Home » Archived » Maven Integration (M2E) » m2eclipse 0.9.3 released
m2eclipse 0.9.3 released [message #3347] Tue, 22 April 2008 00:53 Go to next message
We glad to announce 0.9.3 release. You can see list of resolved issues
in the project issue tracking system http://tinyurl.com/6h4mzt
The most notable new feature is cofiguration for Maven Archetype
catalogs that allow to configure custom catalogs or contribute then
using new extension point.
Please also note that Maven launch configurations had been moved from
"External Tools" into "Run/Debug" category. Because of this change, you
may have to delete old Maven launch configurations from "External Tools"
dialog and recreate them in "Run" dialog. Sorry for the inconvenience,
but now you can explicitly select if you want to run Maven under
debugger by calling "Debug As... / Maven..." from the project popup
menu, or by creating Maven launch configuration from "Debug" drop down
on the main toolbar.
See more details for this and previous releases on the New and
Noteworthy page at
http://docs.codehaus.org/display/M2ECLIPSE/New+and+Noteworth y
You can install new version from the project update site at
http://m2eclipse.sonatype.org/update/
As before, we would like to thank everyone who tested previous
versions, submitted ideas, bug reports, test projects and patches.
m2eclipse team
m2eclipse 0.9.4 dev build [message #5132 is a reply to message #3347] Mon, 12 May 2008 14:55 Go to previous message
m2eclipse team would like your feedback and help us test new project
configuration framework [1] implemented for version 0.9.4. Also, if you
are working on your own tools based on Eclipse, we would like to hear
from you if configuration framework is sufficient for integrating your
tools.
If you are using m2eclipse with WTP and/or AJDT, please install this
stable development build from the dev update site [2], try it with your
projects and give us your feedback. See mini howto for WTP integration
on the wiki [3].
In addition to project configuration we added shortcuts for opening
project page, issue tracker, source control and ci systems based on
information from pom.xml and also packaged "Maven: The Definitive Guide"
book as an Eclipse help. More details for new features added in this and
previous releases available on the New and Noteworthy page at
Known issues in this dev build:
- web modules configuration is not always immediately reflect
dependency changes, so you may have to call "Update Project
Configuration" action from Maven popup menu (note that this action
replaces old "Update Source Folders" action)
- support for ear, rar and other j2ee module types is not implemented
yet. Please let us know if you are interested working on this
m2eclipse team
[1]
http://docs.codehaus.org/display/M2ECLIPSE/Extensible+projec t+configuration+framework
[2] http://m2eclipse.sonatype.org/update-dev/
[3] http://docs.codehaus.org/display/M2ECLIPSE/WTP+mini+howto
Previous Topic:Adding Accurev as an interested party
Next Topic:Eclipse Chapter in Maven Book
Current Time: Sat Jul 26 07:35:02 EDT 2025
Powered by FUDForum. Page generated in 0.04134 seconds
