Home » Eclipse Projects » Equinox » [m7] import package problem
[m7] import package problem [message #38435] Wed, 24 March 2004 11:19 Go to next message
Originally posted by: alexsmr.sympatico.ca
In my project I created a plugin that provide some package to OSGi, I have
also created pure OSGi type bundle that imports the package from that plugin
(I have require header for my plugin ). But with or without import-package
clause I am getting exception. Something like this with import clause:
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: missing imported package com.trillint.facelet.component
and CLassNotFound exception without import clause.
Any ideas?
Alex.
Re: [m7] import package problem [message #38469 is a reply to message #38435] Wed, 24 March 2004 13:17 Go to previous messageGo to next message
Sorry to bother. I didn't refresh packages after bundle installation. Now it
works. Doesn't seems to be standard OSGi procedure though.
Alex.
plugin
import-package
> Any ideas?
> Alex.
Re: [m7] import package problem [message #38562 is a reply to message #38469] Thu, 25 March 2004 07:35 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
You install a bundle, then you refresh it.
PaScaL
> Alex.
> plugin
> import-package
>>Any ideas?
>>Thanks,
>>Alex.
Re: [m7] import package problem [message #38785 is a reply to message #38469] Fri, 26 March 2004 20:34 Go to previous messageGo to next message
Just realized that my previous post was not really helpful...
Why are you saying that it "doesn't seems to be standard OSGi procedure"?
Also could you provide a simplified version of this example, I'm not
sure I'm getting what you are saying.
PaScaL
> Alex.
> plugin
> import-package
>>Any ideas?
>>Thanks,
>>Alex.
Re: [m7] import package problem [message #39174 is a reply to message #38785] Wed, 31 March 2004 16:40 Go to previous messageGo to next message
Pascal,
When installing the bundle it tries to resolve dependencies and enter
RESOLVED state. As far as I understand "Require-Bundle" and
"Provide-Package" are eclipse additions to OSGi standard that
come with a cost of "refreshing" packages after installation part.
In other words, it will not resolve dependencies during installation
phase (unless you explicitly refresh packages).
So that part doesn't seems to me very compliant with OSGi.
Alex.
> PaScaL
Now it
> > Alex.
have
> > plugin
> > import-package
> >>Any ideas?
> >>Thanks,
> >>Alex.
Re: [m7] import package problem [message #39266 is a reply to message #39174] Wed, 31 March 2004 19:21 Go to previous messageGo to next message
In the R3.0 of the spec, nothing is said about when the bundles should
be set to the RESOLVED state. It is up to the implementation to do it
lazily or eagerly.
Here is an excerpt of spec:
6 - The bundle’s state is set to INSTALLED.
7 - If the bundle has not declared an Import-Package Manifest header
(that is, the bundle does not depend on any packages from other OSGi
bundles), the bundle’s state may be set to RESOLVED.
PaScaL
> Pascal,
> Alex.
>>PaScaL
> Now it
>>>Alex.
> have
>>>plugin
>>>import-package
>>>>Any ideas?
>>>>Thanks,
>>>>Alex.
Re: [m7] import package problem [message #39297 is a reply to message #39266] Thu, 01 April 2004 08:51 Go to previous message
Sorry. Hmm... Somehow I missed that point and was pretty sure that
after installation and if dependencies are resolved bundles must enter
RESOLVED state. Looks that I was wrong.
Thanks for pointing me to the right direction,
Alex.
> lazily or eagerly.
> 6 - The bundle
Previous Topic:Can I retrive plugin ID?
Next Topic:Bundle access without activation (M8)
Current Time: Mon Jul 21 20:59:41 EDT 2025
Powered by FUDForum. Page generated in 0.09726 seconds
