Unable to parse resource. Check query regexp [message #38197] |
Wed, 05 December 2007 04:09  |
I have a generic web connection. It works generally ok but when there is no
task, it gives the error. Is it possible to list no task in the view because
there is no tasks available on the web interface also?
When there is 1 task or more tasks available, my query works ok and lists
all the tasks correctly. What might be the problem?
Burak
Re: Unable to parse resource. Check query regexp [message #38395 is a reply to message #38362] |
Thu, 06 December 2007 03:51  |
Ali Burak Kulakli wrote:
> I did try and it worked. Thanks. However, my another query stopped working.
> I'll wait for the release.
In my knowledge there are no critical bugs known for the the web
connector component.
Please submit a bug report to the project's Bugzilla issue tracker.
We'll need enough information to reproduce that issue.
Eugene
Re: Unable to parse resource. Check query regexp [message #585614 is a reply to message #38197] |
Wed, 05 December 2007 10:55  |
Which version of the web connector you are using? Your description is
sounds the same as bug 204061 that been fixed on October 20.
204061: [web connector] error when valid query yields 0 results
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204061
The latest version is available from the weekly "extras" update site.
See http://www.eclipse.org/mylyn/downloads/
regards,
Eugene
Re: Unable to parse resource. Check query regexp [message #585655 is a reply to message #38230] |
Thu, 06 December 2007 02:14  |
Hi Eugene
Burak
"Eugene Kuleshov" <eu@md.pp.ru> wrote in message
news:fj6hlf$5q1$1@build.eclipse.org...
>> no task, it gives the error. Is it possible to list no task in the view
>> because there is no tasks available on the web interface also?
> The latest version is available from the weekly "extras" update site. See
> regards,
> Eugene
Re: Unable to parse resource. Check query regexp [message #585663 is a reply to message #38362] |
Eugene
FUDForum. Page generated in 0.03369 seconds
