Home » Newcomers » Newcomers » jre1.5, java.util.zip.ZipException: error in opening zip file
jre1.5, java.util.zip.ZipException: error in opening zip file [message #38087] Sun, 20 March 2005 02:26 Go to next message
Originally posted by: slamdunkinpool.gmail.com
I have recently removed jdk/jre1.4 from my system (w2k) and installed
jdk/jre1.5. I have cleaned the .metadata directory of eclipse workspace
also.
Now during build I'm getting following error:
[delete] Deleting directory G:\java\work\desiServer\bin
compile:
[mkdir] Created dir: G:\java\work\desiServer\bin
[javac] Compiling 12 source files to G:\java\work\desiServer\bin
[javac] error: error reading
G:\java\work\desiServer\src\socketThrdServer\commons-logging .properties;
[javac] Note:
G:\java\work\desiServer\src\socketThrdServer\printerQProduce r.java uses
unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 1 error
The project was working fine in eclipse3.0.1 before I updated to java 1.5.
I get the same error in both eclipse3.1M5a and eclipse3.0.1.
Also in eclipse where do I uncheck -Xlint:
slamdunk
Re: jre1.5, java.util.zip.ZipException: error in opening zip file [message #38421 is a reply to message #38087] Mon, 21 March 2005 00:30 Go to previous message
> G:javaworkdesiServersrcsocketThrdServercommons-logging.prope rties;
ZipException error still not solved
solved:
add <compilerarg value="-Xlint" /> in ant under <javac> in build.xml file
Previous Topic:How to: make every thing black background white foreground
Next Topic:View/edit files
Current Time: Sun Jun 08 04:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.08088 seconds
