Home » Archived » Maven Integration (M2E) » wost wanted features for Maven integration
wost wanted features for Maven integration [message #3315] Mon, 21 April 2008 15:04 Go to next message
m2eclipse development team would like your feedback on the most wanted
features for Maven integration for Eclipse. This would help us to plan
and prioritize the new features for the project roadmap.
Please let us know what features and improvements you would like to
see in the next m2eclipse releases and if you are interested in working
on some components.
You can respond here or add your ideas to the corresponding wiki page
[1] or submit and vote on the bug reports [2].
Thank you in advance
m2eclipse team
[1] http://docs.codehaus.org/display/M2ECLIPSE/Other+Ideas+and+U se+Cases
[2] http://jira.codehaus.org/browse/MNGECLIPSE
Re: wost wanted features for Maven integration [message #6928 is a reply to message #3315] Thu, 15 May 2008 07:29 Go to previous messageGo to next message
> Please let us know what features and improvements you would like to see
> in the next m2eclipse releases and if you are interested in working on ere
> some components.
> m2eclipse team
Are there plans to also add an up-to-date support for the Eclipse
compiler? Currently our team compiles the sources locally using the
Eclipse compiler and on the build server using the Java compiler
provided by maven.
It would be cool if the same compilers could be used on the client and
server side. There is an eclipse compiler available in the
plexus-compiler, however this compiler is based on Eclipse 3.1. Would be
cool if this compiler would be Eclipse 3.4 (or at least 3.3).
Thanks, Ulli
Re: wost wanted features for Maven integration [message #6952 is a reply to message #6928] Thu, 15 May 2008 09:51 Go to previous messageGo to next message
Originally posted by: igorfie.yahoo.com
Not sure how relevant this is, but we have a subproject called Tycho
aimed at providing first-class maven support for building eclipse and
osgi bundles. One of Tycho's goals is to enforce OSGi class visibility
at compile time and we're using Eclipse JDT compiler to do this. Tycho
already uses Eclipse 3.2 JDT compiler but we plan to move to 3.3 or 3.4
in the near future. It should be possible to use Tycho compiler in
standalone maven build, but I have not tried this.
>> wanted features for Maven integration for Eclipse. This would help us
>> to plan and prioritize the new features for the project roadmap.
>> working on ere
>> some components.
>> m2eclipse team
> provided by maven.
> Thanks, Ulli
Re: wost wanted features for Maven integration [message #7083 is a reply to message #6952] Fri, 16 May 2008 03:22 Go to previous messageGo to next message
> already uses Eclipse 3.2 JDT compiler but we plan to move to 3.3 or 3.4 h
That sounds quite interesting! Is the compiler activated in the same way
as in the plexus compiler flag? Do you have an example configuration how
to use the compiler?
Thanks, Ulli
Re: wost wanted features for Maven integration [message #7106 is a reply to message #7083] Fri, 16 May 2008 04:03 Go to previous messageGo to next message
>> visibility at compile time and we're using Eclipse JDT compiler to do
>> this. Tycho already uses Eclipse 3.2 JDT compiler but we plan to move
>> to 3.3 or 3.4 h
> way as in the plexus compiler flag? Do you have an example
> configuration how to use the compiler?
Please note that maven-osgi-compiler-plugin from Tycho project is used
fro compiling OSGi bundles and I am not sure if it would work for
regular Java projects.
