Home » Eclipse Projects » Plugin Development Environment (PDE) » Build fails: Unable to find feature
Build fails: Unable to find feature [message #38640] Sun, 28 December 2008 10:05 Go to next message
I'm trying to build an RCP app with dependencies to e.g. org.eclipse.help.ui
Build fails when using RCP runtime + delta pack as target environment
(which appears obvious).
Alternatively, I've tried to use a separate Eclipse SDK as target
environment, but build gets much further still fails, but with strange
errors:
[java] customAssembly:
[java] BUILD FAILED
[java]
c:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\productBuild.xml:30:
The following error occurred while executing this line:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\build.xml:91:
[java]
C:\workspace\com.siemens.ct.mp3m.build\customTargets.xml:12: The
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\allElements.xml:10:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\genericTargets.xml:158:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.all.xml:23:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.all.xml:15:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\allElements.xml:44:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.win32.win32.x86.xml:188:
java.io.EOFException
Any ideas what this might be?
-- Andi
Re: Build fails: Unable to find feature [message #38718 is a reply to message #38640] Mon, 29 December 2008 08:32 Go to previous messageGo to next message
I've done some more investigation with a simple PDE build using the
examples from
http://rcpquickstart.com/2007/06/06/getting-started-with-pde -build/
Building against the RCP runtime works fine. This won't work for me
though as runtime doesn't contain all required features like e.g. Common
Navigator etc.
Building against Eclipse SDK (even if separate install) continues to
fail with java.io.EOFException
So I believe it comes down to the question of how to do a PDE build with
required features not part of RCP runtime?
All insight greatly appreciated!
Andi
Re: Build fails: Unable to find feature [message #40060 is a reply to message #38718] Mon, 12 January 2009 09:49 Go to previous messageGo to next message
Hi Andreas,
I believe I had the same error message. In my case the Eclipse Deltapack
was missing. For a small tutorial which related to the Eclipse PDE Build
you can check here:
http://www.vogella.de/articles/EclipsePDEBuild/article.html
Best regards, Lars
> examples from
> Navigator etc.
> Andi
Lars Vogel
http://www.vogella.de/eclipse.html - Tutorials about Eclipse
http://www.vogella.de/articles/RichClientPlatform/article.ht ml - Eclipse
RCP Tutorial
Re: Build fails: Unable to find feature [message #40621 is a reply to message #40060] Fri, 16 January 2009 17:17 Go to previous messageGo to next message
Mhm- I do have the delta pack installed, even re-downloaded to make
sure. Selected target SDK containing delta pack as runtime. Still same
problem:
On 12.01.2009 15:49, Lars Vogel wrote:
> Hi Andreas,
> you can check here:
> Best regards, Lars
>> examples from
>> Common Navigator etc.
>> with required features not part of RCP runtime?
>> Thanks,
>> Andi
Re: Build fails: Unable to find feature [message #40683 is a reply to message #40060] Fri, 16 January 2009 20:06 Go to previous messageGo to next message
Even straight-forward plugins seem to fail:
Bundle
org.eclipse.core.filesystem.win32.x86:
Host plug-in
org.eclipse.core.filesystem_[1.1.0,2.0.0) has not been found.
Bundle
org.eclipse.core.net.win32.x86:
Host plug-in
org.eclipse.core.net_1.1.0 has not been found.
Bundle
org.eclipse.core.resources.win32.x86:
Host plug-in
org.eclipse.core.resources_[3.4.0,3.5.0) has not been found.
Bundle
org.eclipse.equinox.launcher.win32.win32.x86:
Bundle
org.eclipse.equinox.security.win32.x86:
Host plug-in
org.eclipse.equinox.security_[1.0.0,2.0.0) has not been found.
Bundle
org.eclipse.swt.win32.win32.x86:
Bundle org.eclipse.ui.win32:
Host plug-in
org.eclipse.ui.ide_[3.2.0,4.0.0) has not been found.
