Home » Modeling » OCL » Is it possible to change sum() behavior?
Is it possible to change sum() behavior? [message #38719] Wed, 26 September 2007 03:14 Go to next message
I found evaluating following expression would returns null:
Commodity.allInstances()->select(id='aaa').weight->sum()
if there is no commodity whose id is "aaa". I'm wondering whether it is
possible to let above expression returns Integer 0 rather than null, so that
I can safely evaluate this expression:
Commodity.allInstances()->select(id='aaa').weight->sum() > 0
otherwise evaluating above expression would result an exception. Of course I
can write following expression to judge whether the set is empty, but it is
somehow too complex:
let coms:Set(Commodity) = Commodity.allInstances()->select(id='aaa') in
not coms->isEmpty() and coms.weight->sum()>0
Can I archive this by customizing the environment, or there is other
recommended way for this situation?
Hao
Re: Is it possible to change sum() behavior? [message #38787 is a reply to message #38719] Wed, 26 September 2007 09:48 Go to previous messageGo to next message
Hi, Hao,
If you expect to find at most one commodity whose id is 'aaa', then you
might find the "any" iterator to be convenient:
Commodity.allInstances()->any(id='aaa').weight
which will give you a weight or else OclInvalid if there is no such
commodity. (OclInvalid returns true to an oclIsUndefined() test just as
null does).
However, that's all beside the point, because the sum of an empty collection
of integers is supposed to be zero, not null. The specification of this
operation makes that clear.
Would you mind raising a bug? That would be better than asking you to work
around this with a custom EvaluationEnvironment implementation, which would
be feasible but shouldn't be necessary.
Christian
Hao Zhang wrote:
> that I can safely evaluate this expression:
> I can write following expression to judge whether the set is empty, but it
> is somehow too complex:
> in
> Hao
Re: Is it possible to change sum() behavior? [message #39226 is a reply to message #38787] Wed, 26 September 2007 21:43 Go to previous message
I created
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204753
Thanks for your instruction.
"Christian W. Damus" <cdamus@ca.ibm.com>
??????:fddnut$6la$1@build.eclipse.org...
> Hi, Hao,
> null does).
> collection
> work
> would
> Christian
> Hao Zhang wrote:
>> course
>> it
>> in
>> Regards,
>> Hao
Previous Topic:[Announce] MDT OCL 1.2.0 I200709261803 is available
Next Topic:attribute query
Current Time: Fri Jul 18 00:26:17 EDT 2025
Powered by FUDForum. Page generated in 0.28428 seconds
