Home » Modeling » TMF (Xtext) » [Xtext] Installing XText M6 on 3.5M6
[Xtext] Installing XText M6 on 3.5M6 [message #38394] Mon, 06 April 2009 22:43 Go to next message
I am trying to get Xtext integrated into our main dev environments. For this
particular case the target was 3.5 on Windows 32-bit and Linux 64-bit.
Below is the procedure I found that works. Note that I only did some basic
testing with which consisted of generating 3 xtext grammars and verifying
the editor works with some language source files.
1) For Windows download and install eclipse-SDK-3.5M6-win32.zip and for
Linux 64-bit download and install eclipse-SDK-3.5M6-linux-gtk-x86_64.tar. I
presume the other platforms should work similarly with this procedure.
2) Install the modeling plugins using Help->Install New Software. In the
"work with:" pull down select "All Available Sites". Check the modeling
option (i.e. install all modeling components).
3) Download the Itemis Xtext 3.5 M6 distro
( http://oaw.itemis.de/openarchitectureware/language=de/660/do wnloads)
because it has the required Antlr related jars needed to make the
intallation work (I have always used Antlr and don't really know what will
happen without it. Since I am very familiar with Antlr I prefer it since I
know how to deal with its errors and warnings resulting from the grammar I
write with Xtext). Copy the following plug-ins to your new installation:
org.antlr.gen_3.0.1.200903171045
de.itemis.xtext.antlr_0.7.0.200903171045.jar
The reason for step 3 is I could not get a set of working Antlr jars any
other way. There is a link in the Xtext documentation
(http://wiki.eclipse.org/Xtext/Documentation) which points to
http://www.itemis.com/error/404?aspxerrorpath=/itemis-ag/mil estones but this
page does not exist anymore. I found a link to
http://ftp.itemis.de/files/xtext/antlr.zip but these plug-ins did not work.
They seem dated with respect to M6.
Based on my experiments these two plug-ins just need to be posted and
referenced in the document for 3.5 installs to work, unless, of course, if
there is some easier method I am missing.
Derek
Re: [Xtext] Installing XText M6 on 3.5M6 [message #38427 is a reply to message #38394] Tue, 07 April 2009 00:26 Go to previous messageGo to next message
At the bottom of this page:
http://www.eclipse.org/modeling/tmf/downloads/?project=xtext
you can find the link to Antlr for the Update Manager:
http://xtext.itemis.com/updates/milestones/site.xml
The link is placed in a really visible place. How could you miss it? :-)
My strategy was to download all the dependencies by hand (including
Eclipse 3.5M6). This way, I knew that what I got has the proper version.
Antlr is the only thing I installed using the Update Manager.
Lucian
Derek Palma wrote:
> this particular case the target was 3.5 on Windows 32-bit and Linux 64-bit.
> basic testing with which consisted of generating 3 xtext grammars and
> verifying the editor works with some language source files.
> eclipse-SDK-3.5M6-linux-gtk-x86_64.tar. I presume the other platforms
> will happen without it. Since I am very familiar with Antlr I prefer it
> since I know how to deal with its errors and warnings resulting from the
> grammar I write with Xtext). Copy the following plug-ins to your new
> installation:
> this page does not exist anymore. I found a link to
> work. They seem dated with respect to M6.
> if there is some easier method I am missing.
> Derek
Re: [Xtext] Installing XText M6 on 3.5M6 [message #38460 is a reply to message #38427] Tue, 07 April 2009 01:14 Go to previous message
Ok, Thanks Lucian!!! That makes the procedure really easy.
Generally I also gather all the plugins first but I saw the modeling
contents for M6 seemed to have Xtext M6. I certainly should verify the rest
of the numbers...
I am going to try 3.4 now and that will require grabbing all the
dependencies and adding them on top of my other updates. I am going in with
the assumption that EMF 2.5 is not needed based on some comments from Ed
Merks earlier (this may be obvious to everyone but not to me) and that all
other packages on the Xtext download page should supercede whatever I have
in my 3.4 envs.
Derek
"Lazar Codrut-Lucian" <lcodrutlucian@yahoo.com> wrote in message
news:grekdn$1ge$1@build.eclipse.org...
> Lucian
> Derek Palma wrote:
>> 64-bit.
>> installation:
>> Derek
Previous Topic:[XText] IValueConverter and editor sytnax error presentation
Next Topic:[TCS] Grammar file ".g"
Current Time: Sun Jul 27 12:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.03711 seconds
