RAP application with
windows on my desktop pc, then i used my notebook (which is running linux) to do
some "field-deploying" of the RAP app. i converted all my projectfiles from the
cp1251 windows encoding to utf-8 and configured the workspace in eclipse to use
utf-8 encoding on both machines. the result was that all characters were
displayed correctly in the eclipse editors and when running the app inside
eclipse (run as...).
when i used the feature to deploy the rap in linux and put it on the tomcat
server everything was fine, doing the same with windows resulted in garbled
special-chars.
long story short, under linux, the 'compiled' .class files were created using
linux default encoding, so i had utf-8 encoded files 'compiled' with utf-8.
under windows the feature always seemed to use the cp1251 encoding to create the
..class files for deployment. so i had utf-8 files 'compiled' with cp1251, that
couldn't work of course. there was absolutely no setting or compiler flag inside
of eclipse that solved the problem under windows. the solution was rather simple,
nevertheless i found it more or less by accident :). to solve such encoding
issues i simply needed to add -Dfile.encoding=UTF-8 to the eclipse.ini or as a
startparameter to the eclipse link.
now the problem seems to be solved, running the deploy ant script from the
feature on both, linux and windows environments, and putting it on the tomcat
server show the same (correct) results regarding the character-encoding. so i
think this can be made official:
start eclipse with -Dfile.encoding=UTF-8 so solve these encoding problems when
cross-developing on different platforms!!!!
just adjust the workspace encoding or content types in the eclipse preferences
didn't work for me!
if this is a common solution already, sorry, but then it's really rarely
mentioned ;))
HTH,
Ben
Rüdiger Herrmann schrieb:
> Ben W. wrote:
>> Hello,
>> utf-8 encoding? just changing the encoding of the workspace results in
> client and server.
> As long as your text resources are registered with the correct charset,
> everything should work. See the JavaDoc of IResource for example.
>> configuration)?
>> would it make sense, what would be the impact?
>> Greetings,
>> -Ben
>>> Hi,
>>> hint for
>>> Regars,
>>> Thomas
>>>> Hi,
>>>> Bug 187895 says :
>>>> all works
>>>> Regards,
>>>> Tom
>>>>> Tom,
>>>>> Cheers,
>>>>> Rüdiger
>>>>> RAP wrote:
>>>>>> Hi,
>>>>>> Jetty
>>>>>> Application
>>>>>> Regards,
>>>>>> Tom
Re: encoding problem in Tomcat [message #112264 is a reply to message #112146] |
Wed, 12 November 2008 08:50   |
Ben,
you are right in that this pitfall should be documented. I think the
WAR deployment tutorial would be the right place.
However, I doubt that your solution is suitable for general use. A
general purpose documentation should rather point out how to tell
the compiler (that is invoked somewhere during PDE build) how the
source files are encoded.
Feel free to file an enhancement request.
Rüdiger
Ben W. wrote:
> Hello again,
> application with windows on my desktop pc, then i used my notebook
> (which is running linux) to do some "field-deploying" of the RAP app. i
> converted all my projectfiles from the cp1251 windows encoding to utf-8
> and configured the workspace in eclipse to use utf-8 encoding on both
> machines. the result was that all characters were displayed correctly in
> the eclipse editors and when running the app inside eclipse (run as...).
> tomcat server everything was fine, doing the same with windows resulted
> in garbled special-chars.
> using linux default encoding, so i had utf-8 encoded files 'compiled'
> with utf-8.
> create the ..class files for deployment. so i had utf-8 files 'compiled'
> with cp1251, that couldn't work of course. there was absolutely no
> setting or compiler flag inside of eclipse that solved the problem under
> windows. the solution was rather simple, nevertheless i found it more or
> less by accident :). to solve such encoding issues i simply needed to
> add -Dfile.encoding=UTF-8 to the eclipse.ini or as a startparameter to
> the eclipse link.
> the feature on both, linux and windows environments, and putting it on
> the tomcat server show the same (correct) results regarding the
> character-encoding. so i think this can be made official:
> problems when cross-developing on different platforms!!!!
> preferences didn't work for me!
> mentioned ;))
> HTH,
> Ben
>> Ben W. wrote:
>>> Hello,
>>> my applications with ISO-8859-1. is there a common way to convert to
>>> in scrambled german 'umlauts' like ö, ä, ü... or is there only the
>> client and server.
>> example.
>>> do you use with which environment (os, servlet container, browser
>>> configuration)?
>>> Greetings,
>>> -Ben
>>>> Hi,
>>>> another hint for
>>>> Regars,
>>>> Thomas
>>>>> Hi,
>>>>> Bug 187895 says :
>>>>> all works
>>>>> Regards,
>>>>> Tom
>>>>> Newsbeitrag news:f7iej5$6qa$1@build.eclipse.org...
>>>>>> Tom,
>>>>>> Cheers,
>>>>>> Rüdiger
>>>>>> RAP wrote:
>>>>>>> Hi,
>>>>>>> Jetty
>>>>>>> Application
>>>>>>> Regards,
>>>>>>> Tom
Re: encoding problem in Tomcat [message #112429 is a reply to message #112264] |
Fri, 14 November 2008 11:08  |
yes, of course, this would be the more appropriate solution. but so far
i couldn't figure out how to pass this parameter to the pde build compiler :).
if someone may figure it out, i'd love to hear it :).
greetings,
-ben
> Ben,
> general purpose documentation should rather point out how to tell the
> compiler (that is invoked somewhere during PDE build) how the source
> files are encoded.
> Cheers,
> Rüdiger
> Ben W. wrote:
>> Hello again,
>> i converted all my projectfiles from the cp1251 windows encoding to
>> utf-8 and configured the workspace in eclipse to use utf-8 encoding on
>> both machines. the result was that all characters were displayed
>> resulted in garbled special-chars.
>> created using linux default encoding, so i had utf-8 encoded files
>> 'compiled' with cp1251, that couldn't work of course. there was
>> absolutely no setting or compiler flag inside of eclipse that solved
>> encoding issues i simply needed to add -Dfile.encoding=UTF-8 to the
>> eclipse.ini or as a startparameter to the eclipse link.
>> rarely mentioned ;))
>> HTH,
>> Ben
>>> Ben W. wrote:
>>>> Hello,
>>>> the sourcecode of a RAP app in the browser there is a meta tag that
>>> client and server.
>>> example.
>>>> configuration)?
>>>> Greetings,
>>>> -Ben
>>>>> Hi,
>>>>> another hint for
>>>>> Regars,
>>>>> Thomas
>>>>>> Hi,
>>>>>> which came out of the java code or a properties file
>>>>>> Bug 187895 says :
>>>>>> then all works
>>>>>> kind of character encoding.
>>>>>> Regards,
>>>>>> Tom
>>>>>>> Tom,
>>>>>>> Cheers,
>>>>>>> Rüdiger
>>>>>>> RAP wrote:
>>>>>>>> Hi,
>>>>>>>> Tomcat
>>>>>>>> the Jetty
>>>>>>>> Linux
>>>>>>>> Application
>>>>>>>> Regards,
>>>>>>>> Tom
Current Time: Fri Jul 25 10:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.27179 seconds
