Home » Newcomers » Newcomers » Problems with Startup
Problems with Startup [message #38846] Tue, 22 March 2005 17:57 Go to next message
Originally posted by: shorty_26.gmx.de
i have problems when i start eclipse. At startup i get the splash screen
and after that a windows popup message:
An error has occurred. See the log file
C:\eclipse\workspace\.metadata\.log.
Logfile:
!SESSION 2005-03-22 23:27:01.160
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-03-22 23:27:01.170
!MESSAGE Application error
!STACK 1
java.lang.NoSuchMethodError:
org.eclipse.swt.custom.CBanner.setRightMinimumSize(Lorg/ecli pse/swt/graphics/Point;)V
org.eclipse.ui.internal.PerspectiveSwitcher.updateBarParent( PerspectiveSwitcher.java:1199)
org.eclipse.ui.internal.PerspectiveSwitcher.setPerspectiveBa rLocation(PerspectiveSwitcher.java:277)
org.eclipse.ui.internal.PerspectiveSwitcher.createControl(Pe rspectiveSwitcher.java:202)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:864)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:573)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:352)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:778)
at org.eclipse.jface.window.Window.create(Window.java:375)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:581)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1209)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:717)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:918)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1554)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
I hope you can help me ....
Thanks a lot ...
Markus
Re: Problems with Startup [message #39096 is a reply to message #38846] Wed, 23 March 2005 06:25 Go to previous message
Originally posted by: user.server.net
Markus,
Could it be, that you installed a newer version of Eclips over an
existing installation of an older version? You might want to try a clean
install then.
Kai
Rocky wrote:
> Hello,
> Logfile:
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks a lot ...
> Markus
Previous Topic:Debug with Tomcat
Next Topic:CMVC feature exception
Current Time: Mon Jul 21 22:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.30317 seconds
