Can't view/checkout/update/etc with Subversive on Eclipse Ganymede (400 Error) [message #38463] |
Thu, 27 November 2008 21:01  |
I'm getting the following error when I try and checkout a project from my
subversion repository:
Checkout operation for 'http://server/repos/path/to/project' failed.
svn: REPORT of '/repos/!svn/vcc/default': 400 Bad Request (http://server)
I get something similar when I try and update the project. I can't view
the repository either. This all worked fine in the previous version of
Eclipse I was using (Europa), so something's now broken in this verison of
Eclipse.
I'm using Ubuntu 7.10, and I can access the repository just fine with the
command line client, and with the previous version of Eclipse.
I tried checking it out from Subversion, but that didn't work. This is a
new install of Eclipse, downloaded from the Eclipse site, and pointing to
a brand-new workspace. When I couldn't check it out via Eclipse, I tried
it with the command line, and that worked fine. Eclipse picked up the the
fact that it was under version control when I added it as an existing
project, but it won't update and it won't commit, which isn't a lot of use
to me.
I'm running Sun Java 1.5, in case it makes a difference, and my SVN
Connector is set to SVN Kit (SVN 1.5.2, SVNKit/1.2.0 r4949).
Anyone got any ideas on how I can resolve this? The only possibility I can
see is that the server's subversion is an old version, too old to work
with the new Eclipse, but I'm hoping it's something else.
Thanks all.
FUDForum. Page generated in 0.65895 seconds