Bundle org.eclipse.update.core.win32:
[eclipse.generateFeature] Host plug-in
org.eclipse.update.core_[3.0.0,4.0.0) has not been found.
Any idea what might be wrong with the target runtime definition (RCP
binary + Delta pack)?
Andi
Re: Build fails: Unable to find feature [message #40783 is a reply to message #40683] Sat, 17 January 2009 19:36 Go to previous messageGo to next message
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Bundle
> Host plug-in
> Bundle
> Host plug-in
Is the delta pack and rcp binary co-located, ie., c:/dir/plugins ?
Re: Build fails: Unable to find feature [message #40872 is a reply to message #40783] Mon, 19 January 2009 06:54 Go to previous messageGo to next message
I've setup c:\eclipse for my SDK and created c:\eclipse\runtime as base
folder for the rcp binary and delta pack. Thus the combined plugin of
rcp binary and delta pack end up in c:\eclipse\runtime\eclipse\plugins.
I've also configured build properties to match the runtime folder:
base=c:/eclipse/runtime
baseLocation=${base}/eclipse
Makes sense?
>> Bundle
>> Host plug-in
>> Bundle org.eclipse.core.net.win32.x86:
>> Host plug-in
>> Bundle
>> Host plug-in
>> Bundle
>> Bundle
>> Host plug-in
>> Bundle org.eclipse.swt.win32.win32.x86:
>> Host plug-in
[Solved] Re: Build fails: Unable to find feature [message #42324 is a reply to message #38640] Sun, 25 January 2009 12:35 Go to previous message
I've solved this issue by setting up the target runtime environment
again. Runtime needs to consist of
Eclipse Platform SDK + RCP Delta Pack
The previous Eclipse SDK + RCP Delta Pack or RCP Runtime + RCP Delta
Pack were both not sufficient.
Hope this helps,
Andi
Re: Build fails: Unable to find feature [message #587639 is a reply to message #38640] Mon, 29 December 2008 08:32 Go to previous message
examples from
Navigator etc.
Andi
Re: Build fails: Unable to find feature [message #588148 is a reply to message #38718] Mon, 12 January 2009 09:49 Go to previous message
Hi Andreas,
you can check here:
Best regards, Lars
> examples from
> Navigator etc.
> Andi
Lars Vogel
RCP Tutorial
Re: Build fails: Unable to find feature [message #588317 is a reply to message #40060] Fri, 16 January 2009 17:17 Go to previous message
problem:
> Hi Andreas,
> you can check here:
> Best regards, Lars
>> examples from
>> Thanks,
>> Andi
Re: Build fails: Unable to find feature [message #588334 is a reply to message #40060] Fri, 16 January 2009 20:06 Go to previous message
Bundle
Host plug-in
Bundle
Host plug-in
Bundle
Host plug-in
Bundle
Bundle
Host plug-in
Bundle
Host plug-in
Andi
Re: Build fails: Unable to find feature [message #588362 is a reply to message #40683] Sat, 17 January 2009 19:36 Go to previous message
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Bundle
> Host plug-in
> Bundle
> Host plug-in
Re: Build fails: Unable to find feature [message #588387 is a reply to message #40783] Mon, 19 January 2009 06:54 Go to previous message
Makes sense?
>> Bundle
>> Host plug-in
>> Host plug-in
>> Bundle
>> Host plug-in
>> Bundle
>> Bundle
>> Host plug-in
>> Host plug-in
[Solved] Re: Build fails: Unable to find feature [message #590454 is a reply to message #38640] Sun, 25 January 2009 12:35 Go to previous message
Hope this helps,
Andi
Previous Topic:[newbie] Accessing selected file
Next Topic:PDE build fails with optional dependencies
Current Time: Tue Jun 03 11:28:14 EDT 2025
Powered by FUDForum. Page generated in 0.04623 seconds
