Home » Archived » Visual Editor (VE) » Eclipse3 M9 and VE
Eclipse3 M9 and VE [message #38475] Sat, 22 May 2004 09:30 Go to next message
Originally posted by: mokak.web.de
I have installed the new eclipse with the newest GEF and EMF plugins and
VE 1.0 M1. Now when I want to create a new Visual Class, I get the
dialog and enter the name for the class and when I click on Finisch I
get this error:
Creation of element failed.
Attempted to beginRule: F/Test/gui, does not match outer scope rule:
L/Test/gui/gui.java
Could someone please help me with this problem?
Greets
Adam
This is my .log-file:
!SESSION Mai 22, 2004 15:26:12.906
eclipse.buildId=I200405211200
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.jdt.ui 4 10001 Mai 22, 2004 15:26:12.906
!MESSAGE Internal Error
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:283)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 750)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:115)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:607)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:305)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:505)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2716)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2382)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.ui.internal.ide.NewWizardShortcutAction.run(NewW izardShortcutAction.java:96)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:899)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:850)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:769)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Caused by: java.lang.IllegalArgumentException: Attempted to beginRule:
F/Test/gui, does not match outer scope rule: L/Test/gui/TestFrame.java
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java :58)
at org.eclipse.core.internal.jobs.ThreadJob.illegalPush(ThreadJ ob.java:106)
at org.eclipse.core.internal.jobs.ThreadJob.push(ThreadJob.java :200)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:58)
at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:170)
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:95)
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1627)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1667)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:744)
org.eclipse.jdt.internal.core.PackageFragment.createCompilat ionUnit(PackageFragment.java:147)
org.eclipse.jdt.ui.wizards.NewTypeWizardPage.createType(NewT ypeWizardPage.java:1418)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 28)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:108)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:34)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:700)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1672)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3240)
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:65)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
Root exception:
java.lang.IllegalArgumentException: Attempted to beginRule: F/Test/gui,
Re: Eclipse3 M9 and VE [message #38508 is a reply to message #38475] Sat, 22 May 2004 23:16 Go to previous message
Originally posted by: mojo.jojo.com
VE M1 is for Eclipse 3.0M8 not M9.
Eclipse, VE, GEF and EMF versions have to be the ones specified on the
release page, else as noted correct functionality is not guaranteed.
Re: Eclipse3 M9 and VE [message #589092 is a reply to message #38475] Sat, 22 May 2004 23:16 Go to previous message
Previous Topic:Eclipse3 M9 and VE
Next Topic:VE0.5 need too much memory...
Current Time: Tue Jul 08 20:08:46 EDT 2025
Powered by FUDForum. Page generated in 0.03447 seconds
