How to read my plugin dependency libraries [message #38662] |
Mon, 29 December 2008 07:05  |
Hi All,
I am having a common problem of reading the reference libraries.
Examle --
1)I am having a plugin project named as -com.example1
2)I am having another plugin -com.example2
3)Plugin-com.example2 is dependent on plugin-com.example1
4)i have added c.jar to the com.example1 plugin an the build path
3)plugin-com.example1 has exported some packages of the c.jar
in manifest.mf files
4)Plugin-com.example2 has imported those packages in manifest
file.
How to get all the class names resides in that package in the
plugin-com.example2 programmatically to load the class through reflection
class.forname(packagename.classname).because i want to access all the
methods of those classes.
Thanks in advance
Debasis
Re: How to read my plugin dependency libraries [message #38784 is a reply to message #38662] |
Mon, 29 December 2008 09:29  |
Please DO NOT post the same question to all the newsgroups. Pick what
you think is the most appropriate group and ask only there; if it the
wrong place, someone will point you in the right direction.
On 12/29/2008 7:05 AM, Debasis Mishra wrote:
> Hi All,
> Examle --
> 2)I am having another plugin -com.example2 3)Plugin-com.example2 is
> 3)plugin-com.example1 has exported some packages of the c.jar in
> manifest.mf files
> 4)Plugin-com.example2 has imported those packages in manifest file.
> reflection class.forname(packagename.classname).because i want to access
> all the methods of those classes.
> Thanks in advance
> Regards
> Debasis
Re: How to read my plugin dependency libraries [message #587666 is a reply to message #38662] |
> Hi All,
> Examle --
> manifest.mf files
> Thanks in advance
> Regards
> Debasis
FUDForum. Page generated in 0.07794 seconds