It should be sufficient to declare newer Eclipse version for
plexus-compiler-eclipse adapter. So here is the magic configuration
required for using Eclipse 3.3 compiler (this is kind of a long story)
that I've tested with Maven 2.0.9:
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.4</source>
<target>1.4</target>
<compilerId>eclipse</compilerId>
</configuration>
<dependencies>
<dependency>
<groupId>org.codehaus.plexus</groupId>
<artifactId>plexus-compiler-eclipse</artifactId>
<version>1.5.1</version>
</dependency>
<dependency>
<groupId>org.eclipse.jdt</groupId>
<artifactId>core</artifactId>
<version>3.3.0-v_771</version>
<exclusions>
<exclusion>
<groupId>org.eclipse.core</groupId>
<artifactId>resources</artifactId>
</exclusion>
<exclusion>
<artifactId>runtime</artifactId>
</exclusion>
<exclusion>
<artifactId>filesystem</artifactId>
</exclusion>
<exclusion>
<groupId>org.eclipse</groupId>
<artifactId>text</artifactId>
</exclusion>
<exclusion>
<groupId>org.eclipse.team</groupId>
</exclusion>
</exclusions>
</dependency>
</dependencies>
</plugin>
regards,
Eugene
Re: wost wanted features for Maven integration [message #7131 is a reply to message #7106] Fri, 16 May 2008 11:53 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Internally, maven-compiler-plugin uses
org.codehaus.plexus.compiler.Compiler with role-hint=jdt which is
provided by tycho-compiler-jdt. I ran a quick test and it looks like you
can activate this compiler in the usual way, i.e.
<build>
<plugins>
<plugin>
<configuration>
<compilerId>jdt</compilerId>
</configuration>
<dependencies>
<dependency>
<groupId>org.codehaus.tycho</groupId>
<artifactId>tycho-compiler-jdt</artifactId>
<version>1.0-SNAPSHOT</version>
</dependency>
</dependencies>
</plugin>
</plugins>
</build>
Please note that I am using locally modified tycho so your results may
differ ;-)
>>> to 3.3 or 3.4 h
> <plugin>
> <configuration>
> </configuration>
> <dependencies>
> <dependency>
> </dependency>
> <dependency>
> <exclusions>
> <exclusion>
> </exclusion>
> <exclusion>
> </exclusion>
> <exclusion>
> </exclusion>
> <exclusion>
> </exclusion>
> <exclusion>
> </exclusion>
> </exclusions>
> </dependency>
> </dependencies>
> </plugin>
> regards,
> Eugene
Re: wost wanted features for Maven integration [message #9372 is a reply to message #7106] Fri, 23 May 2008 04:12 Go to previous messageGo to next message
>>> to 3.3 or 3.4 h
> <plugin>
> <configuration>
> </configuration>
> <dependencies>
> <dependency>
> </dependency>
> <dependency>
This does not work for me, I get the following exception. (Note
that changing the dependency to Eclipse 3.2.1 results in the
same exception, changing to Eclipse 3.1 works. Seems to be
an incompatible API change).
org.apache.maven.plugin.CompilerMojo#execute() caused a
linkage er
ror (java.lang.NoSuchMethodError) and may be out-of-date. Check the realms:
Plugin realm =
app0.child-container
urls =
file:/C:/Build/Maven-Repository/org/apache/maven/plugins/mav en-compile
r-plugin/2.0.2/maven-compiler-plugin-2.0.2.jar
urls =
file:/C:/Build/Maven-Repository/org/codehaus/plexus/plexus-c ompiler-ec
lipse/1.5.1/plexus-compiler-eclipse-1.5.1.jar
urls =
file:/C:/Build/Maven-Repository/org/codehaus/plexus/plexus-u tils/1.0.4
/plexus-utils-1.0.4.jar
urls =
file:/C:/Build/Maven-Repository/org/codehaus/plexus/plexus-c ompiler-ap
i/1.5.3/plexus-compiler-api-1.5.3.jar
urls =
file:/C:/Build/Maven-Repository/org/eclipse/jdt/core/3.3.0-v _771/core-
3.3.0-v_771.jar
urls =
file:/C:/Build/Maven-Repository/org/codehaus/plexus/plexus-c ompiler-ma
nager/1.5.3/plexus-compiler-manager-1.5.3.jar
urls =
file:/C:/Build/Maven-Repository/org/codehaus/plexus/plexus-c ompiler-ja
vac/1.5.3/plexus-compiler-javac-1.5.3.jar
Container realm = plexus.core
urls =
file:/C:/Build/Tools/apache-maven-2.0.8/bin/../lib/maven-2.0 .9-uber.ja
r
FATAL ERROR
