Home » Language IDEs » AspectJ » Feedback on AJDT 1.1.11
Feedback on AJDT 1.1.11 [message #38940] |
Wed, 21 July 2004 18:18  |
These days I have been trying AJDT 1.1.11 to see if I can use it in my
project.
I had a couple of problems:
- (with incremental build and automatic buildturned on) If I invoke the
build command with the toolbar button, I first get a foreground
progress dialog that keeps me informed of the completion of the build
process; no problem so far, but once it finishes to compile and weave, a
background build process is launched. If I open the Progress view, I see
that an AspectJ build is in progress, bu there is no information about
progress (ie. the progress bar stays at 0%). After a minute or two of
build process, the item disappears form the progress view for a short
instant, and then reappears. I don't know if it means that it started
over again or not, as there is no progress indication. This occurs
several times, I didn't have the patience to wait until it all stopped...
- (with automatic build on, incremental build off): the AspectJ build
process is invoked whenever I save a file (normal), but I observe the
same phenomenon as above.
- In the project properties dialog, the AspectJ entry appears twice
after a while (I mean, noz it appears twicem but yesterday it appeared
only once).
Overall, working with AspectJ is not practival at the moment for my
project, because it is far too slow. I have a 1ghz P3 with 384m RAM,
256m allocated to Eclipse. My project has +/- 1500 classes, and only one
aspect that crosscuts less than 10% of the classes. An AspectJ build of
my project takes 1-2mn, with auto build and incremental build off.
Is the work in progress with the incremental compiler supposed to
improve this? Is there any chance that the memory consumption gets lower?
Guillaume
Re: Feedback on AJDT 1.1.11 [message #38987 is a reply to message #38940] |
Thu, 22 July 2004 06:38   |
Originally posted by: clemas.uk.ibm.com
Guillaume Pothier wrote:
> project.
> only once).
> Guillaume
I have seen the main issue you describe a few times - but I can not
reliably recreate it to debug it. For me these unwanted background
builds seem to occur now and again, rather than every time I do
something. If you are amenable to it, if you privately share your
project with us we will investigate as you seem to have a situation that
always causes it to occur.
Is the aspect a core part of your programs functionality or something
orthogonal like logging? It is very easy to set up the aspects in a
second project that weave into a base java project that contains all
your java code. If that would work for you I can go into more details.
The AspectJ compiler is fully incremental enabled. The AJDT tools are
not - they can't render incremental results correctly in the outline
view and that's why we don't currently have incremental set as the
default compilation option. If you are happy to have a incomplete
outline view then you can turn incremental on and the compiler will
always create the right results on disk for you to execute.
On the memory issue - I know we still have problems, and I think I know
where some of them are so there is still more work to do in this area.
let me know on email if you are OK to share your project.
cheers,
Andy.
Re: Feedback on AJDT 1.1.11 [message #39046 is a reply to message #38987] |
Thu, 22 July 2004 18:24   |
I am afraid I cannot share my project for the time being. But I must say
that I think my project is all the more classic: three source folders, a
few jars, I'm using the eclipse build process (I mean I don't use ant on
a regular basis), the project is shared via CVS... I cannot think of any
fancy setup...
I would be glad if you explained that trick to separate aspects and
source code.
For now I have only one aspect that does the following: there are some
objects on which I want to perform post-constructor initialization, ie.
call an init() method after they are fully instantiated (just after the
call to "new"). So I defined an interface IPCIObject with the init()
method, and I make a few classes implement that interface. I guess that
would be called core functionality.
Well, whith incremental build and automatic build turned on, I just
added a whitespace in a file and saved it, and the build process seemed
to last forever... At least, I didn't wait for it to complete. Is the
backend incremental compiler a work in progress, or is it finished?
Re: Feedback on AJDT 1.1.11 [message #39280 is a reply to message #39046] |
Sat, 24 July 2004 14:15  |
I wanted to add an extra comment on this. The incremental support in
the AspectJ compiler is fully functional. There may be some further
optimizations we can make when you save an aspect such that it does less
compilation but for day-to-day development when you are just modifying
classes or interfaces, it should work perfectly.
It is the way that incremental support surfaces in AJDT that seems to be
misbehaving. We have a bug report in on it already (70774) that I will
use for further investigations.
cheers,
Andy.
AspectJ/AJDT Committer
Re: Feedback on AJDT 1.1.11 [message #581948 is a reply to message #38940] |
> project.
> only once).
> Guillaume
cheers,
Andy.
Re: Feedback on AJDT 1.1.11 [message #581999 is a reply to message #38987] |
fancy setup...
source code.
Re: Feedback on AJDT 1.1.11 [message #582185 is a reply to message #39046] |
cheers,
Andy.
Current Time: Mon Jul 21 21:05:27 EDT 2025
Powered by FUDForum. Page generated in 0.05099 seconds
