| HTTP Proxy Standalone? [message #38722] |
Wed, 02 November 2005 14:55  |
Hello!
I noticed that the HTTP Recorder uses a proxy to monitor the communication.
The HTTP Proxy might be interesting for a number of other purposes
besides testing.
Is it possible to use the HTTP proxy standalone, without the TPTP
testing facility? If no, how difficult would it be to separate the proxy
from TPTP?
Thanks in advance for your ideas.
Thomas
| Re: HTTP Proxy Standalone? [message #39676 is a reply to message #39429] |
Mon, 07 November 2005 11:33  |
Hello Paul,
Thank you very much for this information.
My use case is actually for some HTTP Monitor that I recently ported to
Eclipse, called WebScarab for Eclipse (http://wscarabeclipse.sf.net).
It also contains an HTTP Proxy, but I am not quite satisfied with the
performance, so I am looking for some replacement.
I tried the TPTP proxy and it performed better, so I will look into
extracting it from the plugins you indicated.
-Thomas
Paul Slauenwhite wrote:
> Hi Thomas,
> Although not a supported use case, separating the HTTP proxy recorder
> from TPTP Test is possible, albeit difficult. The HTTP proxy recorder is
> spread over four TPTP plugins:
> -org.eclipse.hyades.test.ui
> -org.eclipse.hyades.test.tools.ui
> -org.eclipse.hyades.test.core
> -org.eclipse.hyades.test.tools.core
> However, there is an implementation of a simple HTTP proxy server that
> we use for demonstration purposes in conference tutorials. You can access
> the source code at:
> http://www.eclipse.org/tptp/ >> Documentation >> Conference Materials >>
> EclipseWorld 2005 >> Using and Extending the Test and Performance Tools
> Platform >> Source >> Simple_HTTP_Proxy_Server
> Please keep in mind that the simple HTTP proxy server implementation was
> only intended for demonstration purposes and will require several
> performance improvements for general use.
> Paul
> "Thomas D" <tderflinger@gmx.net> wrote in message
> news:dkb5ip$s79$1@news.eclipse.org...
>>Hello!
> communication.
>>besides testing.
>>from TPTP?
>>Regards,
>>Thomas
FUDForum. Page generated in 0.03146 seconds
