CDO [message #38094] |
Tue, 20 June 2006 10:07  |
When can we hope to get a RC for CDO, I am not possible to download
something from update manager.
Thanx Chris
Re: CDO [message #38457 is a reply to message #38425] |
Sat, 24 June 2006 02:13  |
Originally posted by: stepper.sympedia.de
Chris,
I appreciate that CDO fits your needs ;-)
Tell me if I can assist you further.
Cheers
/Eike
Chris Lenz schrieb:
> Eike Stepper schrieb:
>> Chris,
>> Sorry for the delay of my response.
>> Yes, all the people who are using CDO are currently working with the
>> HEAD version of CVS.
>> Nevertheless we recently managed to make builds that look very
>> promising. I tested them and they worked with the supplied examples.
>> They are already labeled RC7 but that was only a test. I expect real
>> candidates at the beginning of next week.
>> If you don't want to wait, please have a look at these
>> http://emft.eclipse.org/technology/emft/downloads/?proj=net4 j
>> http://emft.eclipse.org/technology/emft/downloads/?proj=cdo
>> and try the inofficial RC7 builds.
>> Here the steps to try it:
>> 1) start a mysql instance on localhost and create the database "cdoTest"
>> for user "test" with password "test" (sql script is in
>> org.eclipse.emf.cdo.examples.server)
>> 2) install net4j-sdk and cdo-sdk and start eclipse
>> 3) ensure that the mysql jar is present
>> 4) create a launch config "CDO Server":
>> select "org.eclipse.emf.cdo.examples.server.application" under "Run
>> an application".
>> select only the "org.eclipse.emf.cdo.examples.server" and click "Add
>> required plugins" (35 out of ...).
>> 5) run the launch config and watch the console output
>> 6) open the view "CDO Explorer"
>> 7) create new remote resources and edit them, rerun eclipse, start
>> second eclipse and so on...
>> I'd appreciate if you give me some feedback whether it works for you ;-)
>> Cheers
>> /Eike
>>>> Thanx Chris
>>> I read some people already uses cdo but i can't download it from
>>> http://download.eclipse.org/technology/emft/downloads/?proj= cdo
>>> are you working on the cvs versions?
>>> Chris
> Thank you for this promt help.
> I have tested the examples, and I have to say thats exactly what I need.
> Now I test to add also other models to the server.
> Thanx Chris
Re: CDO [message #581342 is a reply to message #38294] |
Wed, 21 June 2006 14:28  |
Chris,
We do have the code in CVS and the build set up, but I think Eike's
still doing some testing before publishing the first build.
>> Thanx Chris
> Chris
Re: CDO [message #581360 is a reply to message #38294] |
Thu, 22 June 2006 05:45  |
Chris,
Yes, all the people who are using CDO are currently working with the HEAD
version of CVS.
Nevertheless we recently managed to make builds that look very promising.
I tested them and they worked with the supplied examples. They are already
labeled RC7 but that was only a test. I expect real candidates at the
select "org.eclipse.emf.cdo.examples.server.application" under "Run an
application".
7) create new remote resources and edit them, rerun eclipse, start second
Cheers
/Eike
>> Thanx Chris
> Chris
Re: CDO [message #581390 is a reply to message #38360] |
Fri, 23 June 2006 03:32  |
> Chris,
> an application".
> Cheers
> /Eike
>>> Thanx Chris
>> Chris
Thanx Chris
Re: CDO [message #581444 is a reply to message #38425] |
Chris,
Cheers
/Eike
>> Chris,
>> an application".
>> Cheers
>> /Eike
>>>> Thanx Chris
>>> Chris
> Thanx Chris
FUDForum. Page generated in 0.05552 seconds
