CDT on Solaris [message #38601] |
Thu, 25 July 2002 13:26  |
Originally posted by: paulwebber.fairisaac.com
When will CDT be working on solaris? The current version 20020710 does not
work under solaris 8, JDK 1.4 with 64 bits.
Paul
Re: CDT on Solaris [message #38679 is a reply to message #38634] |
Thu, 25 July 2002 14:29   |
Judy N. Green wrote:
> \"Paul Webber\" <paulwebber@fairisaac.com> wrote in message
> news:ahpcba$aj$1@rogue.oti.com...
> | Thanks,
> | Paul
> Hi Paul,
> We are in the process of assigning responsibility for supporting specific
> platforms.
> Until then, ...
> There is a BUG listed on the Eclipse site regarding problems running Eclipse
> on Solaris 8 with JDK 1.4
> http://dev.eclipse.org/bugs/show_bug.cgi?id=21695
> Let me know it this sounds like your problem.
> If not ...
> Which flavour of the JDK do you have installed?
> Can you get Eclipse 2.0 working on your installation, without the CDT?
> Or is it just the CDT that is not working?
> -Judy
> ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨ ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨
> Judy N. Green Software Engineer
> QNX Software Systems Ltd. www.qnx.com
Okay, I deleted eclipse from the system and reinstalled just the R 2.0. I
am running under:
pdw@ux5:/tag/src/cppunit-1.8.0 [2] % java -version
java version \"1.4.0\"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.0-b92)
Java HotSpot(TM) Client VM (build 1.4.0-b92, mixed mode)
After starting eclipse the first thing I do is tie it to my cvs
repository. This works and I can browse the repository. I have a
\"project\" in there that I created from a windows machine and so I select
the directory and the mouse menu item \"Check Out As Project\". Nothing
happens. I try the \"Check Out As... and nothing happens.
So, this is now an eclipse issue and not a CDT issue.
Paul
Re: CDT on Solaris [message #38697 is a reply to message #38679] |
Thu, 25 July 2002 17:17  |
"Paul Webber" <paulwebber@fairisaac.com> wrote in message
news:ahpg2f$2ms$1@rogue.oti.com...
not
| > | Thanks,
| > | Paul
|<snip>
| am running under:
| Thanks,
| Paul
Hi Paul,
Yup .. it sounds like an eclipse problem. :(
Let me know if we can be of any assistance.
-Judy
FUDForum. Page generated in 0.06227 seconds
