Home » General (non-technical) » Eclipse Foundation » Deleting IFile instance
Deleting IFile instance [message #38186] Mon, 07 August 2006 08:13 Go to next message
Originally posted by: nagel.trium.de
Hi all,
In my RCP application I want to delete an IFile instance by calling its
delete() method. If the file was changed (in an editor) before, I always
get a ResourceException and the file is not deleted. Is it possible to
force the deletion?
Thanks in advance,
Lars
Re: Deleting IFile instance [message #38222 is a reply to message #38186] Mon, 07 August 2006 08:48 Go to previous messageGo to next message
Lars,
Ask general questions like this on the platform newsgroup. I know that
delete fails if the file in the workspace is out of sync with the file
system, so maybe you just need to refresh it. (See
IResource.isSynchronized/refreshLocal.) Is your editor saving using the
workspace API or is it saving directly to the file system? The later
would cause a problem like this.
Lars Nagel wrote:
> Hi all,
> its delete() method. If the file was changed (in an editor) before, I
> always get a ResourceException and the file is not deleted. Is it
> possible to force the deletion?
> Thanks in advance,
> Lars
Re: Deleting IFile instance [message #38252 is a reply to message #38222] Mon, 07 August 2006 09:50 Go to previous message
Ed Merks wrote:
> Lars,
Okay, thanks.
It is in sync, and I also set the FORCE flag.
I use AbstractTextEditor.doSave(null).
> Lars Nagel wrote:
>> Hi all,
>> Thanks in advance,
>> Lars
Previous Topic:members not meeting the engagements
Next Topic:"NoClassDefFoundError" when use the ant in eclipse
Current Time: Sun Aug 31 23:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.06176 seconds