org.eclipse.jdt.internal.compiler.CompilationResult.getProbl ems()[Lorg/ec
lipse/jdt/core/compiler/IProblem;
[INFO]
[INFO] Trace
java.lang.NoSuchMethodError:
..getProblems()[Lorg/eclipse/jdt/core/compiler/IProblem;
org.codehaus.plexus.compiler.eclipse.EclipseJavaCompiler$Ecl ipseCompi
lerICompilerRequestor.acceptResult(EclipseJavaCompiler.java: 533)
org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler. java:398)
org.codehaus.plexus.compiler.eclipse.EclipseJavaCompiler.com pile(Ecli
pseJavaCompiler.java:206)
org.apache.maven.plugin.AbstractCompilerMojo.execute(Abstrac tCompiler
Mojo.java:493)
org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.ja va:114)
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPlugi
nManager.java:451)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oals(Defa
ultLifecycleExecutor.java:558)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalWithLi
fecycle(DefaultLifecycleExecutor.java:499)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oal(Defau
ltLifecycleExecutor.java:478)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHan
dleFailures(DefaultLifecycleExecutor.java:330)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegmen
ts(DefaultLifecycleExecutor.java:291)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLi
fecycleExecutor.java:142)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:33 6)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
sorImpl.java:25)
org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.ja va:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher. java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Re: wost wanted features for Maven integration [message #9398 is a reply to message #9372] Fri, 23 May 2008 08:43 Go to previous messageGo to next message
Ulli,
Have you tried Tycho compiler I mentioned earlier? It is available from
http://nexus.sonatype.org:8081/nexus/content/repositories/ec lipse-snapshots
repository and currently uses JDT compiler from eclipse 3.2.1 but I'll
be switching it to 3.4 soon.
>>>> and osgi bundles. One of Tycho's goals is to enforce OSGi class
>>>> do this. Tycho already uses Eclipse 3.2 JDT compiler but we plan to
>> used fro compiling OSGi bundles and I am not sure if it would work for
>> <plugin>
>> <configuration>
>> </configuration>
>> <dependencies>
>> <dependency>
>> </dependency>
>> <dependency>
> linkage er
> Plugin realm =
> urls =
> urls =
> urls =
> urls =
> urls =
> 3.3.0-v_771.jar
> urls =
> urls =
> urls =
> r
> FATAL ERROR
> [INFO]
> [INFO] Trace
> at
> at
> at
> at
> Mojo.java:493)
> at
> at
> nManager.java:451)
> at
> at
> at
> at
> at
> at
> at
> java:39)
> at
> sorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
Re: wost wanted features for Maven integration [message #9421 is a reply to message #9372] Fri, 23 May 2008 11:14 Go to previous messageGo to next message
>> story) that I've tested with Maven 2.0.9:
> urls[0] =
> file:/C:/Build/Tools/apache-maven-2.0.8/bin/../lib/maven-2.0 .9-uber.jar
You do need to use Maven 2.0.9
regards,
Eugene
Re: wost wanted features for Maven integration [message #9538 is a reply to message #9421] Mon, 26 May 2008 07:52 Go to previous messageGo to next message
>> urls[0] =
> regards,
> Eugene
Well, I use maven 2.0.9 (just the path is old to avoid changing the
system path), as you see from lib/maven-2.0.9-uber.jar.
Re: wost wanted features for Maven integration [message #9561 is a reply to message #9398] Mon, 26 May 2008 07:56 Go to previous message
> Ulli,
I see, I need to add another snapshot repository. I tried without that
and had no success. I'll try again with the new snapshot repository
enabled and let you know...
Thanks, Ulli
Previous Topic:IP Process
Next Topic:contributing to m2e (help wanted issues)
Current Time: Sat Jul 26 02:31:41 EDT 2025
Powered by FUDForum. Page generated in 0.29170 seconds
