Slow editors [message #38420] |
Mon, 23 July 2007 07:20  |
Hi all,
I have installed the latest milestone release (1.0 m1). Somehow all the
text editors, especially the PHP editor are very slow, in comparison to
the previous version i used (0.7).
What tips / tricks can anyone of you give me to optimize eclipse/pdt so
the editor is as fast as possible?
thanks in advance,
drm / Gerard
Re: Slow editors [message #38584 is a reply to message #38518] |
Mon, 23 July 2007 11:16   |
Thanks Alejandro, i'll try that.
Alejandro González wrote:
> Hi!, I'm using the last integration build (I20070712) and it seems to
> work faster than 1.0 M1
> http://europa-mirror1.eclipse.org/tools/pdt/downloads/?relea se=I20070712
> drm escribió:
>> Hi chuck,
>> Thanks for your reply. I forgot to mention I'm working on a Windows XP
>> machine with the latest JRE installed (java6 update2). It seems your
>> post regards a ubuntu (or at least debian) machine, using gij. I don't
>> think your post will help solve my slow pdt.
>> drm / Gerard
>> chuck wrote:
>>> Gerard,
>>> The biggest and best improvement you can make is to switch from GIJ to
>>> Sun Java. Just take a look at the posts below your first one for the
>>> tail end of a discussion regarding this topic.
>>> chuck
>>> drm wrote:
>>>> Hi all,
>>>> the text editors, especially the PHP editor are very slow, in
>>>> comparison to the previous version i used (0.7).
>>>> so the editor is as fast as possible?
>>>> thanks in advance,
>>>> drm / Gerard
Re: Slow editors [message #40821 is a reply to message #39732] |
Fri, 03 August 2007 06:47  |
Integration build is indeed way faster. Thanks for the tip.
Bruce Heller schreef:
> I run the last incubation build with the same options and it runs quite
> smooth here.
FUDForum. Page generated in 0.07601 seconds
