Home » Archived » XML Schema Definition (XSD) » Help with annotations
Help with annotations [message #38174] Mon, 08 March 2004 09:08 Go to next message
Ed,
I need some help with annotations. We have several extension properties
for XSDSimpleTypeDefinitions that we'd like to persist via Annotations.
What is the best practice for capturing name value pairs in the appInfo?
The tricky part is that the values may contain all readable characters so we
can't simply use a delimited string. We'd prefer to use XML, but if I
remember correctly there are issues with capturing XML in the appInfo value
field.
thanks,
Lance Phillips
Re: Help with annotations [message #38272 is a reply to message #38174] Mon, 08 March 2004 11:02 Go to previous messageGo to next message
Lance,
The appinfo element can contain any nested XML so you should have a source
attribute to uniquely identify the appinfo as yours and then have some XML
syntax for describing the information, kind of like <hfp:xyz> stuff in the
schema for schemas. You might also consider encoding the information as a
non-schema namespace attribute, kind of like the ecore:xyz annotations we
support for specifying the mapping to Ecore.
Lance Phillips wrote:
> Ed,
> field.
> thanks,
> Lance Phillips
Re: Help with annotations [message #38371 is a reply to message #38272] Mon, 08 March 2004 13:33 Go to previous messageGo to next message
Ed,
I actually found a very simple approach that seems to meet our needs.
Under the appinfo element I've simply added our tags as dom Attr entities.
It outputs beautifully and seems to meet all our needs. Are there any
dangers that I should be aware of with this approach?
thanks,
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:404C990C.A8F2B6F1@ca.ibm.com...
> Lance,
> > Ed,
properties
so we
value
> > field.
> > thanks,
> > Lance Phillips
Re: Help with annotations [message #38404 is a reply to message #38371] Mon, 08 March 2004 17:53 Go to previous message
Lance,
This sounds fine.
> Ed,
> thanks,
> lp
> > Lance,
> > > Ed,
> properties
> so we
> value
> > > field.
> > > thanks,
> > > Lance Phillips
Re: Help with annotations [message #583932 is a reply to message #38174] Mon, 08 March 2004 11:02 Go to previous message
Lance,
> Ed,
> field.
> thanks,
> Lance Phillips
Re: Help with annotations [message #583990 is a reply to message #38272] Mon, 08 March 2004 13:33 Go to previous message
Ed,
thanks,
lp
> Lance,
> > Ed,
properties
so we
value
> > field.
> > thanks,
> > Lance Phillips
Re: Help with annotations [message #584003 is a reply to message #38371] Mon, 08 March 2004 17:53 Go to previous message
Lance,
This sounds fine.
> Ed,
> thanks,
> lp
> > Lance,
> > > Ed,
> properties
> so we
> value
> > > field.
> > > thanks,
> > > Lance Phillips
Previous Topic:Help with annotations
Next Topic:Problem Including schemas
Current Time: Sun Aug 31 12:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.04414 seconds
