Home » Eclipse Projects » GEF » is planning to use GEF "safe" ?
is planning to use GEF "safe" ? [message #3285] Mon, 20 May 2002 13:47 Go to next message
I need a diagramming component for an editor plugin I'm developing. I
was planning to use a third party ActiveX component when GEF was
announced. Based on my initial evaluation of GEF, I would be inclined
to use it instead. However I'm concerned about the timing, since GEF is
still in the proposal phase. Do I need to wait until GEF is past the
proposal phase before it's safe to assume that it will become part of
Eclipse? Is there a schedule for it's inclusion in Eclpise? Are there
any issues with the stability of the code at this stage?
David
Re: is planning to use GEF "safe" ? [message #3319 is a reply to message #3285] Mon, 20 May 2002 13:57 Go to previous messageGo to next message
Originally posted by: none.ibm.com
I believe that GEF is past the proposal stage since there is this newsgroup
and CVS home for GEF.
All projects under the "Tools" heading will not be included in the Eclipse
base.
The code is stable.
"David Dean" <david.dean@chordiant.com> wrote in message
news:3CE936A9.2040807@chordiant.com...
> David
Re: is planning to use GEF "safe" ? [message #3417 is a reply to message #3319] Tue, 21 May 2002 09:24 Go to previous message
Originally posted by: John_Duimovich.oti.com
Randy is correct,
If I wasn't travelling and missing my web update tools, I would have fixed
the web pages by now <g>
John Duimovich
"Randy Hudson" <none@ibm.com> wrote in message
news:acbcmn$7h7$1@rogue.oti.com...
newsgroup
> base.
> The code is stable.
> > Thanks,
> > David
Previous Topic:Zooming in GEF/Draw2D
Next Topic:Draw2D menu?
Current Time: Wed Nov 05 00:16:32 EST 2025
Powered by FUDForum. Page generated in 0.03719 seconds
