Home » Eclipse Projects » Plugin Development Environment (PDE) » Dependency between eclipse plugins?
Dependency between eclipse plugins? [message #38816] Mon, 29 December 2008 23:43 Go to next message
Is there a tool which show the dependencies between all the plugins in a
workspace (or a set of selected plugins) in a single view.
A tool other than plugin dependencies view is required as it will show the
dependencies of only one plugin at a time.
If I could see the dependencies between all the plugins of a software
project in a glance I could get a quick understanding about the
architecture of the software project.
Madhu
http://mksamuel.blogspot.com/
Re: Dependency between eclipse plugins? [message #38848 is a reply to message #38816] Tue, 30 December 2008 08:37 Go to previous messageGo to next message
> the dependencies of only one plugin at a time.
There's a PDE Graph Viewer that you may found useful:
http://www.eclipse.org/pde/incubator/dependency-visualizatio n/index.php
~ Chris
Re: Dependency between eclipse plugins? [message #38956 is a reply to message #38848] Thu, 01 January 2009 03:41 Go to previous message
Thanks. I will check the link.
Re: Dependency between eclipse plugins? [message #587693 is a reply to message #38816] Tue, 30 December 2008 08:37 Go to previous message
~ Chris
Re: Dependency between eclipse plugins? [message #587739 is a reply to message #38848] Thu, 01 January 2009 03:41 Go to previous message
Previous Topic:BracketInserter, "mirrored" text in brackets
Next Topic:Context help in a wizard
Current Time: Sat Jul 26 19:34:54 EDT 2025
Powered by FUDForum. Page generated in 0.24179 seconds
