Home » Language IDEs » PHP Development Tools (PDT) » Slow editors
Slow editors [message #38420] Mon, 23 July 2007 07:20 Go to next message
Hi all,
I have installed the latest milestone release (1.0 m1). Somehow all the
text editors, especially the PHP editor are very slow, in comparison to
the previous version i used (0.7).
What tips / tricks can anyone of you give me to optimize eclipse/pdt so
the editor is as fast as possible?
thanks in advance,
drm / Gerard
Re: Slow editors [message #38453 is a reply to message #38420] Mon, 23 July 2007 07:27 Go to previous messageGo to next message
Originally posted by: slydder.arcor.de
Gerard,
The biggest and best improvement you can make is to switch from GIJ to
Sun Java. Just take a look at the posts below your first one for the
tail end of a discussion regarding this topic.
chuck
drm wrote:
> Hi all,
> thanks in advance,
> drm / Gerard
Re: Slow editors [message #38486 is a reply to message #38453] Mon, 23 July 2007 08:38 Go to previous messageGo to next message
Hi chuck,
Thanks for your reply. I forgot to mention I'm working on a Windows XP
machine with the latest JRE installed (java6 update2). It seems your
post regards a ubuntu (or at least debian) machine, using gij. I don't
think your post will help solve my slow pdt.
drm / Gerard
chuck wrote:
> Gerard,
> chuck
> drm wrote:
>> Hi all,
>> the text editors, especially the PHP editor are very slow, in
>> comparison to the previous version i used (0.7).
>> so the editor is as fast as possible?
>> thanks in advance,
>> drm / Gerard
Re: Slow editors [message #38518 is a reply to message #38486] Mon, 23 July 2007 09:12 Go to previous messageGo to next message
Originally posted by: ale.g.gonzalez.gmail.com
Hi!, I'm using the last integration build (I20070712) and it seems to
work faster than 1.0 M1
http://europa-mirror1.eclipse.org/tools/pdt/downloads/?relea se=I20070712
drm escribió:
> Hi chuck,
> drm / Gerard
> chuck wrote:
>> Gerard,
>> chuck
>> drm wrote:
>>> Hi all,
>>> thanks in advance,
>>> drm / Gerard
Re: Slow editors [message #38584 is a reply to message #38518] Mon, 23 July 2007 11:16 Go to previous messageGo to next message
Thanks Alejandro, i'll try that.
> drm escribió:
>> Hi chuck,
>> drm / Gerard
>> chuck wrote:
>>> Gerard,
>>> chuck
>>> drm wrote:
>>>> Hi all,
>>>> thanks in advance,
>>>> drm / Gerard
Re: Slow editors [message #38773 is a reply to message #38584] Mon, 23 July 2007 16:57 Go to previous messageGo to next message
Originally posted by: pobox.verysmall.org
Yes, somebody wrote that in 1.0 the project re-build cycle is run on
every pressed key, which is improved in the integration build.
Iavor
Re: Slow editors [message #38901 is a reply to message #38420] Tue, 24 July 2007 08:21 Go to previous messageGo to next message
I was a bit annoyed too with the slow editor in M1 so I found how to make
it a bit faster, in the preferences :
General/Editors/Structured Text Editors => un-check "Report problem as you
type".
General/Editors/Structured Text Editors/Spelling => un-check "Enable spell
checking"
I also suspended all the validators (Validation => Suspend all validators).
Hope this help ;)
Re: Slow editors [message #38977 is a reply to message #38901] Tue, 24 July 2007 17:56 Go to previous messageGo to next message
yap, disabling all these nice features of the editor may be an option,
although you miss the power of it.
You may try our latest release I20070712 and see if this issue improved as
we had some improvments in the editor performance.
Re: Slow editors [message #39154 is a reply to message #38977] Wed, 25 July 2007 09:57 Go to previous messageGo to next message
It doesn't remove any key-features I use in everyday programming ;)
I use this new release, but still... I'll check with M2.
Re: Slow editors [message #39215 is a reply to message #38901] Thu, 26 July 2007 05:41 Go to previous messageGo to next message
Hi Bruce,
I tried that, but it still wasn't really, well ..., "like lightning" ;)
I don't really have a beast of a machine here, it's an oldie AMD 1800
XP, though 1 G of RAM. JVM programs aren't that fast in general on my
machine.
I'll try the integration build this afternoon, i'll post my experiences
after that.
PS
Are there perhaps JVM command line options that can optimize eclipse or
the JVM in general?
> make it a bit faster, in the preferences :
> you type".
> spell checking"
> Hope this help ;)
Re: Slow editors [message #39246 is a reply to message #39215] Thu, 26 July 2007 12:24 Go to previous messageGo to next message
..oO(drm)
>machine.
Here: PIII@1.2GHz, 512 MB RAM
The latest integration build runs smooth enough on my "oldie".
Micha
Re: Slow editors [message #39732 is a reply to message #39215] Mon, 30 July 2007 05:44 Go to previous messageGo to next message
I run the last incubation build with the same options and it runs quite
smooth here.
Re: Slow editors [message #40759 is a reply to message #38773] Fri, 03 August 2007 06:47 Go to previous messageGo to next message
It is indeed way faster. Thanks for the tip!
> Iavor
Re: Slow editors [message #40821 is a reply to message #39732] Fri, 03 August 2007 06:47 Go to previous message
Integration build is indeed way faster. Thanks for the tip.
> smooth here.
Previous Topic:Newbie : Xdebug setup
Next Topic:Using exec to run Java apps
Current Time: Thu Jul 24 09:20:29 EDT 2025
Powered by FUDForum. Page generated in 0.05487 seconds
