Home » Archived » BIRT » Creating Datasets/Data Sources Programmatically
Creating Datasets/Data Sources Programmatically [message #38937] Fri, 20 May 2005 06:46 Go to next message
In our application we are aiming towards the automatic generation of
reports, to do this we need to programmatically create datasets and/or
datasources. I would like to know if there is a way to do this without
going through the datasource and dataset wizards.
I would greatly appreciate any help on this matter.
Thanks and regards
Nathan
Re: Creating Datasets/Data Sources Programmatically [message #38973 is a reply to message #38937] Fri, 20 May 2005 14:51 Go to previous messageGo to next message
Nathan,
There are two ways to create designs (including data sources and data sets)
programmatically.
First, you can use the DE API. It provides a complete set of functions to
create report elements including data sources and data sets. You can even
start with an existing file if some of the content is the same from one
report to the next (data source, page headers, titles, styles, or whatever.)
See the following for an introduction:
http://www.eclipse.org/birt/index.php?page=deploy/de-api.htm l
Second, you can directly create the XML design file using your favorite text
or XML tool. The scripting approach works best if the generated designs
follow a fairly fixed pattern. For example, a single data set, a tabular
layout, standard styles, etc. Simply create a design that is typical, then
identify the bits that will change. (Data set query, column headings, column
contents.) There is a brief intro to this idea at:
http://www.eclipse.org/birt/index.php?page=deploy/viewer-php .html
I've done a simple prototype of the scripted approach using PHP and can make
that available if it would be helpful.
- Paul
Paul Rogers
BIRT PMC
"Nathan McKeown" <nathan.mckeown@scapatech.com> wrote in message
news:d6kf0n$sbo$1@news.eclipse.org...
> Thanks and regards
> Nathan
Re: Creating Datasets/Data Sources Programmatically [message #48609 is a reply to message #38973] Tue, 21 June 2005 06:25 Go to previous message
Thanks for the help, I have now made some good progress using the DE API
route to produce my reports.
I am however, still having difficulties trying to format the reports
(using grouped headings etc.), with data coming from the ResultSet I
have generated?
Nathan
Paul Rogers wrote:
> Nathan,
> programmatically.
> - Paul
> Paul Rogers
> BIRT PMC
>>Hi,
>>Thanks and regards
>>Nathan
Previous Topic:BIRT 1.0.1 Plan Now Available
Next Topic:Found Any Bugs in BIRT 1.0? Please Log Them In Bugzilla...
Current Time: Sat Jul 26 03:07:23 EDT 2025
Powered by FUDForum. Page generated in 0.05106 seconds
